Devices
RTT Audio驱动,mic和sound的使用问题
发布于 2019-02-22 11:37:25 浏览:2197
```int rt_hw_audio_init(char *i2c_bus_name) { rt_hw_sound_hw_init(i2c_bus_name); rt_hw_micphone_init(i2c_bus_name); return RT_EOK; }``` audio设备初始化时,是写入相应的i2c名称吗? ```int stm32f4_i2c_init(void) { struct rt_i2c_bus_device *bus; bus = rt_malloc(sizeof(struct rt_i2c_bus_device)); if (bus == RT_NULL) { rt_kprintf("rt_malloc failed
"); return -RT_ENOMEM; } rt_memset((void *)bus, 0, sizeof(struct rt_i2c_bus_device)); bus->priv = (void *)&bit_ops; stm32f4_i2c_gpio_init(); rt_i2c_bit_add_bus(bus, "i2c0"); return RT_EOK; } INIT_DEVICE_EXPORT(stm32f4_i2c_init); ```我看I2C中注册的名称是i2c0,初始化时是写入int rt_hw_audio_init( "i2c0")吗?‘’ ```int rt_hw_micphone_init(char *i2c_bus_name) { int result = RT_EOK; struct micphone_device *mic = &micphone; if (mic->recv_fifo != RT_NULL) { return RT_EOK; } mic->recv_fifo = rt_malloc(AUDIO_RECV_BUFFER_SIZE); if (mic->recv_fifo == RT_NULL) { result = -RT_ENOMEM; goto __exit; } memset(mic->recv_fifo, 0, AUDIO_RECV_BUFFER_SIZE); mic->parent.type = RT_Device_Class_Sound; mic->parent.init = micphone_init; mic->parent.open = micphone_open; mic->parent.control = micphone_control; mic->parent.write = RT_NULL; mic->parent.read = micphone_read; mic->parent.close = micphone_close; mic->parent.user_data = mic; /* register the device */ rt_device_register(&mic->parent, "mic", RT_DEVICE_FLAG_RDONLY | RT_DEVICE_FLAG_DMA_RX); rt_device_init(&mic->parent); { rt_uint8_t *buffer = rt_malloc(AUDIO_RECV_BUFFER_SIZE); if (buffer == RT_NULL) { result = -RT_ENOMEM; goto __exit; } memset(buffer, 0, AUDIO_RECV_BUFFER_SIZE); rt_audio_pipe_init(&mic->record_pipe, "voice", RT_PIPE_FLAG_FORCE_WR | RT_PIPE_FLAG_BLOCK_RD, buffer, AUDIO_RECV_BUFFER_SIZE); } return RT_EOK; __exit: if (mic->recv_fifo) { rt_free(mic->recv_fifo); mic->recv_fifo = RT_NULL; } return result; }```mic设备使用时,也是先获取mic的句柄,然后再使用rt_device_write等函数吗?见下面的代码 ```struct micphone_device *mic = RT_NULL; mic =(struct micphone_device *)rt_device_find("mic");```mic设备使用时不需要再调用rt_device_init函数了吧?我看int rt_hw_micphone_init(char *i2c_bus_name)函数中已经使用了rt_device_init(&mic->parent);是已经使用过rt_device_init函数了吧?对audio设备的使用还不太熟悉,希望得到解答
kaisa666
2019-02-22
[i=s] 本帖最后由 kaisa666 于 2019-2-22 11:42 编辑 [/i] sound设备的初始化函数中有i2c设备查找的判断,mic设备中没有找到相应的语句,是否是bug? ``` int rt_hw_sound_hw_init(char *i2c_bus_name) { ... sound->i2c_device = rt_i2c_bus_device_find(i2c_bus_name); if (sound->i2c_device == RT_NULL) { LOG_E("i2c bus device %s not found!", i2c_bus_name); result = -RT_ENOSYS; goto __exit; } ```
2.2k
kaisa666
LCD双缓冲有什么好的办法实现
LCD NT35510 驱动代码
io设备驱动的疑惑与建议
液晶屏驱动 U8g2 移植
求助:在模板上添加LCD模块出现L6406E错误
hwtimer硬件定时器驱动和使用经验
硬件定时器超时时间计算问题
请教spi驱动lcd显示屏问题
新版OneNet的星火1号开发板例程适配(二)
重磅预售!RT-Trace调试工具
基于RT-Thread的STM32F4开发第五讲——软件模拟I2C
Pai同学
Rick98
河南理工大学恁带劲儿
