PIN_GPIO通用驱动
AT32F437-START开发板采用RT-Thread5.0.0版本,发现PIN设备驱动操作方法与实现函数参数不匹配的问题?
发布于 2023-03-01 14:04:33 浏览:730
[tocm] #### 问题简述 下载2023-3-1日github仓库master分支的版本,在AT32F437-START开发板上使用IAR编译project工程会报“结构体类型不匹配的问题”,定位原因到drv_gpio.c与pin.h文件中。 #### 详细说明 下载github仓库上master最新分支,时间为2023年3月1日09:53。   使用`scons --dist`生成工程,在env工具中设置好IAR和MDK5的路径,只开启了内核+shell+pin,如下图所示。设置好template工程的参数后,编译project工程。    产生如下报错。 ```Plain Error[Pe144]: a value of type "void (*)(rt_device_t, rt_base_t, rt_base_t)" cannot be used to initialize an entity of type "void (*)(struct rt_device *, rt_base_t, uint8_t)" C:\Users\JinHuan\Desktop\dist\project\libraries\rt_drivers\drv_gpio.c 482 ```  #### 问题定位 报错位于drv_gpio.c文件中,代码部分为: ```C const static struct rt_pin_ops _at32_pin_ops = { at32_pin_mode, at32_pin_write, at32_pin_read, at32_pin_attach_irq, at32_pin_dettach_irq, at32_pin_irq_enable, at32_pin_get, }; ``` 查看pin.h文件中`struct rt_pin_ops` 原型: ```C struct rt_pin_ops { void (*pin_mode)(struct rt_device *device, rt_base_t pin, rt_uint8_t mode); void (*pin_write)(struct rt_device *device, rt_base_t pin, rt_uint8_t value); rt_int8_t (*pin_read)(struct rt_device *device, rt_base_t pin); rt_err_t (*pin_attach_irq)(struct rt_device *device, rt_base_t pin, rt_uint8_t mode, void (*hdr)(void *args), void *args); rt_err_t (*pin_detach_irq)(struct rt_device *device, rt_base_t pin); rt_err_t (*pin_irq_enable)(struct rt_device *device, rt_base_t pin, rt_uint8_t enabled); rt_base_t (*pin_get)(const char *name); }; ``` 查看drv_gpio.c文件,上述操作方法中的实现函数原型如下: ```C static void at32_pin_mode(rt_device_t dev, rt_base_t pin, rt_base_t mode) static void at32_pin_write(rt_device_t dev, rt_base_t pin, rt_base_t value) static int at32_pin_read(rt_device_t dev, rt_base_t pin) static rt_err_t at32_pin_attach_irq(struct rt_device *device, rt_int32_t pin, rt_uint32_t mode, void (*hdr)(void *args), void *args) static rt_err_t at32_pin_dettach_irq(struct rt_device *device, rt_int32_t pin) static rt_err_t at32_pin_irq_enable(struct rt_device *device, rt_base_t pin, rt_uint32_t enabled) static rt_base_t at32_pin_get(const char *name) ``` 可以看到有以下不匹配的地方: 2. `at32_pin_mode`其中的`mode`参数类型不一致,一个是`rt_uint8_t` ,一个是`rt_base_t`。 3. `at32_pin_write`其中的`value`参数类型不一致,一个是`rt_uint8_t` ,一个是`rt_base_t`。 4. `at32_pin_read`返回值不一样,一个是`rt_int8_t`,一个是`int`。 5. `at32_pin_attach_irq` 其中的`pin`参数类型不一致,一个是`rt_base_t`,一个是`rt_int32_t`。其中的`mode`参数类型不一样,一个是`rt_uint8_t` ,一个是`rt_uint32_t` 。 6. `at32_pin_dettach_irq`其中的`pin`参数类型不一样,一个是`rt_base_t`,一个是`rt_uint32_t` 。 7. `at32_pin_irq_enable`其中的`enabled参数`类型不一样,一个是`rt_uint8_t` ,一个是`rt_uint32_t` 。 rt_def.h文件中有关RT-Thread变量类型定义如下: ```C /* RT-Thread basic data type definitions */ typedef int rt_bool_t; /**< boolean type */ typedef signed long rt_base_t; /**< Nbit CPU related date type */ typedef unsigned long rt_ubase_t; /**< Nbit unsigned CPU related data type */ typedef signed char rt_int8_t; /**< 8bit integer type */ typedef signed short rt_int16_t; /**< 16bit integer type */ typedef signed int rt_int32_t; /**< 32bit integer type */ typedef unsigned char rt_uint8_t; /**< 8bit unsigned integer type */ typedef unsigned short rt_uint16_t; /**< 16bit unsigned integer type */ typedef unsigned int rt_uint32_t; /**< 32bit unsigned integer type */ ``` #### 问题解决 目前把drv_gpio.c中下列函数的形参或返回值修改为跟`rt_pin_ops`操作方法中的成员形参与返回值一致。重新修改之后的drv_gpio.c中函数原型如下: ```C static void at32_pin_mode(rt_device_t dev, rt_base_t pin, rt_uint8_t mode) static void at32_pin_write(rt_device_t dev, rt_base_t pin, rt_uint8_t value) static rt_int8_t at32_pin_read(rt_device_t dev, rt_base_t pin) static rt_err_t at32_pin_attach_irq(struct rt_device *device, rt_base_t pin, rt_uint8_t mode, void (*hdr)(void *args), void *args) static rt_err_t at32_pin_dettach_irq(struct rt_device *device, rt_base_t pin) static rt_err_t at32_pin_irq_enable(struct rt_device *device, rt_base_t pin, rt_uint8_t enabled) static rt_base_t at32_pin_get(const char *name) ``` #### 工程源码 project_0为未修改的工程,project_1为修改drv_gpio.c中相关函数类型的工程。 - [project_0.7z](https://club.rt-thread.org/file_download/b19564e53172970d) - [project_1.7z](https://club.rt-thread.org/file_download/08df2d5f2ef79e01)
730
JinHuan
PIN绑定引脚中断回调函数没有反应
rtthread PIN设备
关于引脚宏定义的一些疑惑
关于gpio引脚实在不懂了,求大家帮助
GET_PIN(A, 1) 提示 'A' 未定义
关于4.0.2版本中STM32的PIN设备外部中断的相关问题
自己按照官方手册 在drv_gpio.c里面找不到PIN脚信息
关于多个PIN设备同时读写的问题
翻车在一个GPIO上 开启pin中断 导致程序卡死
外部中断回调函数执行问题
【睿擎工业平台试用】EtherCAT主站控制从站IO
【睿擎工业平台试用】硬件平台上手和Modbus功能使用
rt thread 文件系统dfs挂载2个块设备
RT Thread 块设备注册
chejia12
纯白酱
530china
rv666
