1.1串口驱动框架疑问
发布于 2013-04-18 17:17:06 浏览:3055
``` /** * uart operators */ struct rt_uart_ops { rt_err_t (*configure)(struct rt_serial_device *serial, struct serial_configure *cfg); rt_err_t (*control)(struct rt_serial_device *serial, int cmd, void *arg); int (*putc)(struct rt_serial_device *serial, char c); int (*getc)(struct rt_serial_device *serial); rt_size_t (*dma_transmit)(struct rt_serial_device *serial, const char *buf, rt_size_t size); }; ``` 我的理解 rt_err_t (*control)(struct rt_serial_device *serial, int cmd, void *arg);控制串口的中断接收与发送 int (*putc)(struct rt_serial_device *serial, char c);从输出一个字符到串口硬件设备 int (*getc)(struct rt_serial_device *serial);从硬件设备获取一个字符 rt_size_t (*dma_transmit)(struct rt_serial_device *serial, const char *buf, rt_size_t size);DMA传送 疑问: 1.rt_err_t (*configure)(struct rt_serial_device *serial, struct serial_configure *cfg);该函数实现的功能 是改变串口配置吗? 2.rt_size_t (*dma_transmit)(struct rt_serial_device *serial, const char *buf, rt_size_t size);怎么实现? 调试代码 ``` #include "stm32f10x.h" #include "serial.h" #include "rtthread.h" #include
/*********************************************************************************************************** @ pin config USART1_REMAP = 0 @____________________________________________________________________________*/ #define UART1_GPIO_TX GPIO_Pin_9 #define UART1_GPIO_RX GPIO_Pin_10 #define UART1_GPIO GPIOA #define RCC_APBPeriph_UART1 RCC_APB2Periph_USART1 #define UART1_TX_DMA DMA1_Channel4 #define UART1_RX_DMA DMA1_Channel5 /*********************************************************************************************************** @ Struct Definition @____________________________________________________________________________*/ struct serial_ringbuffer serial_int_rx_buffer; struct serial_ringbuffer serial_int_tx_buffer; struct rt_serial_device serialx_device; struct serial_user_data { USART_TypeDef* uart_device; const char name[RT_NAME_MAX]; }; /*********************************************************************************************************** @ Hardware clock configuration @____________________________________________________________________________*/ static void RCC_Configuration(void) { RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE); /* Enable USART1 and GPIOA clocks */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1 | RCC_APB2Periph_GPIOA, ENABLE); } static void GPIO_Configuration(void) { GPIO_InitTypeDef GPIO_InitStructure; /* Configure USART1 Rx (PA.10) as input floating */ GPIO_InitStructure.GPIO_Pin = UART1_GPIO_RX; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_Init(UART1_GPIO, &GPIO_InitStructure); /* Configure USART1 Tx (PA.09) as alternate function push-pull */ GPIO_InitStructure.GPIO_Pin = UART1_GPIO_TX; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_Init(UART1_GPIO, &GPIO_InitStructure); } static void NVIC_Configuration(void) { NVIC_InitTypeDef NVIC_InitStructure; /* Enable the USART1 Interrupt */ NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); } /*********************************************************************************************************** @ model driven architecture interface @____________________________________________________________________________*/ int serial_put_char(struct rt_serial_device *serial, char c) { USART_ClearFlag(USART1,USART_FLAG_TC); USART_SendData(USART1, (u8) c); while (USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET); return c; } int serial_get_char(struct rt_serial_device *serial) { int ch = -1; struct serial_user_data* user = (struct serial_user_data *)(serial->parent.user_data); if(USART_GetITStatus(user->uart_device, USART_IT_RXNE) != RESET) { /* interrupt mode receive */ RT_ASSERT(serial->parent.flag & RT_DEVICE_FLAG_INT_RX); ch = USART_ReceiveData(user->uart_device); /* clear interrupt */ USART_ClearITPendingBit(user->uart_device, USART_IT_RXNE); } return ch; } rt_err_t serial_control(struct rt_serial_device *serial, int cmd, void *arg) { u16 int_flag; //interrupt flag FunctionalState NewState; struct serial_user_data *user = (struct serial_user_data *)serial->parent.user_data; switch(*(rt_uint32_t *)arg) { case RT_SERIAL_RX_INT: { int_flag = USART_IT_RXNE; break; } case RT_SERIAL_TX_INT: { int_flag = USART_IT_TC; break; } default : { break; } } switch(cmd) { case RT_DEVICE_CTRL_SET_INT: { NewState = ENABLE; break; } case RT_DEVICE_CTRL_CLR_INT: { NewState = DISABLE; break; } default: { break; } } USART_ITConfig(user->uart_device, int_flag, NewState); } rt_size_t serial_dma_transmit(struct rt_serial_device *serial, const char *buf, rt_size_t size) { } /*********************************************************************************************************** @Struct declaration @____________________________________________________________________________*/ struct serial_configure serial_config = { 115200, 8, 1, 0, 0, 0, 0 }; struct serial_user_data serial_user_struct= { USART1, "usart1" }; rt_err_t stm32_serial_config(struct rt_serial_device *serial, struct serial_configure *cfg); struct rt_uart_ops serial_ops = { stm32_serial_config, serial_control, serial_put_char, serial_get_char, serial_dma_transmit }; rt_err_t stm32_serial_config(struct rt_serial_device *serial, struct serial_configure *cfg) { USART_InitTypeDef USART_InitStructure; USART_ClockInitTypeDef USART_ClockInitStructure; struct serial_user_data* user = (struct serial_user_data *)serial->parent.user_data; RCC_Configuration(); GPIO_Configuration(); NVIC_Configuration(); /* serial->config = serial_config; serial->int_rx = &serial_int_rx_buffer; serial->int_tx = &serial_int_tx_buffer; serial->ops = &serial_ops; */ USART_InitStructure.USART_BaudRate = 9600; USART_InitStructure.USART_WordLength = USART_WordLength_8b; USART_InitStructure.USART_StopBits = USART_StopBits_1; USART_InitStructure.USART_Parity = USART_Parity_No; USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; USART_ClockInitStructure.USART_Clock = USART_Clock_Disable; USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low; USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge; USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable; USART_Init(user->uart_device, &USART_InitStructure); USART_ClockInit(user->uart_device, &USART_ClockInitStructure); // rt_hw_serial_register(serial, user->name, // RT_DEVICE_FLAG_RDWR | RT_DEVICE_FLAG_INT_RX | RT_DEVICE_FLAG_STREAM, // user); /* enable interrupt */ USART_ITConfig(user->uart_device, USART_IT_RXNE, ENABLE); return RT_EOK; } void rt_hw_usart2_init(void) { /* USART_InitTypeDef USART_InitStructure; USART_ClockInitTypeDef USART_ClockInitStructure; RCC_Configuration(); GPIO_Configuration(); NVIC_Configuration(); */ serialx_device.config = serial_config; serialx_device.int_rx = &serial_int_rx_buffer; serialx_device.int_tx = &serial_int_tx_buffer; serialx_device.ops = &serial_ops; /* USART_InitStructure.USART_BaudRate = 115200; USART_InitStructure.USART_WordLength = USART_WordLength_8b; USART_InitStructure.USART_StopBits = USART_StopBits_1; USART_InitStructure.USART_Parity = USART_Parity_No; USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; USART_ClockInitStructure.USART_Clock = USART_Clock_Disable; USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low; USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge; USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable; USART_Init(serial_user_struct.uart_device, &USART_InitStructure); USART_ClockInit(serial_user_struct.uart_device, &USART_ClockInitStructure); */ rt_hw_serial_register(&serialx_device, serial_user_struct.name, RT_DEVICE_FLAG_RDWR | RT_DEVICE_FLAG_INT_RX | RT_DEVICE_FLAG_STREAM, &serial_user_struct); /* enable interrupt */ //USART_ITConfig(serial_user_struct.uart_device, USART_IT_RXNE, ENABLE); //stm32_serial_config(&serialx_device,&serial_config); } ```
