rt-thread studio 启动错误
发布于 2022-02-26 09:24:45 浏览:649
 rt-thread 启动报错是什么原因,重新安装也一样
2022-02-26
把日志文件传上来看看呢
rcp
2022-02-26
日志文件在安装目录下 workspace / .metadata 下的 .log 文件
kun222
2022-02-26
rtt
``` !SESSION 2022-01-14 11:08:45.125 ----------------------------------------------- eclipse.buildId=unknown java.version=1.8.0_144 java.vendor=Oracle Corporation BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=zh_CN Command-line arguments: -os win32 -ws win32 -arch x86_64 !ENTRY org.eclipse.ui 2 0 2022-01-14 11:08:49.976 !MESSAGE Warnings while parsing the images from the 'org.eclipse.ui.commandImages' extension point. !SUBENTRY 1 org.eclipse.ui 2 0 2022-01-14 11:08:49.976 !MESSAGE Cannot bind to an undefined command: plug-in='com.genuitec.eclipse.theming.ui', id='com.genuitec.myeclipse.help.darktheme.commandid' !ENTRY org.eclipse.ui 4 4 2022-01-14 11:08:52.657 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.Rename !ENTRY org.eclipse.ui 4 4 2022-01-14 11:08:52.659 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.HideMethod !ENTRY org.eclipse.ui 4 4 2022-01-14 11:08:52.660 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.ToggleFunction !ENTRY org.eclipse.ui 4 4 2022-01-14 11:08:52.661 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.ExtractMethod !ENTRY org.eclipse.ui 4 4 2022-01-14 11:08:52.662 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.ExtractConstant !ENTRY org.eclipse.ui 4 4 2022-01-14 11:08:52.663 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.ExtractLocalVariable !ENTRY org.eclipse.ui 4 4 2022-01-14 11:08:52.664 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.RefactoringHistory !ENTRY org.eclipse.ui 4 4 2022-01-14 11:08:52.665 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.createRefactoringScript !ENTRY org.eclipse.ui 4 4 2022-01-14 11:08:52.666 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.applyRefactoringScript !ENTRY org.eclipse.ui 4 4 2022-01-14 11:08:52.741 !MESSAGE Plugin 'org.eclipse.search' invalid Menu Extension (Path 'org.eclipse.search.menu' is invalid): textSearchSubMenu !ENTRY org.eclipse.ui 4 4 2022-01-14 11:08:52.742 !MESSAGE Plug-in 'org.eclipse.search' contributed an invalid Menu Extension (Path: 'org.eclipse.search.menu' is invalid): org.eclipse.search.OpenFileSearchPage !ENTRY org.eclipse.ui 4 4 2022-01-14 11:08:52.764 !MESSAGE Plug-in 'org.eclipse.search' contributed an invalid Menu Extension (Path: 'org.eclipse.search.menu' is invalid): org.eclipse.search.OpenSearchDialog !ENTRY org.eclipse.ui 4 4 2022-01-14 11:08:52.779 !MESSAGE Plug-in 'org.eclipse.search' contributed an invalid Menu Extension (Path: 'org.eclipse.search.menu/textSearchSubMenu' is invalid): org.eclipse.search.TextSearchWorkingSet !ENTRY org.eclipse.ui 4 4 2022-01-14 11:08:52.780 !MESSAGE Plug-in 'org.eclipse.search' contributed an invalid Menu Extension (Path: 'org.eclipse.search.menu/textSearchSubMenu' is invalid): org.eclipse.search.TextSearchFile !ENTRY org.eclipse.ui 4 4 2022-01-14 11:08:52.781 !MESSAGE Plug-in 'org.eclipse.search' contributed an invalid Menu Extension (Path: 'org.eclipse.search.menu/textSearchSubMenu' is invalid): org.eclipse.search.TextSearchProject !ENTRY org.eclipse.ui 4 4 2022-01-14 11:08:52.782 !MESSAGE Plug-in 'org.eclipse.search' contributed an invalid Menu Extension (Path: 'org.eclipse.search.menu/textSearchSubMenu' is invalid): org.eclipse.search.TextSearchWorkspace !ENTRY org.eclipse.egit.ui 2 0 2022-01-14 11:09:16.844 !MESSAGE Warning: The environment variable HOME is not set. The following directory will be used to store the Git user global configuration and to define the default location to store repositories: 'C:\Users\Administrator'. If this is not correct please set the HOME environment variable and restart Eclipse. Otherwise Git for Windows and EGit might behave differently since they see different configuration options. This warning can be switched off on the Team > Git > Confirmations and Warnings preference page. !ENTRY org.eclipse.launchbar.core 2 0 2022-01-14 11:09:17.032 !MESSAGE Enablement expression is missing for descriptor type org.eclipse.cdt.debug.core.coreBuildDescriptorType !ENTRY org.eclipse.launchbar.core 2 0 2022-01-14 11:09:17.035 !MESSAGE Enablement expression is missing for config provider for org.eclipse.cdt.debug.core.coreBuildDescriptorType !ENTRY org.eclipse.launchbar.core 2 0 2022-01-14 11:09:17.036 !MESSAGE Enablement expression is missing for config provider for org.eclipse.cdt.debug.core.coreBuildDescriptorType !