Network
LWIP在STM32F746G-DISCO移植问题
发布于 2016-07-07 10:56:19 浏览:4326
目的: 打算将STM32F746G-DISCO这个官方开发板的网口上使用RTT+lwip,但是经过努力没有成功,请各位兄弟一起帮我查查是哪里出了问题。 思路: 由于rtt里面含有lwip组件,而且包含了收发处理线程。只需要写一个让网口工作,帧数据的收发函数,在注册到网络设备中。 结论: 通过这样配置之后现在路由器可以才开发板自动分配IP,在路由器中可以看到这个开发板的IP。 现在无论就是无法ping通开发板,总是现在请求超时。 也请版主帮我看看那里还有问题。 代码如下: ```/** * @brief This function handles Ethernet interrupt request. * @param None * @retval None */ void ETH_IRQHandler(void) { /* enter interrupt */ rt_interrupt_enter(); HAL_ETH_IRQHandler(&EthHandle); /* leave interrupt */ rt_interrupt_leave(); } /** * @brief Ethernet Rx Transfer completed callback * @param heth: ETH handle * @retval None */ void HAL_ETH_RxCpltCallback(ETH_HandleTypeDef *heth) { rt_err_t err; /* a frame has been received */ err = eth_device_ready(&(stm32_eth_device.parent)); if (err != RT_EOK) { STM32_ETH_PRINTF("frame mb send failed! "); } } static rt_err_t rt_stm32_eth_init(rt_device_t dev) { struct rt_stm32_eth * stm32_eth = (struct rt_stm32_eth *)dev; EthHandle.Instance = ETH; EthHandle.Init.MACAddr = stm32_eth->dev_addr; EthHandle.Init.AutoNegotiation = ETH_AUTONEGOTIATION_ENABLE; EthHandle.Init.Speed = stm32_eth->ETH_Speed; EthHandle.Init.DuplexMode = stm32_eth->ETH_Mode; EthHandle.Init.MediaInterface = ETH_MEDIA_INTERFACE_RMII; EthHandle.Init.RxMode = ETH_RXINTERRUPT_MODE; EthHandle.Init.ChecksumMode = ETH_CHECKSUM_BY_HARDWARE; EthHandle.Init.PhyAddress = LAN8742A_PHY_ADDRESS; /* configure ethernet peripheral (GPIOs, clocks, MAC, DMA) */ if (HAL_ETH_Init(&EthHandle) == HAL_OK) { STM32_ETH_PRINTF("init link up "); /* Set netif link flag */ //netif->flags |= NETIF_FLAG_LINK_UP; } /* Initialize Tx Descriptors list: Chain Mode */ HAL_ETH_DMATxDescListInit(&EthHandle, DMATxDscrTab, &Tx_Buff[0][0], ETH_TXBUFNB); /* Initialize Rx Descriptors list: Chain Mode */ HAL_ETH_DMARxDescListInit(&EthHandle, DMARxDscrTab, &Rx_Buff[0][0], ETH_RXBUFNB); /* Enable MAC and DMA transmission and reception */ HAL_ETH_Start(&EthHandle); return RT_EOK; } /* ethernet device interface */ /* transmit packet. */ rt_err_t rt_stm32_eth_tx( rt_device_t dev, struct pbuf* p) { err_t errval; struct pbuf *q; uint8_t *buffer = (uint8_t *)(EthHandle.TxDesc->Buffer1Addr); __IO ETH_DMADescTypeDef *DmaTxDesc; uint32_t framelength = 0; uint32_t bufferoffset = 0; uint32_t byteslefttocopy = 0; uint32_t payloadoffset = 0; DmaTxDesc = EthHandle.TxDesc; bufferoffset = 0; /* copy frame from pbufs to driver buffers */ for(q = p; q != NULL; q = q->next) { /* Is this buffer available? If not, goto error */ if((DmaTxDesc->Status & ETH_DMATXDESC_OWN) != (uint32_t)RESET) { errval = ERR_USE; goto error; } /* Get bytes in current lwIP buffer */ byteslefttocopy = q->len; payloadoffset = 0; /* Check if the length of data to copy is bigger than Tx buffer size*/ while( (byteslefttocopy + bufferoffset) > ETH_TX_BUF_SIZE ) { /* Copy data to Tx buffer*/ memcpy( (uint8_t*)((uint8_t*)buffer + bufferoffset), (uint8_t*)((uint8_t*)q->payload + payloadoffset), (ETH_TX_BUF_SIZE - bufferoffset) ); /* Point to next descriptor */ DmaTxDesc = (ETH_DMADescTypeDef *)(DmaTxDesc->Buffer2NextDescAddr); /* Check if the buffer is available */ if((DmaTxDesc->Status & ETH_DMATXDESC_OWN) != (uint32_t)RESET) { errval = ERR_USE; goto error; } buffer = (uint8_t *)(DmaTxDesc->Buffer1Addr); byteslefttocopy = byteslefttocopy - (ETH_TX_BUF_SIZE - bufferoffset); payloadoffset = payloadoffset + (ETH_TX_BUF_SIZE - bufferoffset); framelength = framelength + (ETH_TX_BUF_SIZE - bufferoffset); bufferoffset = 0; } /* Copy the remaining bytes */ memcpy( (uint8_t*)((uint8_t*)buffer + bufferoffset), (uint8_t*)((uint8_t*)q->payload + payloadoffset), byteslefttocopy ); bufferoffset = bufferoffset + byteslefttocopy; framelength = framelength + byteslefttocopy; } /* Prepare transmit descriptors to give to DMA */ HAL_ETH_TransmitFrame(&EthHandle, framelength); errval = ERR_OK; error: /* When Transmit Underflow flag is set, clear it and issue a Transmit Poll Demand to resume transmission */ if ((EthHandle.Instance->DMASR & ETH_DMASR_TUS) != (uint32_t)RESET) { /* Clear TUS ETHERNET DMA flag */ EthHandle.Instance->DMASR = ETH_DMASR_TUS; /* Resume DMA transmission*/ EthHandle.Instance->DMATPDR = 0; } return errval; } /* reception packet. */ struct pbuf *rt_stm32_eth_rx(rt_device_t dev) { struct pbuf *p = NULL, *q = NULL; uint16_t len = 0; uint8_t *buffer; __IO ETH_DMADescTypeDef *dmarxdesc; uint32_t bufferoffset = 0; uint32_t payloadoffset = 0; uint32_t byteslefttocopy = 0; uint32_t i=0; /* get received frame */ if (HAL_ETH_GetReceivedFrame_IT(&EthHandle) != HAL_OK) return NULL; /* Obtain the size of the packet and put it into the "len" variable. */ len = EthHandle.RxFrameInfos.length; buffer = (uint8_t *)EthHandle.RxFrameInfos.buffer; if (len > 0) { /* We allocate a pbuf chain of pbufs from the Lwip buffer pool */ p = pbuf_alloc(PBUF_RAW, len, PBUF_POOL); } if (p != NULL) { dmarxdesc = EthHandle.RxFrameInfos.FSRxDesc; bufferoffset = 0; for(q = p; q != NULL; q = q->next) { byteslefttocopy = q->len; payloadoffset = 0; /* Check if the length of bytes to copy in current pbuf is bigger than Rx buffer size */ while( (byteslefttocopy + bufferoffset) > ETH_RX_BUF_SIZE ) { /* Copy data to pbuf */ memcpy( (uint8_t*)((uint8_t*)q->payload + payloadoffset), (uint8_t*)((uint8_t*)buffer + bufferoffset), (ETH_RX_BUF_SIZE - bufferoffset)); /* Point to next descriptor */ dmarxdesc = (ETH_DMADescTypeDef *)(dmarxdesc->Buffer2NextDescAddr); buffer = (uint8_t *)(dmarxdesc->Buffer1Addr); byteslefttocopy = byteslefttocopy - (ETH_RX_BUF_SIZE - bufferoffset); payloadoffset = payloadoffset + (ETH_RX_BUF_SIZE - bufferoffset); bufferoffset = 0; } /* Copy remaining data in pbuf */ memcpy( (uint8_t*)((uint8_t*)q->payload + payloadoffset), (uint8_t*)((uint8_t*)buffer + bufferoffset), byteslefttocopy); bufferoffset = bufferoffset + byteslefttocopy; } } /* Release descriptors to DMA */ /* Point to first descriptor */ dmarxdesc = EthHandle.RxFrameInfos.FSRxDesc; /* Set Own bit in Rx descriptors: gives the buffers back to DMA */ for (i=0; i< EthHandle.RxFrameInfos.SegCount; i++) { dmarxdesc->Status |= ETH_DMARXDESC_OWN; dmarxdesc = (ETH_DMADescTypeDef *)(dmarxdesc->Buffer2NextDescAddr); } /* Clear Segment_Count */ EthHandle.RxFrameInfos.SegCount =0; /* When Rx Buffer unavailable flag is set: clear it and resume reception */ if ((EthHandle.Instance->DMASR & ETH_DMASR_RBUS) != (uint32_t)RESET) { /* Clear RBUS ETHERNET DMA