xiao苦
2013-04-19
- -首先 rt_err_t (*control)(struct rt_serial_device *serial, int cmd, void *arg); 是所有设备驱动都有的控制函数,主要用于一些额外命令的读写, 通过arg参数传递/ rt_err_t (*configure)(struct rt_serial_device *serial, struct serial_configure *cfg);该函数是根据输入的配置包进行配置。 rt_size_t (*dma_transmit)(struct rt_serial_device *serial, const char *buf, rt_size_t size);要自己根据硬件需求写dma传送代码,具体是可以参考SPI 驱动的DMA模式, 利用信号量来实现多个包DMA传送。
王周旺
2013-04-19
经过两天的调试这个问题基本已经解决了 目前uart1可以用 但是uart2还有问题 我想把使用所有串口做成一个可配置的接口 初步封装了一下 不知道 用那种方式比较好 ``` #include "stm32f10x.h" #include "serial.h" #include "rtthread.h" #include
/*********************************************************************************************************** @ pin config USART1_REMAP = 0 @____________________________________________________________________________*/ /* USART1_REMAP = 0 */ #define UART1_GPIO_TX GPIO_Pin_9 #define UART1_GPIO_RX GPIO_Pin_10 #define UART1_GPIO GPIOA #define RCC_APBPeriph_UART1 RCC_APB2Periph_USART1 #define USART1_TX_DMA DMA1_Channel4 #define USART1_RX_DMA DMA1_Channel5 #if defined(STM32F10X_LD) || defined(STM32F10X_MD) || defined(STM32F10X_CL) #define UART2_GPIO_TX GPIO_Pin_5 #define UART2_GPIO_RX GPIO_Pin_6 #define UART2_GPIO GPIOD #define RCC_APBPeriph_UART2 RCC_APB1Periph_USART2 #else /* for STM32F10X_HD */ /* USART2_REMAP = 0 */ #define UART2_GPIO_TX GPIO_Pin_2 #define UART2_GPIO_RX GPIO_Pin_3 #define UART2_GPIO GPIOA #define RCC_APBPeriph_UART2 RCC_APB1Periph_USART2 #define UART2_TX_DMA DMA1_Channel7 #define UART2_RX_DMA DMA1_Channel6 #endif /* USART3_REMAP[1:0] = 00 */ #define UART3_GPIO_RX GPIO_Pin_11 #define UART3_GPIO_TX GPIO_Pin_10 #define UART3_GPIO GPIOB #define RCC_APBPeriph_UART3 RCC_APB1Periph_USART3 #define UART3_TX_DMA DMA1_Channel2 #define UART3_RX_DMA DMA1_Channel3 /*********************************************************************************************************** @ Struct Definition @____________________________________________________________________________*/ struct serial_user_data { USART_TypeDef* uart_device; const char name[RT_NAME_MAX]; }; /*********************************************************************************************************** @ Hardware clock configuration @____________________________________________________________________________*/ static void RCC_Configuration(void) { RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE); /* Enable USART1 and GPIOA clocks */ RCC_APB2PeriphClockCmd(RCC_APBPeriph_UART1 | RCC_APB2Periph_GPIOA, ENABLE); /* Enable AFIO and GPIOD clock */ RCC_APB1PeriphClockCmd(RCC_APBPeriph_UART2, ENABLE); } static void GPIO_Configuration(void) { GPIO_InitTypeDef GPIO_InitStructure; /* Configure USART1 Rx (PA.10) as input floating */ GPIO_InitStructure.GPIO_Pin = UART1_GPIO_RX; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_Init(UART1_GPIO, &GPIO_InitStructure); /* Configure USART1 Tx (PA.09) as alternate function push-pull */ GPIO_InitStructure.GPIO_Pin = UART1_GPIO_TX; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_Init(UART1_GPIO, &GPIO_InitStructure); /* Configure USART2 Rx as input floating */ GPIO_InitStructure.GPIO_Pin = UART2_GPIO_RX; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_Init(UART2_GPIO, &GPIO_InitStructure); /* Configure USART2 Tx as alternate function push-pull */ GPIO_InitStructure.GPIO_Pin = UART2_GPIO_TX; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(UART2_GPIO, &GPIO_InitStructure); } static void NVIC_Configuration(void) { NVIC_InitTypeDef NVIC_InitStructure; /* Enable the