DIY综合交流区
关于stm32f407 I2s DMA主发送的问题
发布于 2013-06-28 15:29:44 浏览:3107
最近用stm32f407做一个sd卡mp3解码后,音频传输的项目,声卡芯片用的VM8978,采取的是SPI3的i2s,用的DMA是DMA1的stream5通道0.用的是主发送模式,程序代码是用的realtouch修改过来的代码。 在dma中断中我用一个led反转看是否进入中断,结果是,中断进入,但i2s 引脚为何没有输出,按道理说应该是有波形输出的啊 BCLk脚怎么一直是低电平了? 程序如下: ```c DMA_InitTypeDef DMA_InitStructure; u32 AudioTotalSize = 0xffff; u32 AudioRemSize = 0; u16 *CurrentPos; extern void AUDIO_TransferComplete(u32 pBuffer, uint32_t Size); void AUDIO_Init(u32 AudioFreq) { Audio_I2S_Init(AudioFreq); I2S_GPIO_Init(); Audio_DMA_Init(); } void I2s_GPIO_DEinit(void) { GPIO_InitTypeDef GPIO_InitStructure; RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE); RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE); GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; /* I2S3S_WS */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15; GPIO_Init(GPIOA, &GPIO_InitStructure); /* I2S3_CK, I2S3_SD, I2S3ext_SD */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5; GPIO_Init(GPIOB, &GPIO_InitStructure); } void I2S_GPIO_Init(void) { GPIO_InitTypeDef GPIO_InitStructure; I2s_GPIO_DEinit(); RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE); RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE); GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; /* Connect pins to I2S peripheral */ GPIO_PinAFConfig(GPIOA, GPIO_PinSource15, GPIO_AF_SPI3); GPIO_PinAFConfig(GPIOB, GPIO_PinSource3, GPIO_AF_SPI3); GPIO_PinAFConfig(GPIOB, GPIO_PinSource4, GPIO_AF_I2S3ext); GPIO_PinAFConfig(GPIOB, GPIO_PinSource5, GPIO_AF_SPI3); /* I2S3S_WS */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15; GPIO_Init(GPIOA, &GPIO_InitStructure); /* I2S3_CK, I2S3_SD, I2S3ext_SD */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5; GPIO_Init(GPIOB, &GPIO_InitStructure); } void Audio_I2S_Init(uint32_t AudioFreq) { I2S_InitTypeDef I2S_InitStructure; SPI_I2S_DeInit(SPI3); RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI3, ENABLE); SPI_I2S_DeInit(SPI3); I2S_InitStructure.I2S_AudioFreq = AudioFreq; I2S_InitStructure.I2S_Standard = I2S_Standard_Phillips; I2S_InitStructure.I2S_DataFormat = I2S_DataFormat_16b; I2S_InitStructure.I2S_CPOL = I2S_CPOL_Low; I2S_InitStructure.I2S_Mode = I2S_Mode_MasterTx; I2S_InitStructure.I2S_MCLKOutput = I2S_MCLKOutput_Disable; I2S_Init(SPI3, &I2S_InitStructure); } //DMA传送配置 void Audio_DMA_Init(void) { NVIC_InitTypeDef NVIC_InitStructure; RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA1, ENABLE); DMA_Cmd(DMA1_Stream5, DISABLE); DMA_DeInit(DMA1_Stream5); DMA_InitStructure.DMA_Channel = DMA_Channel_0; DMA_InitStructure.DMA_PeripheralBaseAddr = 0x4000380C; DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)0;//该项将在播放函数中进行配置 DMA_InitStructure.DMA_DIR = DMA_DIR_MemoryToPeripheral; DMA_InitStructure.DMA_BufferSize = (uint32_t)0xFFFE;//该项将在播放函数中进行配置 DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord; DMA_InitStructure.DMA_Mode = DMA_Mode_Normal; DMA_InitStructure.DMA_Priority = DMA_Priority_High; DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable; DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_1QuarterFull; DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single; DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single; DMA_Init(DMA1_Stream5, &DMA_InitStructure); DMA_ITConfig(DMA1_Stream5, DMA_IT_TC, ENABLE);//使能所选DMA的中断 //I2S DMA中断通道配置 NVIC_InitStructure.NVIC_IRQChannel = DMA1_Stream5_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;//抢占优先级(0 最高) NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;//子优先级(0 最高) NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); SPI_I2S_DMACmd(SPI3, SPI_I2S_DMAReq_Tx, ENABLE);//中断请求使能 } //开始从特定大小(Size)的缓冲区(pBuffer)中播放音频流 uint32_t AUDIO_Play(u16* pBuffer, u32 Size) { AudioTotalSize=Size; Audio_MAL_Play((u32)pBuffer,(u32)(DMA_MAX(Size/4)));//更新媒体层数据并播放 AudioRemSize=(Size/2)-DMA_MAX(AudioTotalSize);//更新剩余数据量 CurrentPos=pBuffer+DMA_MAX(AudioTotalSize);//更新当新数据指针 return 0; } //开始播放媒体中的音频流 void Audio_MAL_Play(u32 Addr, u32 Size) { DMA_InitStructure.DMA_Memory0BaseAddr=(uint32_t)Addr;//配置缓冲区地址和大小 DMA_InitStructure.DMA_BufferSize=(uint32_t)Size/2; DMA_Init(DMA1_Stream5,&DMA_InitStructure); DMA_Cmd(DMA1_Stream5,ENABLE);//I2S DMA使能 if ((SPI3->I2SCFGR & I2S_ENABLE_MASK)==0)I2S_Cmd(SPI3,ENABLE);//若I2S接口未使能,则使能 } //I2S中断处理 void SPI3_IRQHandler(void) { if (SPI_I2S_GetFlagStatus(SPI3,SPI_I2S_FLAG_TXE)!=RESET) { SPI_I2S_SendData(SPI3, 0);//发送空字节到I2S SPI_I2S_ClearFlag(SPI3,SPI_I2S_FLAG_TXE); } } //DMA中断处理函数 void DMA1_Stream5_IRQHandler(void) { //传送完成中断 if (DMA_GetFlagStatus(DMA1_Stream5, DMA_FLAG_TCIF5)!=RESET) { if (AudioRemSize>0)//查看是否到达文件尾 { printf("DMA1 "); while (DMA_GetCmdStatus(DMA1_Stream5) != DISABLE) IWDG_ReloadCounter();//等待DMA disabled DMA_ClearFlag(DMA1_Stream5, DMA_FLAG_TCIF5);//清传送完成中断标志 DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t) CurrentPos;//重新配置缓冲区地址和大小 DMA_InitStructure.DMA_BufferSize = (uint32_t) (DMA_MAX(AudioRemSize)); DMA_Init(DMA1_Stream5, &DMA_InitStructure); DMA_Cmd(DMA1_Stream5, ENABLE); CurrentPos += DMA_MAX(AudioRemSize);//更新数据指针 AudioRemSize -= DMA_MAX(AudioRemSize);//更新剩余数据 DMA_Cmd(DMA1_Stream5, ENABLE); } else//已到达文件尾 { DMA_Cmd(DMA1_Stream5, DISABLE); DMA_ClearFlag(DMA1_Stream5, DMA_FLAG_TCIF5); AUDIO_TransferComplete((uint32_t)CurrentPos, 0); STM_EVAL_LEDToggle(2); //led反转 ,显示状态 // printf("DMA2 "); } // printf("DMA3 "); } } ```
3.1k
xslyk
[项目]搞个开源的硬件项目
硬件计划贴,及时更新,欢迎提意见
MMS协议
定点的wma解压库-libwma
QQ群记录 [20090821]
STM32网络收音机PCB报名征集
第一版调试记录
第二版硬件讨论
嵌入式ARM RISCV toolchain工具 梳理arm-none-eabi-gcc
可以使用MQTT连接AI大模型吗
wake_mirco
mushroom
Jack_____
