m6315
请问是at组件问题 还是6315模块问题
发布于 2020-11-26 14:56:57 浏览:1098
stm405 ;rt-thread studio 1.1.5; at-2.03 ; rt-thread 4.02,中移物联的M6315模组 ``` int gprs_socket_send(int socketid, const uint8_t *buf, const int buf_size, const int flags) { int ret; at_response_t resp = RT_NULL; char para_exp[32]; uint32_t event = 0; int event_result; if (buf == NULL || buf_size > AT_MAX_PAYLOAD_LEN || socketid >= MAX_SOCKET_NUM) { rt_kprintf("--->[Error] Invalid args \r\n"); return AT_INVALID_DATA; } //resp = at_create_resp(128, 2, 20 * RT_TICK_PER_SECOND); resp = at_create_resp(128, 2, AT_IPSEND_TIMEOUT); if (resp == RT_NULL) { //LOG_E("no memory for resp create."); return -RT_ENOMEM; } // clear socket connect event event = SET_EVENT(socketid, GPRS_EVENT_SEND_OK | GPRS_EVENT_SEND_FAIL); gprs_socket_event_recv(event, 0, RT_EVENT_FLAG_OR); at_set_end_sign('>'); memset(para_exp, 0, sizeof(para_exp)); snprintf(para_exp, sizeof(para_exp), "%s=%d,%d", AT_IPSEND, socketid, buf_size); //ret = at_client_dev_cmd(para_exp, strlen(para_exp), ">", NULL, NULL); ret = at_exec_cmd(resp, para_exp); if (ret < 0) { rt_kprintf("--->[Error] 1gprs_socket_send_str fail ! ret=%d str=%s\r\n", ret, buf); ret = -RT_ERROR; goto __exit; } //ret = at_client_dev_cmd(buf, buf_size, "SEND OK", AT_IPSEND_RESP_LINE, NULL, NULL); ret = at_client_send(buf, buf_size); if (ret <= 0) { rt_kprintf("--->[Error] 2gprs_socket_send_str fail ! ret=%d str=%s\r\n", ret, buf); ret = -RT_ERROR; goto __exit; } // waiting result event from AT URC event = SET_EVENT(socketid, 0); if (gprs_socket_event_recv(event , 20 * RT_TICK_PER_SECOND, RT_EVENT_FLAG_OR) < 0) { LOG_E("device socket(%d) wait send result timeout.", socketid); ret = -RT_ETIMEOUT; goto __exit; } // waiting OK or failed result event = SET_EVENT(socketid, GPRS_EVENT_SEND_OK | GPRS_EVENT_SEND_FAIL); event_result = gprs_socket_event_recv(event , 15 * RT_TICK_PER_SECOND, RT_EVENT_FLAG_OR); if (event_result < 0) { LOG_E("device socket(%d) wait send connect OK|FAIL timeout.", socketid); ret = -RT_ETIMEOUT; goto __exit; } // check result if (event_result & GPRS_EVENT_SEND_FAIL) { LOG_E("device socket(%d) send failed.", socketid); ret = -RT_ERROR; goto __exit; } __exit: /* reset the end sign for data conflict */ at_set_end_sign(0); //rt_mutex_release(lock); if (resp) { at_delete_resp(resp); } return ret; } ``` 协议  发送和接收数据情况  AT+QISEND=0,6 这个正确 AT+QISEND=0,87 这个就不符合要求了 什么会出现这样的情况呢?是at组件问题? 还是6315模块问题?
2021-03-19
请进入单步调试模式,跟踪一下代码,是否是延时不当引起的问题?
1.1k
piaoxueboy
rt-thread 2g/3g/4g通信模块的教程有吗?
基于AT指令,用esp8266如何连接mqtt?
AT组件使用问题
官方AT客户端应用笔记的几个小tip
RTT的SAL能够判断使用LWIP或者AT?
rt_therad AT组件移植不成功(结贴)
AT组件在哪个版本的?
AT组件 连接 Onenet 连接失败
esp8266 AT指令 MQTT连接问题
AT组件使用问题之模块主动上报【已解决】
基于RT-Thread的STM32F4开发第三讲——DAC
Wireshark抓包EtherCAT报文
820