USART1 Interrupt */ NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority =1; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); /* Enable the USART2 Interrupt */ NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); } static void DMA_Configuration(void) { #if defined (RT_USING_UART3) DMA_InitTypeDef DMA_InitStructure; /* fill init structure */ DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte; DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte; DMA_InitStructure.DMA_Mode = DMA_Mode_Normal; DMA_InitStructure.DMA_Priority = DMA_Priority_VeryHigh; DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; /* DMA1 Channel5 (triggered by USART3 Tx event) Config */ DMA_DeInit(UART3_TX_DMA); DMA_InitStructure.DMA_PeripheralBaseAddr = USART3_DR_Base; DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST; /* As we will set them before DMA actually enabled, the DMA_MemoryBaseAddr * and DMA_BufferSize are meaningless. So just set them to proper values * which could make DMA_Init happy. */ DMA_InitStructure.DMA_MemoryBaseAddr = (u32)0; DMA_InitStructure.DMA_BufferSize = 1; DMA_Init(UART3_TX_DMA, &DMA_InitStructure); DMA_ITConfig(UART3_TX_DMA, DMA_IT_TC | DMA_IT_TE, ENABLE); DMA_ClearFlag(DMA1_FLAG_TC2); #endif } /*********************************************************************************************************** @ model driven architecture interface @____________________________________________________________________________*/ rt_err_t stm32_serial_config(struct rt_serial_device *serial, struct serial_configure *cfg); int serial_put_char(struct rt_serial_device *serial, char c) { struct serial_user_data* user = (struct serial_user_data *)(serial->parent.user_data); USART_ClearFlag(user->uart_device,USART_FLAG_TC); USART_SendData(user->uart_device, c); while (USART_GetFlagStatus(user->uart_device, USART_FLAG_TC) == RESET); return c; } int serial_get_char(struct rt_serial_device *serial) { int ch = -1; struct serial_user_data* user = (struct serial_user_data *)(serial->parent.user_data); if(USART_GetITStatus(user->uart_device, USART_IT_RXNE) != RESET) { /* interrupt mode receive */ RT_ASSERT(serial->parent.flag & RT_DEVICE_FLAG_INT_RX); ch = USART_ReceiveData(user->uart_device); /* clear interrupt */ USART_ClearITPendingBit(user->uart_device, USART_IT_RXNE); } return ch; } rt_err_t serial_control(struct rt_serial_device *serial, int cmd, void *arg) { FunctionalState NewState; struct serial_user_data *user = (struct serial_user_data *)serial->parent.user_data; switch(cmd) { case RT_DEVICE_CTRL_SET_INT: { NewState = ENABLE; break; } case RT_DEVICE_CTRL_CLR_INT: { NewState = DISABLE; break; } default: { break; } } switch(*(rt_uint32_t *)arg) { case RT_SERIAL_RX_INT: { USART_ITConfig(user->uart_device, USART_IT_RXNE, NewState); break; } case RT_SERIAL_TX_INT: { USART_ITConfig(user->uart_device, USART_IT_TC, NewState); break; } default : { break; } } return RT_EOK; } rt_size_t serial_dma_transmit(struct rt_serial_device *serial, const char *buf, rt_size_t size) { return size; } rt_err_t stm32_serial_config(struct rt_serial_device *serial, struct serial_configure *cfg) { USART_InitTypeDef USART_InitStructure; USART_ClockInitTypeDef USART_ClockInitStructure; struct serial_user_data* user = (struct serial_user_data *)serial->parent.user_data; RCC_Configuration(); GPIO_Configuration(); NVIC_Configuration(); DMA_Configuration(); USART_InitStructure.USART_BaudRate = cfg->baud_rate; switch(cfg->data_bits) { case 8: { USART_InitStructure.USART_WordLength = USART_WordLength_8b; break; } case 9: { USART_InitStructure.USART_WordLength = USART_WordLength_9b; break; } default : { #ifndef RT_USING_FINSH rt_kprintf("data bit set error "); #endif break; } } switch(cfg->stop_bits) { case 1: { USART_InitStructure.USART_StopBits = USART_StopBits_1; break; } case 2: { USART_InitStructure.USART_StopBits = USART_StopBits_2; break; } case 3: { USART_InitStructure.USART_StopBits = USART_StopBits_0_5; break; } case 4: { USART_InitStructure.USART_StopBits = USART_StopBits_1_5; break; } default : { #ifndef RT_USING_FINSH rt_kprintf("stopbits bit set error "); #endif break; } } switch(cfg->parity) { case 0: { USART_InitStructure.USART_Parity = USART_Parity_No; break; } case 1: { USART_InitStructure.USART_Parity = USART_Parity_Odd; break; } case 2: { USART_InitStructure.USART_Parity = USART_Parity_Even; break; } default : { #ifndef RT_USING_FINSH rt_kprintf("data bit set error "); #endif break; } } USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; USART_ClockInitStructure.USART_Clock = USART_Clock_Disable; USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low; USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge; USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable; USART_Init(user->uart_device, &USART_InitStructure); USART_ClockInit(user->uart_device, &USART_ClockInitStructure); /* enable interrupt */ USART_ITConfig(user->uart_device, USART_IT_RXNE, ENABLE); return RT_EOK; } /*********************************************************************************************************** @serial private function @____________________________________________________________________________*/ struct rt_uart_ops serial_ops = { stm32_serial_config, serial_control, serial_put_char, serial_get_char, serial_dma_transmit }; /*********************************************************************************************************** @Struct declaration @____________________________________________________________________________*/ struct serial_configure serial_config = { 115200, //USART_BaudRate 8, //USART_WordLength 1, //USART_StopBits 0, //USART_Parity 0, // 0, // 0 // }; struct serial_user_data serial_user_struct = { USART2, //hardware device "uart2" //device name }; struct serial_ringbuffer serial_int_rx_buffer; struct serial_ringbuffer serial_int_tx_buffer; struct rt_serial_device serialx_device; void rt_hw_serialx_register(void) { serialx_device.config = serial_config; serialx_device.int_rx = &serial_int_rx_buffer; serialx_device.int_tx = &serial_int_tx_buffer; serialx_device.ops = &serial_ops; rt_hw_serial_register(&serialx_device, serial_user_struct.name, RT_DEVICE_FLAG_RDWR | RT_DEVICE_FLAG_INT_RX | RT_DEVICE_FLAG_STREAM, &serial_user_struct); } struct serial_user_data serial_user_struct1 = { USART1, //hardware device "uart1" //device name }; struct rt_serial_device serialx_device1; struct serial_ringbuffer serial_int_rx_buffer1; struct serial_ringbuffer serial_int_tx_buffer1; void rt_hw_serialx_register1(void) { serialx_device1.config = serial_config; serialx_device1.int_rx = &serial_int_rx_buffer1; serialx_device1.int_tx = &serial_int_tx_buffer1; serialx_device1.ops = &serial_ops; rt_hw_serial_register(&serialx_device1, serial_user_struct1.name, RT_DEVICE_FLAG_RDWR | RT_DEVICE_FLAG_INT_RX | RT_DEVICE_FLAG_STREAM, &serial_user_struct1); } #ifdef RT_USING_FINSH #include
static rt_uint8_t led_inited = 0; void usarts2(char *str) { rt_device_t usart; usart = rt_device_find("uart2"); rt_device_write(usart,0,str,20); } FINSH_FUNCTION_EXPORT(usarts2,str) #endif ```
prife
2013-04-20
[http://www.rt-thread.org/phpBB3/viewtopic.php?f=2&t=2629](http://www.rt-thread.org/phpBB3/viewtopic.php?f=2&t=2629) 5路uart全可用。rtt的device框架本身就已经对uart做了些封装了,就不要画蛇添足了。
王周旺
2013-04-20
恩 看了一下你发的那个这个驱动框架和BSP/device驱动框架一样 我之所以要画蛇添足是因为 BSP/device/serial.c中使用了与硬件有关的底层函数,而在\components\drivers\serial\serial.c已经把串口驱动完全抽象出来,也就是说在新平台上串口驱动只要完成usart.c与usart.h即可。
3.1k
王周旺
33
Wireshark抓包EtherCAT报文
RT-Thread studio的驱动5.1.0报错修改
818