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:10:55.173 !MESSAGE D:\RT-ThreadStudio>cd /d D:/RT-ThreadStudio/plugins/org.rt-thread.studio.project.gener_1.0.30/gener !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:10:55.174 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\gener>set RTT_ROOT= !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:10:55.175 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\gener>set ENV_ROOT=D:/RT-ThreadStudio/platform/env_released/env !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:10:55.176 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\gener>set RTT_EXEC_PATH=D:/RT-ThreadStudio/repo/Extract/ToolChain_Support_Packages/ARM/GNU_Tools_for_ARM_Embedded_Processors/5.4.1/bin !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:10:55.177 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\gener>set KCONF_EXEC_PATH=D:/RT-ThreadStudio/platform/env_released/env\tools\exec !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:10:55.178 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\gener>set RTT_CC=gcc !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:10:55.179 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\gener>set SCONS=D:/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:10:55.179 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\gener>set PKGS_ROOT=D:/RT-ThreadStudio/platform/env_released/env\packages !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:10:55.180 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\gener>set PATH=D:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;D:\Program Files (x86)\NetSarang\Xshell 7\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files (x86)\Windows Kits\10\Windows Performance Toolkit\;C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;D:\Program Files\VisualSVN Server\bin;D:\Program Files\TortoiseSVN\bin;d:\Program Files\Git\cmd;D:\Program Files\Microsoft VS Code\bin;C:\Users\Administrator\AppData\Local\Programs\Python\Python39\Scripts\;C:\Users\Administrator\AppData\Local\Programs\Python\Python39\;C:\Users\Administrator\AppData\Local\Microsoft\WindowsApps;D:\Program Files\JetBrains\IntelliJ IDEA 2021.1.2\bin;D:\Users\Administrator\AppData\Local\Programs\Microsoft VS Code\bin;C:\Users\Administrator\AppData\Local\GitHubDesktop\bin;D:\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:10:55.181 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\gener>set PATH=D:/RT-ThreadStudio/platform/env_released/env\tools\Python27;D:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;D:\Program Files (x86)\NetSarang\Xshell 7\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files (x86)\Windows Kits\10\Windows Performance Toolkit\;C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;D:\Program Files\VisualSVN Server\bin;D:\Program Files\TortoiseSVN\bin;d:\Program Files\Git\cmd;D:\Program Files\Microsoft VS Code\bin;C:\Users\Administrator\AppData\Local\Programs\Python\Python39\Scripts\;C:\Users\Administrator\AppData\Local\Programs\Python\Python39\;C:\Users\Administrator\AppData\Local\Microsoft\WindowsApps;D:\Program Files\JetBrains\IntelliJ IDEA 2021.1.2\bin;D:\Users\Administrator\AppData\Local\Programs\Microsoft VS Code\bin;C:\Users\Administrator\AppData\Local\GitHubDesktop\bin;D:\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:10:55.182 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\gener>set PATH=D:/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;D:/RT-ThreadStudio/platform/env_released/env\tools\Python27;D:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;D:\Program Files (x86)\NetSarang\Xshell 7\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files (x86)\Windows Kits\10\Windows Performance Toolkit\;C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;D:\Program Files\VisualSVN Server\bin;D:\Program Files\TortoiseSVN\bin;d:\Program Files\Git\cmd;D:\Program Files\Microsoft VS Code\bin;C:\Users\Administrator\AppData\Local\Programs\Python\Python39\Scripts\;C:\Users\Administrator\AppData\Local\Programs\Python\Python39\;C:\Users\Administrator\AppData\Local\Microsoft\WindowsApps;D:\Program