Kernel
使用rtt小内存管理,内存泄漏问题怎么定位
发布于 2018-12-23 20:05:32 浏览:2196
1.使用rtt小内存管理模块,代码中有较多的地方会使用到动态内存分配与释放,发生内存泄漏该怎么定位。 2.小内存管理模块 长时间运行程序是否会因为内存碎片而造成内存耗尽?
enmonster
2018-12-25
很多小内存,很奇怪,自己没有`rt_malloc`,不知道从哪里来的 ``` memtrace total memory: 119472 used memory : 46892 maximum allocated memory: 49968 memory heap address: heap_ptr: 0x20002d10 lfree : 0x20009a28 heap_end: 0x2001ffe0 --memory item information -- [0x20002d10 - 696] NONE [0x20002fe8 - 152] NONE [0x200030a0 - 4K] NONE [0x200040c0 - 48] NONE [0x20004110 - 48] NONE [0x20004160 - 48] NONE [0x200041b0 - 60] NONE [0x2000420c - 200] NONE [0x200042f4 - 60] NONE [0x20004350 - 40] NONE [0x20004398 - 60] NONE [0x200043f4 - 40] NONE [0x2000443c - 60] NONE [0x20004498 - 40] NONE [0x200044ReadCertInfo(): bank_id:8b240bb600010001000815d359ad0fe4 efo() 152] NONE [0x20004598 - 4K] NONE [0x200055b8 - 152] NONE [0x20005670 - 4K] NONE [0x20006690 - 152] NONE [0x20006748 - 4K] NONE [0x20007768 - 152] NONE [0x20007820 - 4K] NONE [0x20008840 - 88] tshell [0x200088b8 - 12] tran_task [0x200088e4 - 60] tran_task [0x20008940 - 120] tran_task [0x200089d8 - 12] tran_task [0x20008a04 - 60] tran_task [0x20008a60 - 20] tran_task [0x20008a94 - 24] tran_task [0x20008acc - 116] tran_task [0x20008b60 - 12] tran_task [0x20008b8c - 60] tran_task [0x20008be8 - 20] tran_task [0x20008c1c - 12] tran_task [0x20008c48 - 60] tran_task [0x20008ca4 - 20] tran_task [0x20008cd8 - 12] tran_task [0x20008d04 - 44] tran_task [0x20008d50 - 512] tran_task [0x20008f70 - 152] tran_task [0x20009028 - 2K] tran_task [0x20009848 - 12] tran_task [0x20009874 - 76] tran_task [0x200098e0 - 12] service_mc_task [0x2000990c - 44] service_mc_task [0x20009958 - 76] ota_thread [0x200099c4 - 68] ota_thread [0x20009a28 - 64] [0x20009a88 - 12] cad_task_hander [0x20009ab4 - 60] ota_thread [0x20009b10 - 60] [0x20009b6c - 68] TASK_EC20_TRANS [0x20009bd0 - 124] [0x20009c6c - 20] cad_task_hander [0x20009ca0 - 36] TASK_WG219_TRANS [0x20009ce4 - 116] tran_task [0x20009d78 - 12] tran_task [0x20009da4 - 60] tran_task [0x20009e00 - 40] tran_task [0x20009e48 - 12] tran_task [0x20009e74 - 60] tran_task [0x20009ed0 - 12] tran_task [0x20009efc - 24] tran_task [0x20009f34 - 176] tran_task [0x2000a004 - 12] tran_task [0x2000a030 - ReadCertInfo(): bank_id:2b9a86d5000100010009401b59ae0af1 6C] tran_task [0x2000a08c - 20] tran_task [0x2000a0c0 - 12] tran_task [0x2000a0ec - 44] tran_task [0x2000a138 - 12] tran_task [0x2000a164 - 44] tran_task [0x2000a1b0 - 512] tran_task [0x2000a3d0 - 152] tran_task [0x2000a488 - 2K] tran_task [0x2000aca8 - 84] tran_task [0x2000ad1c - 152] tran_task [0x2000add4 - 152] tran_task [0x2000ae8c - 152] tran_task [0x2000af44 - 28] cad_task_hander [0x2000af80 - 12] tran_task [0x2000afac - 60] tran_task [0x2000b008 - 40] tran_task [0x2000b050 - 12] tran_task [0x2000b07c - 60] tran_task [0x2000b0d8 - 12] tran_task [0x2000b104 - 2K] tran_task [0x2000b924 - 2K] tran_task [0x2000c144 - 4K] tran_task [0x2000d164 - 40] ota_thread [0x2000d1ac - 44] ota_thread [0x2000d1f8 - 12] ota_thread [0x2000d224 - 12] ota_thread [0x2000d250 - 16] ota_thread [0x2000d280 - 52] ota_thread [0x2000d2d4 - 32] cad_task_hander [0x2000d314 - 60] cad_task_hander [0x2000d370 - 40] cad_task_hander [0x2000d3b8 - 56] cad_task_hander [0x2000d410 - 24] cad_task_hander [0x2000d448 - 48] cad_task_hander [0x2000d498 - 32] cad_task_hander [0x2000d4d8 - 12] cad_task_hander [0x2000d504 - 60] cad_task_hander [0x2000d560 - 40] cad_task_hander [0x2000d5a8 - 32] cad_task_hander [0x2000d5e8 - 12] cad_task_hander [0x2000d614 - 60] cad_task_hander [0x2000d670 - 40] cad_task_hander [0x2000d6b8 - 12] ota_thread [0x2000d6e4 - 44] ota_thread [0x2000d730 - 56] cad_task_hander [0x2000d788 - 24] cad_task_hander [0x2000d7c0 - 48] cad_task_hander [0x2000d810 - 40] cad_task_hander [0x2000d858 - 36] cad_task_hander [0x2000d89c - 12] ota_thread [0x2000d8c8 - 68] ota_thread [0x2000d92c - 40] cad_task_hander [0x2000d974 - 16] cad_task_hander [0x2000d9a4 - 40] cad_task_hander [0x2000d9ec - 40] cad_task_hander [0x2000da34 - 12] cad_task_hander [0x2000da60 - 12] cad_task_hander [0x2000da8c - 40] cad_task_hander [0x2000dad4 - 12] cad_task_hander [0x2000db00 - 44] cad_task_hander [0x2000db4c - 40] ota_thread [0x2000db94 - 16] ota_thread [0x2000dbc4 - 40] ota_thread [0x2000dc0c - 12] ota_thread [0x2000dc38 - 68] ota_thread [0x2000dc9c - 36] cad_task_hander [0x2000dce0 - 40] cad_task_hander [0x2000dd28 - 12] ota_thread [0x2000dd54 - 16] ota_thread [0x2000dd84 - 12] ota_thread [0x2000ddb0 - 12] cad_task_hander [0x2000dddc - 40] cad_task_hander [0x2000de24 - 12] cad_task_hander [0x2000de50 - 40] cad_task_hander [0x2000de98 - 12] cad_task_hander [0x2000dec4 - 40] cad_task_hander [0x2000df0c - 12] cad_task_hander [0x2000df38 - 40] cad_task_hander [0x2000df80 - 12] cad_task_hander [0x2000dfac - 40] cad_task_hander [0x2000dff4 - 12] cad_task_hander [0x2000e020 - 40] cad_task_hander [0x2000e068 - 12] cad_task_hander [0x2000e094 - 40] ota_thread [0x2000e0dc - 40] ota_thread [0x2000e124 - 12] ota_thread [0x2000e150 - 44] [0x2000e19c - 40] cad_task_hander [0x2000e1e4 - 40] cad_task_hander [0x2000e22c - 40] cad_task_hander [0x2000e274 - 12] cad_task_hander [0x2000e2a0 - 40] cad_task_hander [0x2000e2e8 - 12] cad_task_hander [0x2000e314 - 60] cad_task_hander [0x2000e370 - 272] [0x2000e4a0 - 12] cad_task_hander [0x2000e4cc - 40] cad_task_hander [0x2000e514 - 12] cad_task_hander [0x2000e540 - 40] cad_task_hander [0x2000e588 - 12] cad_task_hander [0x2000e5b4 - 40] cad_task_hander [0x2000e5fc - 12] cad_task_hander [0x2000e628 - 40] cad_task_hander [0x2000e670 - 12] cad_task_hander [0x2000e69c - 40] cad_task_hander [0x2000e6e4 - 12] cad_task_hander [0x2000e710 - 70K] ```
yqiu
2018-12-25
可以试试 memtrace
enmonster
2018-12-25
>可以试试 memtrace --- 上面就用memtrace打出来的,很多小内存不知道咋出来的,线程里面不会分配这些小内存12字节40字节之类的
2018-12-23
信息很多,这个需要你来查了,例如在rt_malloc里判断是否是"tran_task"任务,大小是否是怀疑的。然后下断点,带着仿真器跑下来就知道是哪个地方分配的内存了
enmonster
2018-12-25
>信息很多,这个需要你来查了,例如在rt_malloc里判断是否是"tran_task"任务,大小是否是怀疑的。然后下断点 ... 非常感谢熊总,一下就定位出来了
2018-12-26
:handshake 多多分享经验
enmonster
2018-12-26
>多多分享经验 好的,后面写个贴子分享一下
2.2k
enmonster
cpu使用率分析
选择FreeRTOS, 还是RT-Thread。
thread heap stack overflow ?
rtt消息队列delay问题
释放被删除线程的内存地方在哪里啊
请教:各线程结束后,释放其中的内存的连续性问题
STM32F103中断关于信号量、邮箱问题
RTT中的线程栈大小如何控制
关于线程由执行态变为挂起态的代码实现,,,
浅谈国产加密芯片的选择
[Vision Board创客营] PWM模块实践
FRDM-MCXN947 I2C(软件)使用
1506
339
1423
281
740
161
540
157
1218
146