flag */ EthHandle.Instance->DMASR = ETH_DMASR_RBUS; /* Resume DMA reception */ EthHandle.Instance->DMARPDR = 0; } return p; } int rt_hw_stm32_eth_init(void) { rt_err_t result = RT_EOK; /* PHY RESET: PC0 */ if (0) { GPIO_InitTypeDef GPIO_InitStruct; /* GPIO Ports Clock Enable */ __HAL_RCC_GPIOI_CLK_ENABLE(); /* Configure GPIO pin: PI1 (LD1) */ GPIO_InitStruct.Pin = GPIO_PIN_1; GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP; GPIO_InitStruct.Pull = GPIO_PULLDOWN; GPIO_InitStruct.Speed = GPIO_SPEED_LOW; HAL_GPIO_Init(GPIOI, &GPIO_InitStruct); HAL_GPIO_WritePin(GPIOI, GPIO_PIN_1, GPIO_PIN_RESET); rt_thread_delay(2); HAL_GPIO_WritePin(GPIOI, GPIO_PIN_1, GPIO_PIN_SET); rt_thread_delay(2); } GPIO_Configuration(); stm32_eth_device.ETH_Speed = ETH_SPEED_10M; stm32_eth_device.ETH_Mode = ETH_MODE_FULLDUPLEX; /* OUI 00-80-E1 STMICROELECTRONICS. */ stm32_eth_device.dev_addr[0] = 0x00; stm32_eth_device.dev_addr[1] = 0x80; stm32_eth_device.dev_addr[2] = 0xE1; /* generate MAC addr from 96bit unique ID (only for test). */ stm32_eth_device.dev_addr[3] = *(rt_uint8_t*)(0x1FF0F420 + 4); stm32_eth_device.dev_addr[4] = *(rt_uint8_t*)(0x1FF0F420 + 2); stm32_eth_device.dev_addr[5] = *(rt_uint8_t*)(0x1FF0F420 + 0); stm32_eth_device.parent.parent.init = rt_stm32_eth_init; stm32_eth_device.parent.parent.open = rt_stm32_eth_open; stm32_eth_device.parent.parent.close = rt_stm32_eth_close; stm32_eth_device.parent.parent.read = rt_stm32_eth_read; stm32_eth_device.parent.parent.write = rt_stm32_eth_write; stm32_eth_device.parent.parent.control = rt_stm32_eth_control; stm32_eth_device.parent.parent.user_data = RT_NULL; stm32_eth_device.parent.eth_rx = rt_stm32_eth_rx; stm32_eth_device.parent.eth_tx = rt_stm32_eth_tx; /* init tx semaphore */ rt_sem_init(&tx_wait, "tx_wait", 0, RT_IPC_FLAG_FIFO); /* register eth device */ eth_device_init(&(stm32_eth_device.parent), "e0"); /* start phy monitor */ if (1) { rt_thread_t tid; tid = rt_thread_create("phy", phy_monitor_thread_entry, RT_NULL, 512, RT_THREAD_PRIORITY_MAX - 2, 2); if (tid != RT_NULL) rt_thread_startup(tid); } return (int)result; } INIT_DEVICE_EXPORT(rt_hw_stm32_eth_init); ```
2016-07-07
在电脑端和板子上面网卡驱动中分别抓包对比。
wujialing3000
2016-07-07
其实我感觉应该是驱动的问题, struct pbuf *rt_stm32_eth_rx(rt_device_t dev) rt_err_t rt_stm32_eth_tx( rt_device_t dev, struct pbuf* p) 这两个函数实现是关键,这个两个函数取自于官方开发板里面。开发板是freertos+lwip
wujialing3000
2016-07-07
各位大神们帮帮忙吧。
zchong
2016-07-16
参考f2和f4的,以太网驱动应该是一样的
pangwei
2016-07-20
1 抓包分析,是否icmp校验和失败 2 debug是否进入接收网络接收中断
落叶有痕
2016-07-31
我也碰到了,我的是硬件校验和问题
wujialing3000
2016-08-04
>参考f2和f4的,以太网驱动应该是一样的 --- 不太一样吧。 >1 抓包分析,是否icmp校验和失败 > >2 debug是否进入接收网络接收中断 --- 可以进入中断,tcp都能建立连接,ping不通,发送数据不顺畅,很不容易才能发送到板子上。 >我也碰到了,我的是硬件校验和问题 --- 请问兄弟你怎么修改的?
wujialing3000
2016-08-04
现在这个驱动是从官方的freertos+lwip处移植过来的。官方这个可以正常使用,但是移植到rtt下就不能正常使用。
2016-08-04
F7是否要关心一下cache的问题?
wujialing3000
2016-08-05
>F7是否要关心一下cache的问题? --- 在这个地方应该不需要吧。这个驱动本身能够使用,但是偏偏移植到rtt上就不能使用,我想应该是移植的问题。
4.3k
wujialing3000
lwip1.4.1连接经常会断开无法连接上,可以ping通
求一些LWIP开发的经验,目前ping一直不稳定。
stm32f207+dp83848无法ping通
RTT下的LWIP传递机制
rtt内lwip的socket是否是线程安全?
Lwip+enc28j60无法ping通
坑爹的rtconfig.h lwip关掉了checksum
rt-thread 挂载romfs与ramfs
smart启动流程详解
小内存管理(1)--- 内存初始化
spi自动初始化程序
zhuzhuzhu
YDPB_5935