Files\JetBrains\IntelliJ IDEA 2021.1.2\bin;D:\Users\Administrator\AppData\Local\Programs\Microsoft VS Code\bin;C:\Users\Administrator\AppData\Local\GitHubDesktop\bin;D:\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:10:55.183 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\gener>set PATH=D:/RT-ThreadStudio/platform/env_released/env\tools\bin;D:/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;D:/RT-ThreadStudio/platform/env_released/env\tools\Python27;D:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;D:\Program Files (x86)\NetSarang\Xshell 7\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files (x86)\Windows Kits\10\Windows Performance Toolkit\;C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;D:\Program Files\VisualSVN Server\bin;D:\Program Files\TortoiseSVN\bin;d:\Program Files\Git\cmd;D:\Program Files\Microsoft VS Code\bin;C:\Users\Administrator\AppData\Local\Programs\Python\Python39\Scripts\;C:\Users\Administrator\AppData\Local\Programs\Python\Python39\;C:\Users\Administrator\AppData\Local\Microsoft\WindowsApps;D:\Program Files\JetBrains\IntelliJ IDEA 2021.1.2\bin;D:\Users\Administrator\AppData\Local\Programs\Microsoft VS Code\bin;C:\Users\Administrator\AppData\Local\GitHubDesktop\bin;D:\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:10:55.184 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\gener>set PATH=D:/RT-ThreadStudio/repo/Extract/ToolChain_Support_Packages/ARM/GNU_Tools_for_ARM_Embedded_Processors/5.4.1/bin;D:/RT-ThreadStudio/platform/env_released/env\tools\bin;D:/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;D:/RT-ThreadStudio/platform/env_released/env\tools\Python27;D:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;D:\Program Files (x86)\NetSarang\Xshell 7\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files (x86)\Windows Kits\10\Windows Performance Toolkit\;C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;D:\Program Files\VisualSVN Server\bin;D:\Program Files\TortoiseSVN\bin;d:\Program Files\Git\cmd;D:\Program Files\Microsoft VS Code\bin;C:\Users\Administrator\AppData\Local\Programs\Python\Python39\Scripts\;C:\Users\Administrator\AppData\Local\Programs\Python\Python39\;C:\Users\Administrator\AppData\Local\Microsoft\WindowsApps;D:\Program Files\JetBrains\IntelliJ IDEA 2021.1.2\bin;D:\Users\Administrator\AppData\Local\Programs\Microsoft VS Code\bin;C:\Users\Administrator\AppData\Local\GitHubDesktop\bin;D:\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:10:55.185 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\gener>set PATH=D:/RT-ThreadStudio/platform/env_released/env\tools\exec;D:/RT-ThreadStudio/repo/Extract/ToolChain_Support_Packages/ARM/GNU_Tools_for_ARM_Embedded_Processors/5.4.1/bin;D:/RT-ThreadStudio/platform/env_released/env\tools\bin;D:/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;D:/RT-ThreadStudio/platform/env_released/env\tools\Python27;D:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;D:\Program Files (x86)\NetSarang\Xshell 7\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files (x86)\Windows Kits\10\Windows Performance Toolkit\;C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;D:\Program Files\VisualSVN Server\bin;D:\Program Files\TortoiseSVN\bin;d:\Program Files\Git\cmd;D:\Program Files\Microsoft VS Code\bin;C:\Users\Administrator\AppData\Local\Programs\Python\Python39\Scripts\;C:\Users\Administrator\AppData\Local\Programs\Python\Python39\;C:\Users\Administrator\AppData\Local\Microsoft\WindowsApps;D:\Program Files\JetBrains\IntelliJ IDEA 2021.1.2\bin;D:\Users\Administrator\AppData\Local\Programs\Microsoft VS Code\bin;C:\Users\Administrator\AppData\Local\GitHubDesktop\bin;D:\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:10:55.186 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\gener>set PATH=D:/RT-ThreadStudio/platform/env_released/env\tools\qemu\qemu32;D:/RT-ThreadStudio/platform/env_released/env\tools\exec;D:/RT-ThreadStudio/repo/Extract/ToolChain_Support_Packages/ARM/GNU_Tools_for_ARM_Embedded_Processors/5.4.1/bin;D:/RT-ThreadStudio/platform/env_released/env\tools\bin;D:/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;D:/RT-ThreadStudio/platform/env_released/env\tools\Python27;D:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;D:\Program