仿真
RT Studio 仿真,文件系统挂载不了
发布于 2021-08-11 09:34:11 浏览:1696
各位大神,使用stm32f429-fire-challenger仿真,运行时spi设备挂载不了,这是什么原因。     ``` D:\RT-ThreadStudio\workspace\rt-fire>D:/RT-ThreadStudio/repo/Extract/Debugger_Support_Packages/RealThread/QEMU/4.2.0.4/qemu-system-arm.exe -M stm32f429-fire-challenger -sd sd.bin -nographic --kernel Debug/r tthread.bin -serial stdio -monitor null -show-cursor WARNING: Image format was not specified for 'sd.bin' and probing guessed raw. Automatically detecting the format is dangerous for raw images, write operations on block 0 will be restricted. Specify the 'raw' format explicitly to remove the restrictions. [D/drv.sdram] sdram init success, mapped at 0xD0000000, size is 8388608 bytes, data width is 16 \ | / - RT - Thread Operating System / | \ 4.0.4 build Aug 11 2021 2006 - 2021 Copyright by rt-thread team lwIP-2.0.3 initialized! [I/sal.skt] Socket Abstraction Layer initialize success. [D/SFUD] (../rt-thread/components/drivers/spi/sfud/src/sfud.c:862) The flash device manufacturer ID is 0x00, memory type ID is 0x00, ca [D/SFUD] (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:122) Error: Check SFDP signature error. It's must be 50444653h('S' ' [I/SFUD] Warning: Read SFDP parameter header information failed. The W25Q128 is not support JEDEC SFDP. [I/SFUD] Warning: This flash device is not found or not support. [I/SFUD] Error: W25Q128 flash device is initialize fail. [E/SFUD] ERROR: SPI flash probe failed by SPI device spi50. msh /> msh />list_device device type ref count -------- -------------------- ---------- spi50 SPI Device 0 e0 Network Interface 0 spi5 SPI Bus 0 uart1 Character Device 2 pin Miscellaneous Device 0 ```
zhkag
2021-08-11
感觉大概率是时间的问题,仿真启动时间和实际运行时间相比太长了,可能就会导致某些设备启动不了
2021-08-11
``` [D/SFUD] (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:122) Error: Check SFDP signature error. It's must be 50444653h('S' ' [I/SFUD] Warning: Read SFDP parameter header information failed. The W25Q128 is not support JEDEC SFDP. ``` 第一行错误信息,读 flash 的sfdp 出错了。要么是 spi 没配置好,要么是 flash 不支持 sfdp 。 1. 检查 msp 里spi 引脚配置是否正确。 2. 取消 sfud 的 SFUD_USING_SFDP 这个宏配置,跳过读取 sfdp 头的过程。
liuduanfei
2021-08-11
首先确定是不是支持W25Q128
1.7k
tenda
BBB的SPI驱动
求个SPI上挂两个或多个设备的使用例子
SPI设备有个bug
SPI驱动
请教rt_spi_configure函数理解
SPI FLASH挂载的问题
SPI-FLASH 文件系统 SPIFFS
求助一个完整的 spi flash 驱动
关于同时使用文件系统与SPI FLASH的问题
STM32内存扩展,SRAM-RMC
新版OneNet的星火1号开发板例程适配(下)
tjrong
yans
alight
Pai同学
Rick98
WenShan
