SPI Bus 注册完之后,take_bus或者configure都会报错
发布于 2019-11-30 23:07:36 浏览:2038
代码如下: ```c /*-------------------------函数实现-------------------------*/ void rt_app_tcpip_client_thread_entry(void* parameter) { rt_err_t result; //-------------------------查找SPI1设备是否成功注册---------------------- spi_device = (struct rt_spi_device *)rt_device_find("spi1"); if (spi_device == RT_NULL) { rt_kprintf("spi device spi1 not found!
"); } else { rt_kprintf("spi device spi1 found!
"); } result=rt_spi_take_bus(spi_device); if(result==RT_EOK) { rt_kprintf("rt_spi_take_bus OK !
"); } else { rt_kprintf("rt_spi_take_bus ERROR !
"); } //-------------------------将W5500挂载到SPI1总线上---------------------- result=stm32_spi_bus_attach_device(W5500_SCSn,"spi1","spi10"); if(result==RT_EOK) { rt_kprintf("attach W5500_SCSn to SPI1 OK !
"); } else { rt_kprintf("attach W5500_SCSn to SPI1 ERROR !
"); } //-------------------------配置SPI1总线的传输参数----------------------- cfg.data_width = 8; cfg.mode = RT_SPI_MASTER | RT_SPI_MODE_0 | RT_SPI_MSB; /* SPI Compatible Modes 0 */ cfg.max_hz = 20 * 1000 * 1000; /* SPI Interface with Clock Speeds Up to 20 MHz */ rt_spi_configure(spi_device, &cfg); } ``` 不论是rt_spi_take_bus还是rt_spi_configure都会在获取互斥量的时候报错,具体错误如下: ``` (rt_object_get_type(&mutex->parent.parent) == RT_Object_Class_Mutex) assertion failed at function:rt_mutex_take, line number:6 ``` 纠结了一晚上,没找出原因。各位大佬帮帮忙吧,谢谢啦!
BaiJinHui
2019-11-30
好像找到问题了,刚开始注册的只是SPI总线,后面需要先挂载W5500设备,然后查找也是查找W5500设备,后面的操作也应该是针对W5500设备进行的。
james_s
2021-04-14
rt_spi_take_bus参数是device不是bus
2k
BaiJinHui
BBB的SPI驱动
求个SPI上挂两个或多个设备的使用例子
SPI设备有个bug
SPI驱动
请教rt_spi_configure函数理解
SPI FLASH挂载的问题
SPI-FLASH 文件系统 SPIFFS
求助一个完整的 spi flash 驱动
关于同时使用文件系统与SPI FLASH的问题
cJSON 避坑笔记
Vision-Board porting Xbox One USB Controller
可存万物的bsp_flash
TIM,硬件定时器驱动程序
LCD(mipi)+LVGL +gui(适配V8.x版本)
1506
339
1423
281
740
161
539
157
1218
146