Files (x86)\NetSarang\Xshell 7\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files (x86)\Windows Kits\10\Windows Performance Toolkit\;C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;D:\Program Files\VisualSVN Server\bin;D:\Program Files\TortoiseSVN\bin;d:\Program Files\Git\cmd;D:\Program Files\Microsoft VS Code\bin;C:\Users\Administrator\AppData\Local\Programs\Python\Python39\Scripts\;C:\Users\Administrator\AppData\Local\Programs\Python\Python39\;C:\Users\Administrator\AppData\Local\Microsoft\WindowsApps;D:\Program Files\JetBrains\IntelliJ IDEA 2021.1.2\bin;D:\Users\Administrator\AppData\Local\Programs\Microsoft VS Code\bin;C:\Users\Administrator\AppData\Local\GitHubDesktop\bin;D:\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:10:55.187 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\gener>set PYTHONPATH=D:/RT-ThreadStudio/platform/env_released/env\tools\Python27; !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:10:55.187 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\gener>set PATH=D:/RT-ThreadStudio/platform/env_released/env\tools\qemu\qemu32;D:/RT-ThreadStudio/platform/env_released/env\tools\exec;D:/RT-ThreadStudio/repo/Extract/ToolChain_Support_Packages/ARM/GNU_Tools_for_ARM_Embedded_Processors/5.4.1/bin;D:/RT-ThreadStudio/platform/env_released/env\tools\bin;D:/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;D:/RT-ThreadStudio/platform/env_released/env\tools\Python27;D:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;D:\Program Files (x86)\NetSarang\Xshell 7\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files (x86)\Windows Kits\10\Windows Performance Toolkit\;C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;D:\Program Files\VisualSVN Server\bin;D:\Program Files\TortoiseSVN\bin;d:\Program Files\Git\cmd;D:\Program Files\Microsoft VS Code\bin;C:\Users\Administrator\AppData\Local\Programs\Python\Python39\Scripts\;C:\Users\Administrator\AppData\Local\Programs\Python\Python39\;C:\Users\Administrator\AppData\Local\Microsoft\WindowsApps;D:\Program Files\JetBrains\IntelliJ IDEA 2021.1.2\bin;D:\Users\Administrator\AppData\Local\Programs\Microsoft VS Code\bin;C:\Users\Administrator\AppData\Local\GitHubDesktop\bin;D:\RT-ThreadStudio;; !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:10:55.188 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\gener>"D:/RT-ThreadStudio/plugins/org.rt-thread.studio.project.gener_1.0.30/gener/prj_gen.exe" --bsp_project=true --bsp_parameter_file="D:\RT-ThreadStudio\workspace/.metadata/Temp/board_proj_parameter_demo.json" --project-name=xxx !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:10:57.629 !MESSAGE [22008] Failed to execute script main !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:10:57.630 !MESSAGE finally exit. !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:10:57.631 !MESSAGE Traceback (most recent call last): !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:10:57.632 !MESSAGE File "main.py", line 216, in
!ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:10:57.633 !MESSAGE File "site-packages\click\core.py", line 829, in __call__ !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:10:57.634 !MESSAGE File "site-packages\click\core.py", line 782, in main !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:10:57.636 !MESSAGE File "site-packages\click\core.py", line 1066, in invoke !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:10:57.637 !MESSAGE File "site-packages\click\core.py", line 610, in invoke !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:10:57.638 !MESSAGE File "main.py", line 187, in gen_prj_process !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:10:57.639 !MESSAGE File "backend\bsp_proj\bridge_to_top.py", line 10, in bsp_proj_gen !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:10:57.640 !MESSAGE File "C:\Users\rt-thread\Anaconda3\lib\codecs.py", line 322, in decode !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:10:57.641 !MESSAGE UnicodeDecodeError: 'utf-8' codec can't decode byte 0x88 in position 0: invalid start byte !