请教个问题,我用BK7321,输出pwm,和adc,等其他外设没反应
发布于 2019-05-14 18:15:36 浏览:1655
* 本帖最后由 aozima 于 2019-5-14 19:26 编辑 * ```OSStatus wh_pwm_initialize(bk_pwm_t pwm, uint32_t frequency, float duty_cycle) { UINT32 ret; pwm_param_t param; /*init pwm*/ param.channel = (uint8_t)pwm; param.cfg.bits.en = PWM_DISABLE; param.cfg.bits.int_en = PWM_INT_EN; param.cfg.bits.mode = PMODE_PWM; param.cfg.bits.clk = PWM_CLK_26M; param.p_Int_Handler = 0; param.duty_cycle = duty_cycle; param.end_value = frequency; // ????? ret = sddev_control(PWM_DEV_NAME, CMD_PWM_INIT_PARAM, ¶m); ASSERT(PWM_SUCCESS == ret); rt_kprintf("liuweihao:%d
",ret);//liuweihao return kNoErr; } OSStatus wh_pwm_start(bk_pwm_t pwm) { UINT32 ret; UINT32 param; bk_gpio_config_output(GPIO19); bk_gpio_output(GPIO19, 1); param = pwm; ret = sddev_control(PWM_DEV_NAME, CMD_PWM_UNIT_ENABLE, ¶m); ASSERT(PWM_SUCCESS == ret); rt_kprintf("wh_pwm_startliuweihao:%d
",ret);//liuweihao return kNoErr; } OSStatus wh_pwm_stop(bk_pwm_t pwm) { UINT32 ret; UINT32 param; param = pwm; ret = sddev_control(PWM_DEV_NAME, CMD_PWM_UINT_DISABLE, ¶m); ASSERT(PWM_SUCCESS == ret); return kNoErr; } #if 1 #define PWM_DEV_NAME "pwm" /* PWM设备名称 */ #define PWM_DEV_CHANNEL 5 /* PWM通道 */ struct rt_device_pwm *pwm_dev; /* PWM设备句柄 */ static int pwm_led_sample(int argc, char *argv[]) { rt_uint32_t period, pulse, dir; period = 500000; /* 周期为0.5ms,单位为纳秒ns */ dir = 1; /* PWM脉冲宽度值的增减方向 */ pulse = 0; /* PWM脉冲宽度值,单位为纳秒ns */ // bk_gpio_config_output(GPIO19); //bk_gpio_output(GPIO19, 1); wh_pwm_initialize(5,6500,3000); wh_pwm_start(5); /* 查找设备 */ pwm_dev = (struct rt_device_pwm *)rt_device_find(PWM_DEV_NAME); if (pwm_dev == RT_NULL) { rt_kprintf("pwm sample run failed! can't find %s device!
", PWM_DEV_NAME); return RT_ERROR; } /* 设置PWM周期和脉冲宽度默认值 */ rt_pwm_set(PWM_DEV_CHANNEL, period, pulse); /* 使能设备 */ rt_pwm_enable( PWM_DEV_CHANNEL); rt_kprintf("pwm 8888sample run failed! can't find %s device!
", pwm_dev); while (1) {rt_thread_mdelay(150); if (dir) { pulse += 5000; /* 从0值开始每次增加5000ns */ } else { pulse -= 5000; /* 从最大值开始每次减少5000ns */ } if (pulse >= period) { dir = 0; } if (0 == pulse) { dir = 1; } // wh_pwm_initialize(5,6500,3000); // wh_pwm_start(5); // rt_thread_mdelay(150); // wh_pwm_stop(5); /* 设置PWM周期和脉冲宽度 */ rt_pwm_set( PWM_DEV_CHANNEL, period, pulse); } } /* 导出到 msh 命令列表中 */ MSH_CMD_EXPORT(pwm_led_sample, pwm sample); void pwm_led_thread_entry(void *parameter) { pwm_led_sample(0,RT_NULL); } int pwm_led_thread_init(void) { rt_thread_t thread; thread =rt_thread_create("pwm_led", pwm_led_thread_entry,RT_NULL,512,20,10 ); if (thread != RT_NULL) { rt_thread_startup(thread); rt_kprintf("pwm_led_rt_thread_startup
"); } return RT_EOK; } //INIT_APP_EXPORT(pwm_led_thread_init); #endif``` 主函数就调用pwm_led_thread_init();个人调试出现的现象是 /* 设置PWM周期和脉冲宽度默认值 */ rt_pwm_set(PWM_DEV_CHANNEL, period, pulse);这个设置失败; 后面有人提示我没初始化,我按bk提供的例程修改 wh_pwm_initialize(5,6500,3000); wh_pwm_start(5); 初始化了这两个,还是不能输出PWM,求大佬解答
shadowliang
2019-05-14
Hello,world!!!
不知道楼主的问题是否解决了,可以试试我这个方法,把附件中的drv_pwm.c文件替换到项目工程文件夹中的driver目录下的drv_pwm.c文件(注意:建议先备份你原有drv_pwm.c文件。)还有在项目工程根目录下的rtconfig.h文件中添加 #define RT_USING_PWM 开启pwm模块,然后重新编译生成工程,把生成的bin文件烧录到板子上,如果编译等操作步骤没有报错,就可以在msh命令行中使用pwm 的操作,如:输入 pwm_set 1 8000 4000 //这是设置使用PWM 1 周期8us 占空比为50% ,然后输入 pwm_enable 1 // 这是启动pwm 1; 如果需要使用其他的pwm 通道可以把1换为对应的pwm通道数,周期也可以根据实际修改,设置好pwm 后可以在对应的引脚接一个led灯测试。
刘明洲
2019-05-15
[i=s] 本帖最后由 刘明洲 于 2019-5-15 09:11 编辑 [/i] >不知道楼主的问题是否解决了,可以试试我这个方法,把附件中的drv_pwm.c文件替换到项目工程文件夹中的drive ... --- 我工程里有定义/* Device Drivers */ #define RT_USING_DEVICE_IPC #define RT_USING_SERIAL #define RT_USING_I2C #define RT_USING_I2C_BITOPS #define RT_USING_PIN #define RT_USING_PWM #define RT_USING_RTC #define RT_USING_SOFT_RTC #define RT_USING_WDT #define RT_USING_WIFI #define RT_USING_WLAN_STA #define RT_USING_WLAN_AP #define WIFI_DEVICE_STA_NAME "w0" #define WIFI_DEVICE_AP_NAME "ap" 这些东西,你给的dr_pwm.c跟我的.c类似,有点区别感谢,请大佬提供下,其他驱动的软件包可以?你的这个跟我那里面的那个有点区别,换上去可以了,感谢
1.7k
刘明洲
cJSON 避坑笔记
Vision-Board porting Xbox One USB Controller
可存万物的bsp_flash
TIM,硬件定时器驱动程序
LCD(mipi)+LVGL +gui(适配V8.x版本)
1506
339
1423
281
740
161
539
157
1218
146
