touchgfx
wifi
ART-PI 在运行Touchgfx时如果打开wifi就在初始化时有一段时间乱码
发布于 2021-02-03 10:14:37 浏览:1661
首先说明一下问题,在ART-Pi上运行好Touchgfx的官方例程后,若不开启AP6212A,屏幕显示正常,若开启AP6212A发现屏幕在初始化时会发生乱码。经过检查项目的软件包时,发现会有一个Fal被使能,这时在终端可以看到以下数据 [I/SFUD] Probe SPI flash norflash0 by SPI device spi10 success. [D/FAL] (fal_flash_init:63) Flash device | norflash0 | addr: 0x00000000 | len: 0x01000000 | blk_size: 0x00001000 |initialized finish. [I/FAL] ==================== FAL partition table ==================== [I/FAL] | name | flash_dev | offset | length | [I/FAL] ------------------------------------------------------------- [I/FAL] | wifi_image | norflash0 | 0x00000000 | 0x00080000 | [I/FAL] | bt_image | norflash0 | 0x00080000 | 0x00080000 | [I/FAL] | download | norflash0 | 0x00100000 | 0x00200000 | [I/FAL] | easyflash | norflash0 | 0x00300000 | 0x00100000 | [I/FAL] | filesystem | norflash0 | 0x00400000 | 0x00c00000 | [I/FAL] ============================================================= [I/FAL] RT-Thread Flash Abstraction Layer (V0.5.0) initialize success. 发现norflash被分区,接着我又开始分析具体是什么情况引起的初始化时有一段时间的乱码,于是我想到了,TouchGfx会不会使用了Flash靠前的部分,于是就找到了fal_cfg.h文件,打开后可以看到: } /* ==================== Partition Configuration ======================== */ #ifdef FAL_PART_HAS_TABLE_CFG #define FAL_PART_TABLE \ { \ {FAL_PART_MAGIC_WORD, "wifi_image", NOR_FLASH_DEV_NAME, 0, 512*1024, 0}, \ {FAL_PART_MAGIC_WORD, "bt_image", NOR_FLASH_DEV_NAME, 512*1024, 512*1024, 0}, \ {FAL_PART_MAGIC_WORD, "download", NOR_FLASH_DEV_NAME, 1024*1024, 2*1024*1024, 0}, \ {FAL_PART_MAGIC_WORD, "easyflash", NOR_FLASH_DEV_NAME, 3*1024*1024, 1*1024*1024, 0}, \ {FAL_PART_MAGIC_WORD, "filesystem", NOR_FLASH_DEV_NAME, 4*1024*1024, 12*1024*1024, 0}, \ } #endif /* FAL_PART_HAS_TABLE_CFG */ 可以看到第一个分区是关于wifi的,于是就将flash全部向后移动1024,果然屏幕不会有一段时间乱码了,但是又出现了一个新的报错(最后一行): [I/SFUD] Probe SPI flash norflash0 by SPI device spi10 success. [D/FAL] (fal_flash_init:63) Flash device | norflash0 | addr: 0x00000000 | len: 0x01000000 | blk_size: 0x00001000 |initialized finish. [I/FAL] ==================== FAL partition table ==================== [I/FAL] | name | flash_dev | offset | length | [I/FAL] ------------------------------------------------------------- [I/FAL] | wifi_image | norflash0 | 0x00000400 | 0x00080400 | [I/FAL] | bt_image | norflash0 | 0x00080400 | 0x00080400 | [I/FAL] | download | norflash0 | 0x00100400 | 0x00200400 | [I/FAL] | easyflash | norflash0 | 0x00300400 | 0x00100400 | [I/FAL] | filesystem | norflash0 | 0x00400400 | 0x00c00400 | [I/FAL] ============================================================= [I/FAL] RT-Thread Flash Abstraction Layer (V0.5.0) initialize success. [I/at.clnt] AT client(V1.3.0) on device uart6 initialize success. [D/at.dev.ec20] network interface device(4G) set up status. [I/FAL] The FAL MTD NOR device (filesystem) created successfully ../packages/littlefs-latest/lfs.c:1071:error: Corrupted dir pair at {0x0, 0x1} [W/app.filesystem] mount to '/flash' failed! try to mkfs filesyst夗夗眄眄?$ [I/touch] rt_touch init success [D/at.dev.[ec20] startI/OTA] RT init -4G device.Thread OTA package(V0.2.3) initialize success. **msh />[E/WLAN] Wi-Fi image was NOT found on wifi_image partition** 我第一次碰到这个报错的时候已经懵了,于是就开始查找源头,在libraries->drivers->drv_wlan.c 可以看到第171行函数, /* initialize fal */ fal_init(); partition = fal_partition_find(WIFI_IMAGE_PARTITION_NAME); 首先进行fal初始化,其次是fal_partition_find(WIFI_IMAGE_PARTITION_NAME);查找分区函数。接着就会执行一下函数,原来在初始化之前会寻找此分区,但是我不清楚这个分区明明已经定义仅仅是向后移动了一部分不知为何就是找不到,所以还请大佬帮帮忙。 if (rt_ota_part_fw_verify(partition) >= 0) { /* initialize low level wifi(ap6212) library */ wifi_hw_init(); /* waiting for sdio bus stability */ rt_thread_delay(WIFI_INIT_WAIT_TIME); /* set wifi work mode */ rt_wlan_set_mode(RT_WLAN_DEVICE_STA_NAME, RT_WLAN_STATION); /* NEED TODO !!! */ /* rt_wlan_set_mode(RT_WLAN_DEVICE_AP_NAME, RT_WLAN_AP); */ init_flag = 1; } else { LOG_E("Wi-Fi image was NOT found on %s partition!", WIFI_IMAGE_PARTITION_NAME); }
2021-02-03
可以先尝试在一个没有 `touchgfx` 的工程上去验证 `FAL` 的功能是否正常, 偏移地址改到 4096 试一试。 `FAL` 提供了很多的 终端测试命令 `fal probe` `fal write` `fal read` 先测试一下这些是否正常。
Fjf
2021-05-24
```C++ bool TouchGFXHAL::blockCopy(void* RESTRICT dest, const void* RESTRICT src, uint32_t numBytes) ``` 咨询一下,Touch GFX中的这个函数在RTT中什么时候调用?具体在哪里调用?能不能把它调用的顺序放在SD卡挂载后?
1.7k
贾S_1872468521
RT-STUDIO下加入TOUCHGFX?
ART-Pi 在 Studio 中使用TouchGFX Library 编译报错
APT-Pi运行Touchgfx例程出现错误
请问程序烧到内部rom后,如何把touchgfx图片数据烧到片外8M闪存里
ART-Pi在同时打开板载wifi例程和touchgfx后发生乱屏的现象
ART-PI的Touchgfx按键事件没反应
TouchGFX从文件系统中读取图片失败
TouchGFX如何从文件系统中读取字库
将ExtFlashSection映射到添加的USB区域后,程序下载失败
ART-PI添加了Touchgfx后显示模糊
STM32H723使用ETH使用记录
【GD32F527I-EVAL运行RTThread】使用Agile Button 处理按键输入
th-thread 源码学习-中断系统
【GD32F527I-EVAL运行RTThread】GPIO外设使用
庐山派K230 基于RT-Smart实现FOC云台控制并封装成micropython库与物体自动跟踪系统
QEMU
1532
346
822
180
super_gith
wdfk_prog
killer22
LoongYang
waner
