micropython导入uart出现大的问题
发布于 2021-11-15 23:35:58 浏览:1445
``` packages\micropython-v1.12.0\port\modules\machine\machine_uart.c: In function 'machine_uart_print': packages\micropython-v1.12.0\port\modules\machine\machine_uart.c:52:30: error: dereferencing pointer to incomplete type 'struct rt_serial_device' self->uart_device->parent.parent.name, ^ packages\micropython-v1.12.0\port\modules\machine\machine_uart.c: In function 'machine_uart_init_helper': packages\micropython-v1.12.0\port\modules\machine\machine_uart.c:119:12: error: variable 'config' has initializer but incomplete type struct serial_configure config = RT_SERIAL_CONFIG_DEFAULT; ^ packages\micropython-v1.12.0\port\modules\machine\machine_uart.c:119:38: error: 'RT_SERIAL_CONFIG_DEFAULT' undeclared (first use in this function) struct serial_configure config = RT_SERIAL_CONFIG_DEFAULT; ^ packages\micropython-v1.12.0\port\modules\machine\machine_uart.c:119:38: note: each undeclared identifier is reported only once for each function it appears in packages\micropython-v1.12.0\port\modules\machine\machine_uart.c:119:29: error: storage size of 'config' isn't known struct serial_configure config = RT_SERIAL_CONFIG_DEFAULT; ^ packages\micropython-v1.12.0\port\modules\machine\machine_uart.c:127:25: error: 'PARITY_NONE' undeclared (first use in this function) config.parity = PARITY_NONE; ^ packages\micropython-v1.12.0\port\modules\machine\machine_uart.c:130:40: error: 'PARITY_ODD' undeclared (first use in this function) config.parity = (parity & 1) ? PARITY_ODD : PARITY_EVEN; ^ packages\micropython-v1.12.0\port\modules\machine\machine_uart.c:130:53: error: 'PARITY_EVEN' undeclared (first use in this function) config.parity = (parity & 1) ? PARITY_ODD : PARITY_EVEN; ^ packages\micropython-v1.12.0\port\modules\machine\machine_uart.c:136:28: error: 'DATA_BITS_8' undeclared (first use in this function) config.data_bits = DATA_BITS_8; ^ packages\micropython-v1.12.0\port\modules\machine\machine_uart.c:138:28: error: 'DATA_BITS_9' undeclared (first use in this function) config.data_bits = DATA_BITS_9; ^ packages\micropython-v1.12.0\port\modules\machine\machine_uart.c:140:28: error: 'DATA_BITS_7' undeclared (first use in this function) config.data_bits = DATA_BITS_7; ^ packages\micropython-v1.12.0\port\modules\machine\machine_uart.c:147:36: error: 'STOP_BITS_1' undeclared (first use in this function) case 1: config.stop_bits = STOP_BITS_1; break; ^ packages\micropython-v1.12.0\port\modules\machine\machine_uart.c:148:37: error: 'STOP_BITS_2' undeclared (first use in this function) default: config.stop_bits = STOP_BITS_2; break; ^ packages\micropython-v1.12.0\port\modules\machine\machine_uart.c: In function 'machine_uart_ioctl': packages\micropython-v1.12.0\port\modules\machine\machine_uart.c:247:12: warning: return makes integer from pointer without a cast [-Wint-conversion] return NULL; ^ CC build\packages\micropython-v1.12.0\port\modules\modfile.o scons: *** [build\packages\micropython-v1.12.0\port\modules\machine\machine_uart.o] Error 1 scons: building terminated because of errors. ``` 请问谁知道如何解决??
2021-11-16
@jevian 请用最新的latest版本
2021-11-16
1. 启用串口设备 2. 选择串口端口 3. 添加串口引脚复用配置代码
1.4k
jevian
rt thread 2.0.2 usart 接收缓存问题
关于STM32串口通信的问题
STM32F1+RTT串口接收终端数据丢失问题
UART TX丢数据?
RTT打开串口的时候如何自定义波特率呢?
STM32F4的USART数据接收问题
串口1234使用问题
串口接收回调函数
LPC18xx UART问题讨论
x1000串口配置的失败问题
STM32内存扩展,SRAM-RMC
