Kernel
【求助】邮箱接收发生问题[已解决]
发布于 2019-03-05 11:38:44 浏览:2297
* 本帖最后由 来日方长 于 2019-3-5 22:08 编辑 * 在线程1中进行邮箱初始化```add_music_mb = rt_mb_create("add_music_mb",10,RT_IPC_FLAG_FIFO); if (add_music_mb == RT_NULL) { rt_kprintf("init mailbox add_music_mb failed.
"); return -RT_ERROR; }```线程2中进行发送邮件```result = rt_mb_send(add_music_mb, (rt_ubase_t)newfilemane);```其中newfilemane是一个字符串指针用于存放文件名,指向rt_malloc申请的内存中。发送过在另一个线程里接收```result = rt_mb_recv(add_music_mb,(rt_ubase_t *)addfilemane,RT_WAITING_NO);```addfilemane和newfilemane一样,是char *类型的字符串指针,但是接收时会进入硬件中断,通过单独调试找到的错误发生在rt_mb_recv中,即ipc.c的第1684行```/* increase output offset */ ++ mb->out_offset;```完整邮箱接收函数如下:```rt_err_t rt_mb_recv(rt_mailbox_t mb, rt_ubase_t *value, rt_int32_t timeout) { struct rt_thread *thread; register rt_ubase_t temp; rt_uint32_t tick_delta; /* parameter check */ RT_ASSERT(mb != RT_NULL); RT_ASSERT(rt_object_get_type(&mb->parent.parent) == RT_Object_Class_MailBox); /* initialize delta tick */ tick_delta = 0; /* get current thread */ thread = rt_thread_self(); RT_OBJECT_HOOK_CALL(rt_object_trytake_hook, (&(mb->parent.parent))); /* disable interrupt */ temp = rt_hw_interrupt_disable(); /* for non-blocking call */ if (mb->entry == 0 && timeout == 0) { rt_hw_interrupt_enable(temp); return -RT_ETIMEOUT; } /* mailbox is empty */ while (mb->entry == 0) { /* reset error number in thread */ thread->error = RT_EOK; /* no waiting, return timeout */ if (timeout == 0) { /* enable interrupt */ rt_hw_interrupt_enable(temp); thread->error = -RT_ETIMEOUT; return -RT_ETIMEOUT; } RT_DEBUG_IN_THREAD_CONTEXT; /* suspend current thread */ rt_ipc_list_suspend(&(mb->parent.suspend_thread), thread, mb->parent.parent.flag); /* has waiting time, start thread timer */ if (timeout > 0) { /* get the start tick of timer */ tick_delta = rt_tick_get(); RT_DEBUG_LOG(RT_DEBUG_IPC, ("mb_recv: start timer of thread:%s
", thread->name)); /* reset the timeout of thread timer and start it */ rt_timer_control(&(thread->thread_timer), RT_TIMER_CTRL_SET_TIME, &timeout); rt_timer_start(&(thread->thread_timer)); } /* enable interrupt */ rt_hw_interrupt_enable(temp); /* re-schedule */ rt_schedule(); /* resume from suspend state */ if (thread->error != RT_EOK) { /* return error */ return thread->error; } /* disable interrupt */ temp = rt_hw_interrupt_disable(); /* if it's not waiting forever and then re-calculate timeout tick */ if (timeout > 0) { tick_delta = rt_tick_get() - tick_delta; timeout -= tick_delta; if (timeout < 0) timeout = 0; } } /* fill ptr */ *value = mb->msg_pool[mb->out_offset]; /* increase output offset */ ++ mb->out_offset;//这一行会进入硬件中断 if (mb->out_offset >= mb->size) mb->out_offset = 0; /* decrease message entry */ mb->entry --; /* resume suspended thread */ if (!rt_list_isempty(&(mb->suspend_sender_thread))) { rt_ipc_list_resume(&(mb->suspend_sender_thread)); /* enable interrupt */ rt_hw_interrupt_enable(temp); RT_OBJECT_HOOK_CALL(rt_object_take_hook, (&(mb->parent.parent))); rt_schedule(); return RT_EOK; } /* enable interrupt */ rt_hw_interrupt_enable(temp); RT_OBJECT_HOOK_CALL(rt_object_take_hook, (&(mb->parent.parent))); return RT_EOK; } RTM_EXPORT(rt_mb_recv);```目前完全没有头绪,希望大神帮忙看下。
来日方长
2019-03-05
>接收的时候addfilemane需要取址 --- addfilemane是char *类型的指针,这个我觉得应该不需要再取地址了吧
水清沙白
2019-03-05
>addfilemane是char *类型的指针,这个我觉得应该不需要再取地址了吧 --- 需要取地址,你看rt_mb_recv的实现 ``` *value = mb->msg_pool[mb->out_offset]; ``` 如果你不取地址直接强制转换传入的话,相当于 ``` *((rt_ubast_t *)add_mucic_mb) =mb->msg_pool[mb->out_offset]; ``` 而add_mucic_mb是一个指针,指向一块未经初始化的指针,必然出错了。 IPC这块可参考编程指南[https://www.rt-thread.org/document/site/programming-manual/ipc2/ipc2/#_11](邮箱使用)
来日方长
2019-03-05
>需要取地址,你看rt_mb_recv的实现 --- 非常感谢 确实是要取地址,没有仔细去看官方的例子了
2.3k
来日方长
35
请教cpu使用率分析
选择FreeRTOS, 还是RT-Thread。
thread heap stack overflow ?
rtt消息队列delay问题
释放被删除线程的内存地方在哪里啊
请教:各线程结束后,释放其中的内存的连续性问题
STM32F103中断关于信号量、邮箱问题
RTT中的线程栈大小如何控制
关于线程由执行态变为挂起态的代码实现,,,
RT-Thread studio的驱动5.1.0报错修改
基于RT-Thread的STM32开发第一讲——USART
pkgs --upgrade报错SSL未验证问题解决记录
CherryUSB STM32 glue 新增初始化
818
