Filesystem
关于STM32F407ZG 使用W25Q128B文件系统问题
发布于 2017-12-29 10:35:53 浏览:7928
说明:使用原子STM32F407开发板,基于STM32F407 HAL工程开发,在提问题时顺道到使用menuconfig及相关步骤和大家分享一下,高手指正,没用过的借鉴 1. 工程配置 a. 起动env工具的console.bat,进入工程目录cd E:\STM32 t-thread\bsp\stm32f4xx-HAL,输入menuconfig进步配置界面 b.配置界面修改项: 主界面起用UART1,SPI1 (75)W25QXX CS Pin index (对应PB14) (spi1)W25QXX Spi bus name kernel->kernel Device Object->uart2 改为 uart1 Componets->Device virtual file system起用 Componets->Device virtual file system->elm-chan fafs->xxxxxxxx_Module-> (4096)Maximum sector size.......... Device type (STM32F407ZG) SAVE Exit 2. 生成MDK工程 命令行进去工程目录:scons --target=mdk5 -s 3.MDK IDE工具配置 打开MDK工程,默认芯片为401,修改芯片为对应型号 4.代码修改 修改Drivers下的drv_spi.c if(spiHandle->Instance==SPI1) { /* SPI1 clock enable */ __HAL_RCC_SPI1_CLK_ENABLE(); __HAL_RCC_GPIOB_CLK_ENABLE(); /**SPI1 GPIO Configuration PB3 ------> SPI1_SCK PB4 ------> SPI1_MISO PB5 ------> SPI1_MOSI */ GPIO_InitStruct.Pin = GPIO_PIN_3|GPIO_PIN_4|GPIO_PIN_5; GPIO_InitStruct.Mode = GPIO_MODE_AF_PP; GPIO_InitStruct.Pull = GPIO_NOPULL; GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH; GPIO_InitStruct.Alternate = GPIO_AF5_SPI1; HAL_GPIO_Init(GPIOB, &GPIO_InitStruct); } HAL_GPIO_DeInit(GPIOB, GPIO_PIN_3|GPIO_PIN_4|GPIO_PIN_5); 5. 编译下载 当前问题: \ | / - RT - Thread Operating System / | \ 3.0.1 build Dec 29 2017 2006 - 2017 Copyright by rt-thread team W25Q128BV detection msh />mkfs -t elm flash0 \ | / - RT - Thread Operating System / | \ 3.0.1 build Dec 29 2017 2006 - 2017 Copyright by rt-thread team W25Q128BV detection msh />mkfs -t elm flash0 psr: 0x01000000 pc: 0x08016fbc lr: 0x0800c49b r12: 0x0000000a r03: 0x200035d7 r02: 0x00000000 r01: 0x00000000 r00: 0x00000011 hard fault on thread: tshell thread pri status sp stack size max used left tick error ------ --- ------- ---------- ---------- ------ ---------- --- tshell 20 ready 0x00000088 0x00001000 10% 0x00000009 000 tidle 31 ready 0x00000054 0x00000200 16% 0x00000018 000 可以识别Flash形号,但mount不成功,用mkfs 格式化就出错,请高手指点
43
bigfanofRTOS
2017-12-29
有啥好写的,一边凉快去!
开启sfud驱动,把spi驱动加进来,再把drv_spiflash.c加进来就可以了
bigfanofRTOS
2017-12-29
有啥好写的,一边凉快去!
不建议使用w25q128那个驱动,使用sfud更好
mcubuilder
2017-12-29
>开启sfud驱动,把spi驱动加进来,再把drv_spiflash.c加进来就可以了 --- 我试试,把结果更新给大家
bigfanofRTOS
2017-12-29
有啥好写的,一边凉快去!
[attach]2946[/attach] [attach]2947[/attach] [attach]2948[/attach] elm会在components中初始化,不需要手动调用: [attach]2949[/attach] 如果挂载失败,使用mkfs命令格式化下文件系统,确保有block device [attach]2950[/attach]
bigfanofRTOS
2017-12-29
有啥好写的,一边凉快去!
我正好使用的是正点原子的stm32f407板子测试的,下面是3个驱动: [attach]2951[/attach] [attach]2952[/attach] [attach]2953[/attach]
mcubuilder
2017-12-29
>我正好使用的是正点原子的stm32f407板子测试的,下面是3个驱动: --- 我用的是3.01 dfs_init elm_init 在组件里已经初始化了,我在这里应该挂载就行了,我全用了你的驱动,也起用了SFUD,还是涛声依旧:'(,还有可能那时不对;这和我刚才直接用W25Q128驱动一样;就是挂载不了 [attach]2958[/attach] [attach]2959[/attach]
bigfanofRTOS
2017-12-29
有啥好写的,一边凉快去!
>我用的是3.01 >dfs_init >elm_init --- **如果挂载失败,使用mkfs命令格式化下文件系统,然后复位**
mcubuilder
2017-12-29
>如果挂载失败,使用mkfs命令格式化下文件系统,然后复位 --- [attach]2960[/attach] 一格式化就报错
mcubuilder
2017-12-29
>如果挂载失败,使用mkfs命令格式化下文件系统,然后复位 --- 应该还是SFUD这块没搞对 用sf 命令识别不了设备 msh />list_device device type ref count ------- -------------------- ---------- W25Q128 Block Device 0 spi10 SPI Device 0 spi1 SPI Bus 0 uart1 Character Device 2 pin Miscellaneous Device 0 msh />sf probe W25Q128 ERROR: SPI device W25Q128 not found! msh />
mcubuilder
2017-12-29
SFUD是对的应该用设备名spi10,这样可以读可以写 msh />sf probe spi10 [SFUD]Find a Winbond flash chip. Size is 16777216 bytes. [SFUD]sf_cmd flash device is initialize success. 16 MB sf_cmd is current selected device. msh />sf read 0 64 Read the sf_cmd flash data success. Start from 0x00000000, size is 64. The data is: Offset (h) 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F [00000000] EB FE 90 4D 53 44 4F 53 35 2E 30 00 02 08 01 00 [00000010] 01 00 02 00 60 F0 0A 00 3F 00 FF 00 00 00 00 00 [00000020] 00 00 00 00 80 00 29 00 00 A6 44 4E 4F 20 4E 41 [00000030] 4D 45 20 20 20 20 46 41 54 20 20 20 20 20 00 00
7.9k
mcubuilder
24
65
字库除了SD卡和http还有别的方式导入吗
EasyFlash好棒
SD卡挂在的SPI总线又要加个DA设备
请教ramfs使用方法
rtt stable2.0.x版本 sd卡及文件系统
nandflash文件系统UFFS请教
关于SD卡挂载文件系统的问题(已解决)
Yaffs采用GPL2许可
Vision-Board porting Xbox One USB Controller
可存万物的bsp_flash
TIM,硬件定时器驱动程序
LCD(mipi)+LVGL +gui(适配V8.x版本)
上海找工作的小伙伴们,私聊
1506
339
1423
281
740
161
539
157
1218
146
