串口1234使用问题
发布于 2017-04-17 10:42:17 浏览:4622
使用的是RTT 2.1.0,开启了4个串口。串口1,2 3都是接设备,调试发现,串口在线程中初始化后,发送时,第一个字节掉了,用串口助手看第一个字节没有收到,后面都是正常 的,请问下为什么。 用的命令和MODBUS上面修改的。 ``` /* ----------------------- Start implementation -----------------------------*/ BOOL xMBPortSerialInit(UCHAR ucPORT, ULONG ulBaudRate, UCHAR ucDataBits, eMBParity eParity) { /** * set 485 mode receive and transmit control IO * @note MODBUS_SLAVE_RT_CONTROL_PIN_INDEX need be defined by user */ rt_pin_mode(MODBUS_SLAVE_RT_CONTROL_PIN_INDEX, PIN_MODE_OUTPUT); /* set serial name */ if (ucPORT == 1) { #if defined(RT_USING_UART1) || defined(RT_USING_REMAP_UART1) extern struct rt_serial_device serial1; serial = &serial1; #endif } else if (ucPORT == 2) { #if defined(RT_USING_UART2) extern struct rt_serial_device serial2; serial = &serial2; #endif } else if (ucPORT == 3) { #if defined(RT_USING_UART3) extern struct rt_serial_device serial3; serial = &serial3; #endif } /* set serial configure parameter */ serial->config.baud_rate = ulBaudRate; serial->config.stop_bits = STOP_BITS_1; switch(eParity){ case MB_PAR_NONE: { serial->config.data_bits = DATA_BITS_8; serial->config.parity = PARITY_NONE; break; } case MB_PAR_ODD: { serial->config.data_bits = DATA_BITS_9; serial->config.parity = PARITY_ODD; break; } case MB_PAR_EVEN: { serial->config.data_bits = DATA_BITS_9; serial->config.parity = PARITY_EVEN; break; } } /* set serial configure */ serial->ops->configure(serial, &(serial->config)); /* open serial device */ if (!serial->parent.open(&serial->parent, RT_DEVICE_OFLAG_RDWR | RT_DEVICE_FLAG_INT_RX )) { serial->parent.rx_indicate = serial_rx_ind; } else { return FALSE; } /* software initialize */ rt_thread_init(&thread_serial_soft_trans_irq, "slave trans", serial_soft_trans_irq, RT_NULL, serial_soft_trans_irq_stack, sizeof(serial_soft_trans_irq_stack), 10, 5); rt_thread_startup(&thread_serial_soft_trans_irq); rt_event_init(&event_serial, "slave event", RT_IPC_FLAG_PRIO); return TRUE; } ``` 在这个基础上修改的。 发送和读是这么写的 serial->parent.write(&(serial->parent), 0, &ucByte, len); serial->parent.read(&(serial->parent), 0, pucByte, len); 现在就是第一个字符收不到,搞的我读取配置有时不正常,要读多次。后面都正常,就开机第一个字符没了。
2017-04-17
和你用的芯片,bsp相关的
swcy225@163.com
2017-04-17
芯片是STM23F103,
Aubr.Cool
2017-04-17
你是用一个串口发,3个收,然后串口调试助手看,第一个发的发出来了,然后收不到吗?
qq_臭小孩
2017-05-05
是怎么同时使用多个串口的,我现在使用一个串口可以,使用多个串口所有串口就都不能用了
lihuiseng
2017-08-13
usart.c -> stm32_putc() -> while (!(uart->uart_device->SR & USART_FLAG_TC)); 判断USART_FLAG_TC是会丢失第一字节的 改成判断USART_FLAG_TXE似乎可以解决
swcy225@163.com
2017-08-28
初始化完了,读下状态寄电器就好了
pan16309
2017-08-28
我的用法是照着系统默认的配置再添加几个,用的时候挂到线程的设备上使用。所有串口挂到console上的时候都很正常,不过挂到device上接收数据总是会异常,好尴尬
4.6k
swcy225@163.com
rt thread 2.0.2 usart 接收缓存问题
关于STM32串口通信的问题
STM32F1+RTT串口接收终端数据丢失问题
UART TX丢数据?
RTT打开串口的时候如何自定义波特率呢?
STM32F4的USART数据接收问题
串口接收回调函数
LPC18xx UART问题讨论
x1000串口配置的失败问题
如何用串口输出一个字符
【最新活动】RT-Thread论坛活动正在进行(2026年5月活动已更新)
8月27日上海 | 睿擎工业平台Workshop:EtherCAT实时控制与工业方案实战
【RSOC26】第二天学习记录:内核与多线程培训
【RSOC26】从启动流程到多线程:RT-Thread 内核学习笔记
【RSOC26】第二天学习记录:RT-Thread 启动流程与多线程编程
【RSOC26】内核与多线程
QEMU
CYFS
王棒棒
wdfk_prog
Ewan11111
徐VV
金阳阳
longtsing
RTT_Studio