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:11:04.120 !MESSAGE D:\RT-ThreadStudio>cd /d D:/RT-ThreadStudio/plugins/org.rt-thread.studio.project.gener_1.0.30/gener !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:11:04.123 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\gener>set RTT_ROOT= !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:11:04.124 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\gener>set ENV_ROOT=D:/RT-ThreadStudio/platform/env_released/env !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:11:04.124 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\gener>set RTT_EXEC_PATH=D:/RT-ThreadStudio/repo/Extract/ToolChain_Support_Packages/ARM/GNU_Tools_for_ARM_Embedded_Processors/5.4.1/bin !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:11:04.125 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\gener>set KCONF_EXEC_PATH=D:/RT-ThreadStudio/platform/env_released/env\tools\exec !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:11:04.126 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\gener>set RTT_CC=gcc !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:11:04.127 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\gener>set SCONS=D:/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:11:04.128 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\gener>set PKGS_ROOT=D:/RT-ThreadStudio/platform/env_released/env\packages !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:11:04.128 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\gener>set PATH=D:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;D:\Program Files (x86)\NetSarang\Xshell 7\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files (x86)\Windows Kits\10\Windows Performance Toolkit\;C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;D:\Program Files\VisualSVN Server\bin;D:\Program Files\TortoiseSVN\bin;d:\Program Files\Git\cmd;D:\Program Files\Microsoft VS Code\bin;C:\Users\Administrator\AppData\Local\Programs\Python\Python39\Scripts\;C:\Users\Administrator\AppData\Local\Programs\Python\Python39\;C:\Users\Administrator\AppData\Local\Microsoft\WindowsApps;D:\Program Files\JetBrains\IntelliJ IDEA 2021.1.2\bin;D:\Users\Administrator\AppData\Local\Programs\Microsoft VS Code\bin;C:\Users\Administrator\AppData\Local\GitHubDesktop\bin;D:\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:11:04.130 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\gener>set PATH=D:/RT-ThreadStudio/platform/env_released/env\tools\Python27;D:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;D:\Program Files (x86)\NetSarang\Xshell 7\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files (x86)\Windows Kits\10\Windows Performance Toolkit\;C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;D:\Program Files\VisualSVN Server\bin;D:\Program Files\TortoiseSVN\bin;d:\Program Files\Git\cmd;D:\Program Files\Microsoft VS Code\bin;C:\Users\Administrator\AppData\Local\Programs\Python\Python39\Scripts\;C:\Users\Administrator\AppData\Local\Programs\Python\Python39\;C:\Users\Administrator\AppData\Local\Microsoft\WindowsApps;D:\Program Files\JetBrains\IntelliJ IDEA 2021.1.2\bin;D:\Users\Administrator\AppData\Local\Programs\Microsoft VS Code\bin;C:\Users\Administrator\AppData\Local\GitHubDesktop\bin;D:\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:11:04.131 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\gener>set PATH=D:/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;D:/RT-ThreadStudio/platform/env_released/env\tools\Python27;D:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;D:\Program Files (x86)\NetSarang\Xshell 7\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files (x86)\Windows Kits\10\Windows Performance Toolkit\;C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;D:\Program Files\VisualSVN Server\bin;D:\Program Files\TortoiseSVN\bin;d:\Program Files\Git\cmd;D:\Program Files\Microsoft VS Code\bin;C:\Users\Administrator\AppData\Local\Programs\Python\Python39\Scripts\;C:\Users\Administrator\AppData\Local\Programs\Python\Python39\;C:\Users\Administrator\AppData\Local\Microsoft\WindowsApps;D:\Program Files\JetBrains\IntelliJ IDEA 2021.1.2\bin;D:\Users\Administrator\AppData\Local\Programs\Microsoft VS Code\bin;C:\Users\Administrator\AppData\Local\GitHubDesktop\bin;D:\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:11:04.132 