ADC设备
ADC采集电压,读取到的数据总是出错,不就是满量程3.29,不就是1.65,就两个值不断地跳变,反正不正常,求助大佬帮助!!!
发布于 2024-04-10 10:01:33 浏览:522
cubmx配置的也没啥问题,就配置了5通道,生成的代码复制到了board.c里面了,就是读取到的数据有问题,太奇怪了,rtthread也打开了adc组件 ```c /* * Copyright (c) 2006-2021, RT-Thread Development Team * * SPDX-License-Identifier: Apache-2.0 * * Change Logs: * Date Author Notes * 2024-03-27 EE the first version */ #include
rt_adc_device_t adc_dev,adc_2; #define ADC_DEV_NAME "adc1" /* ADC 设 备 名 称 */ #define ADC_DEV_CHANNEL 5 /* ADC 通 道 */ #define REFER_VOLTAGE 330 /* 参 考 电 压 3.3V,数 据 精 度 乘 以100保 留2位 小 数 */ #define CONVERT_BITS (1 << 12) /* 转 换 位 数 为12位 */ int adc_vol_sample(void) { rt_uint32_t value, vol; /* 查 找 设 备 */ adc_dev = (rt_adc_device_t)rt_device_find("adc1"); adc_2 = (rt_adc_device_t)rt_device_find("adc2"); if (adc_dev == RT_NULL) { rt_kprintf("adc sample run failed! can't find %s device!\n", ADC_DEV_NAME); return RT_ERROR; } if (adc_2 == RT_NULL) { rt_kprintf("adc2 sample run failed! can't find %s device!\n", ADC_DEV_NAME); return RT_ERROR; } rt_adc_enable(adc_dev, ADC_DEV_CHANNEL); rt_adc_enable(adc_2, 1); // value = rt_adc_read(adc_dev, ADC_DEV_CHANNEL); // rt_kprintf("the value is :%d \n", value); /* 转 换 为 对 应 电 压 值 */ // vol = value * REFER_VOLTAGE / CONVERT_BITS; // rt_kprintf("the adc1 is :%d.%02d \n", vol / 100, vol % 100); // value = rt_adc_read(adc_2, 1); // rt_kprintf("the value is :%d \n", value); /* 转 换 为 对 应 电 压 值 */ // vol = value * REFER_VOLTAGE / CONVERT_BITS; // rt_kprintf("the adc2 is :%d.%02d \n", vol / 100, vol % 100); return RT_EOK; } static int adc_sample(void) { rt_uint32_t value, vol; /* 查 找 设 备 */ adc_dev = (rt_adc_device_t)rt_device_find(ADC_DEV_NAME); if (adc_dev == RT_NULL) { rt_kprintf("adc sample run failed! can't find %s device!\n", ADC_DEV_NAME); return RT_ERROR; } /* 使 能 设 备 */ rt_adc_enable(adc_dev, ADC_DEV_CHANNEL); /* 读 取 采 样 值 */ value = rt_adc_read(adc_dev, ADC_DEV_CHANNEL); rt_kprintf("the value is :%d \n", value); /* 转 换 为 对 应 电 压 值 */ vol = value * REFER_VOLTAGE / CONVERT_BITS; rt_kprintf("the voltage is :%d.%02d \n", vol / 100, vol % 100); return RT_EOK; }/* 导 出 到 msh 命 令 列 表 中 */ MSH_CMD_EXPORT(adc_sample, adc_sample); ```  上述图片,一个adc1 PA0接到了1.4v的电压,adc2 PC0接到了地,为什么他们显示一样都是错误的3.29v,按理来说,我的电压不断调整不应该模拟量也在随时变化吗,我的历程他不变化,都是跳变,而且3.29和1.65和0来回跳变.。。。。。。。
2024-04-10
感觉像是配置的问题,哪里不对
wzh2024
2024-04-10
直接用cubemx代码试下,排除板子问题
2024-04-10
按官方文档例程的流程来,依次调用 rt_adc_enable rt_adc_read rt_adc_disable
522
dsfghjkl
adc设备不能打开。。。。。
ADC 设备名称是怎么确定的
stm32g0 设备驱动框架 wdt adc 报错
ADC设备只能采集一个通道值?
rtthread studio adc三通道采集ntc电阻出现问题
ADC复制的void HAL_ADC_MspInit编译错误
双通道ADC采集问题
多通道ADC读取出现问题
ADC 总线打不开 控制台没有ADC总线
rt_adc_voltage 使用问题
新版OneNet的星火1号开发板例程适配(下)
重磅预售!RT-Trace调试工具
yans
tjrong
miandian_7
Pai同学
Rick98
河南理工大学恁带劲儿