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\gener>set PATH=D:/RT-ThreadStudio/platform/env_released/env\tools\bin;D:/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;D:/RT-ThreadStudio/platform/env_released/env\tools\Python27;D:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;D:\Program Files (x86)\NetSarang\Xshell 7\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files (x86)\Windows Kits\10\Windows Performance Toolkit\;C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;D:\Program Files\VisualSVN Server\bin;D:\Program Files\TortoiseSVN\bin;d:\Program Files\Git\cmd;D:\Program Files\Microsoft VS Code\bin;C:\Users\Administrator\AppData\Local\Programs\Python\Python39\Scripts\;C:\Users\Administrator\AppData\Local\Programs\Python\Python39\;C:\Users\Administrator\AppData\Local\Microsoft\WindowsApps;D:\Program Files\JetBrains\IntelliJ IDEA 2021.1.2\bin;D:\Users\Administrator\AppData\Local\Programs\Microsoft VS Code\bin;C:\Users\Administrator\AppData\Local\GitHubDesktop\bin;D:\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:11:04.133 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\gener>set PATH=D:/RT-ThreadStudio/repo/Extract/ToolChain_Support_Packages/ARM/GNU_Tools_for_ARM_Embedded_Processors/5.4.1/bin;D:/RT-ThreadStudio/platform/env_released/env\tools\bin;D:/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;D:/RT-ThreadStudio/platform/env_released/env\tools\Python27;D:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;D:\Program Files (x86)\NetSarang\Xshell 7\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files (x86)\Windows Kits\10\Windows Performance Toolkit\;C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;D:\Program Files\VisualSVN Server\bin;D:\Program Files\TortoiseSVN\bin;d:\Program Files\Git\cmd;D:\Program Files\Microsoft VS Code\bin;C:\Users\Administrator\AppData\Local\Programs\Python\Python39\Scripts\;C:\Users\Administrator\AppData\Local\Programs\Python\Python39\;C:\Users\Administrator\AppData\Local\Microsoft\WindowsApps;D:\Program Files\JetBrains\IntelliJ IDEA 2021.1.2\bin;D:\Users\Administrator\AppData\Local\Programs\Microsoft VS Code\bin;C:\Users\Administrator\AppData\Local\GitHubDesktop\bin;D:\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:11:04.134 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\gener>set PATH=D:/RT-ThreadStudio/platform/env_released/env\tools\exec;D:/RT-ThreadStudio/repo/Extract/ToolChain_Support_Packages/ARM/GNU_Tools_for_ARM_Embedded_Processors/5.4.1/bin;D:/RT-ThreadStudio/platform/env_released/env\tools\bin;D:/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;D:/RT-ThreadStudio/platform/env_released/env\tools\Python27;D:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;D:\Program Files (x86)\NetSarang\Xshell 7\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files (x86)\Windows Kits\10\Windows Performance Toolkit\;C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;D:\Program Files\VisualSVN Server\bin;D:\Program Files\TortoiseSVN\bin;d:\Program Files\Git\cmd;D:\Program Files\Microsoft VS Code\bin;C:\Users\Administrator\AppData\Local\Programs\Python\Python39\Scripts\;C:\Users\Administrator\AppData\Local\Programs\Python\Python39\;C:\Users\Administrator\AppData\Local\Microsoft\WindowsApps;D:\Program Files\JetBrains\IntelliJ IDEA 2021.1.2\bin;D:\Users\Administrator\AppData\Local\Programs\Microsoft VS Code\bin;C:\Users\Administrator\AppData\Local\GitHubDesktop\bin;D:\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:11:04.134 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\gener>set PATH=D:/RT-ThreadStudio/platform/env_released/env\tools\qemu\qemu32;D:/RT-ThreadStudio/platform/env_released/env\tools\exec;D:/RT-ThreadStudio/repo/Extract/ToolChain_Support_Packages/ARM/GNU_Tools_for_ARM_Embedded_Processors/5.4.1/bin;D:/RT-ThreadStudio/platform/env_released/env\tools\bin;D:/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;D:/RT-ThreadStudio/platform/env_released/env\tools\Python27;D:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;D:\Program Files (x86)\NetSarang\Xshell 7\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files (x86)\Windows Kits\10\Windows Performance Toolkit\;C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;D:\Program Files\VisualSVN Server\bin;D:\Program Files\TortoiseSVN\bin;d:\Program Files\Git\cmd;D:\Program Files\Microsoft VS Code\bin;C:\Users\Administrator\AppData\Local\Programs\Python\Python39\Scripts\;C:\Users\Administrator\AppData\Local\Programs\Python\Python39\;C:\Users\Administrator\AppData\Local\Microsoft\WindowsApps;D:\Program Files\JetBrains\IntelliJ IDEA 2021.1.2\bin;D:\Users\Administrator\AppData\Local\Programs\Microsoft VS Code\bin;C:\Users\Administrator\AppData\Local\GitHubDesktop\bin;D:\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:11:04.135 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\gener>set PYTHONPATH=D:/RT-ThreadStudio/platform/env_released/env\tools\Python27; !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:11:04.136 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\gener>set PATH=D:/RT-ThreadStudio/platform/env_released/env\tools\qemu\qemu32;D:/RT-ThreadStudio/platform/env_released/env\tools\exec;D:/RT-ThreadStudio/repo/Extract/ToolChain_Support_Packages/ARM/GNU_Tools_for_ARM_Embedded_Processors/5.4.1/bin;D:/RT-ThreadStudio/platform/env_released/env\tools\bin;D:/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;D:/RT-ThreadStudio/platform/env_released/env\tools\Python27;D:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;D:\Program Files (x86)\NetSarang\Xshell 7\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files (x86)\Windows Kits\10\Windows Performance Toolkit\;C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;D:\Program Files\VisualSVN Server\bin;D:\Program Files\TortoiseSVN\bin;d:\Program Files\Git\cmd;D:\Program Files\Microsoft VS Code\bin;C:\Users\Administrator\AppData\Local\Programs\Python\Python39\Scripts\;C:\Users\Administrator\AppData\Local\Programs\Python\Python39\;C:\Users\Administrator\AppData\Local\Microsoft\WindowsApps;D:\Program Files\JetBrains\IntelliJ IDEA 2021.1.2\bin;D:\Users\Administrator\AppData\Local\Programs\Microsoft VS Code\bin;C:\Users\Administrator\AppData\Local\GitHubDesktop\bin;D:\RT-ThreadStudio;; !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:11:04.137 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\gener>"D:/RT-ThreadStudio/plugins/org.rt-thread.studio.project.gener_1.0.30/gener/prj_gen.exe" --bsp_project=true --bsp_parameter_file="D:\RT-ThreadStudio\workspace/.metadata/Temp/board_proj_parameter_demo.json" --project-name=xxx !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:11:05.279 !MESSAGE [21516] Failed to execute script main !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:11:05.280 !MESSAGE Traceback (most recent call last): !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:11:05.282 !MESSAGE finally exit. !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:11:05.283 !MESSAGE File "main.py", line 216, in
!ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:11:05.284 !MESSAGE File "site-packages\click\core.py", line 829, in __call__ !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:11:05.286 !MESSAGE File "site-packages\click\core.py", line 782, in main !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:11:05.287 !MESSAGE File "site-packages\click\core.py", line 1066, in invoke !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:11:05.289 !MESSAGE File "site-packages\click\core.py", line 610, in invoke !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:11:05.290 !MESSAGE File "main.py", line 187, in gen_prj_process !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:11:05.291 !MESSAGE File "backend\bsp_proj\bridge_to_top.py", line 10, in bsp_proj_gen !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:11:05.293 !MESSAGE File "C:\Users\rt-thread\Anaconda3\lib\codecs.py", line 322, in decode !ENTRY org.rt-thread.studio.common.ui 1 0 2022-01-14 11:11:05.294 !MESSAGE UnicodeDecodeError: 'utf-8' codec can't decode byte 0x88 in position 0: invalid start byte ```
649
kun222
rtt
rt_thread studio 啥时候能用呢
RT_Thread使用反馈帖子
RTT studio 下的 AT指令问题。
rt thread Studio 关于J-LINK下载问题
RT-Thread studio 调试设置问题
RTT-Studio 如何设置调试配置参数?
rt_thread studio 软件包配置
RT-Studio目前只能开发STM32的项目吗?
rtt studio 生成hex名字修改
V5.2.1 魔改以支持多核处理器从任意核启动
【RSOC25】Day5 课程笔记:软件包相关知识
RT-Thread 夏令营 第五天笔记
【RSOC25】Day5 课程笔记:软件包和网络组件
【RSOC25】Day4 课程笔记:I/O设备和驱动框架
Ryan_CW
D1sguIse_
wdfk_prog
