问一个更改SConscript过程中SrcRemove使用错误的问题
发布于 2014-12-23 21:01:09 浏览:3248
[tocm] 各位,问一个SConscript相关的问题。 我用stm32f407的mcu,把库从1.0升级成1.3,由于最新的库里面有同时支持STM32F427 STM32437等,所以库里面多了sdram的文件stm32f4xx_fmc.c,我需要在SConscript里面通过判断使用的芯片类型去掉该文件的包含,最终库里面的SConscript文件如下 ``` Import('rtconfig') Import('RTT_ROOT') from building import * # get current directory cwd = GetCurrentDir() # The set of source files associated with this SConscript file. src = Split(""" CMSIS/Device/ST/STM32F4xx/Source/Templates/system_stm32f4xx.c """) src += Glob('STM32F4xx_StdPeriph_Driver/src/*.c') # 我添加的处理 # STM32F427_437xx STM32F429_439xx or STM32F40_41xxx STM32F401xx if (GetDepend('STM32F40_41xxx') == True) or (GetDepend('STM32F401xx') == True): SrcRemove(src, 'stm32f4xx_fmc.c') #add for startup script if rtconfig.CROSS_TOOL == 'gcc': src = src + ['CMSIS/Device/ST/STM32F4xx/Source/Templates/gcc_ride7/startup_stm32f40_41xxx.s'] elif rtconfig.CROSS_TOOL == 'keil': src = src + ['CMSIS/Device/ST/STM32F4xx/Source/Templates/arm/startup_stm32f40_41xxx.s'] elif rtconfig.CROSS_TOOL == 'iar': src = src + ['CMSIS/Device/ST/STM32F4xx/Source/Templates/iar/startup_stm32f40_41xxx.s'] path = [cwd + '/STM32F4xx_StdPeriph_Driver/inc', cwd + '/CMSIS/Device/ST/STM32F4xx/Include', cwd + '/CMSIS/Include'] CPPDEFINES = ['USE_STDPERIPH_DRIVER'] group = DefineGroup('STM32_StdPeriph', src, depend = [''], CPPPATH = path, CPPDEFINES = CPPDEFINES) Return('group') ``` 但是我scons 编译时出错,信息如下: ``` scons: warning: No version of Visual Studio compiler found - C/C++ compilers most likely not set correctly File "D:projectNETDATAPROCodeFWmodiSConstruct", line 36, in
TypeError: object of type 'File' has no len(): File "D:projectNETDATAPROCodeFWmodiSConstruct", line 39: objs = PrepareBuilding(env, RTT_ROOT, has_libcpu=False) File "D:projectNETDATAPROCodeFW t-thread oolsuilding.py", line 218: objs = SConscript('SConscript', variant_dir=bsp_vdir, duplicate=0) File "C:Python27Scripts..Libsite-packagesscons-2.3.4SConsScriptSConscript.py", line 614: return method(*args, **kw) File "C:Python27Scripts..Libsite-packagesscons-2.3.4SConsScriptSConscript.py", line 551: return _SConscript(self.fs, *files, **subst_kw) File "C:Python27Scripts..Libsite-packagesscons-2.3.4SConsScriptSConscript.py", line 260: exec _file_ in call_stack[-1].globals File "D:projectNETDATAPROCodeFWmodiSConscript", line 12: objs = objs + SConscript(os.path.join(d, 'SConscript')) File "C:Python27Scripts..Libsite-packagesscons-2.3.4SConsScriptSConscript.py", line 614: return method(*args, **kw) File "C:Python27Scripts..Libsite-packagesscons-2.3.4SConsScriptSConscript.py", line 551: return _SConscript(self.fs, *files, **subst_kw) File "C:Python27Scripts..Libsite-packagesscons-2.3.4SConsScriptSConscript.py", line 260: exec _file_ in call_stack[-1].globals File "D:projectNETDATAPROCodeFWmodiLibrariesSConscript", line 17: SrcRemove(src, 'stm32f4xx_fmc.c') File "D:projectNETDATAPROCodeFW t-thread oolsuilding.py", line 503: if os.path.basename(item) in remove: File "C:Python27Scripts..lib tpath.py", line 207: return split(p)[1] File "C:Python27Scripts..lib tpath.py", line 179: d, p = splitdrive(p) File "C:Python27Scripts..lib tpath.py", line 114: if len(p) > 1: ``` 由于对python 一窍不通,所以只能请求大家帮助了,谢谢。
grissiom
2014-12-23
改成 ``` SrcRemove(src, ['stm32f4xx_fmc.c']) ``` 试试?
chmh8981
2014-12-23
是我的项目的问题,我自前也改过SConscript文件,现在用一个全新的干净环境修改就没有这个问题,我先找找自己的错误出在哪里。 另外问一下,要学习SConscript相关的东西,怎么配置,有详细一点的资料吗?官方文档里的那一章感觉太简略了,scons的官网我好想没看到什么关于配置SConscript的说明文档,都是写的怎么编译的东西,也就是tool文件夹下的东西,感觉那个我没时间也没必要了解。
grissiom
2014-12-24
Scons, RTFM.
mail2li
2015-08-10
挖坟: 上周遇见和楼主雷同的问题,看了下SrcRemove的源码, ``` def SrcRemove(src, remove): if not src: return if type(src[0]) == type('str'): for item in src: if os.path.basename(item) in remove: src.remove(item) return …… ``` Glob() 的返回的列表内容的类型是 [SCons.Node.FS.File] 而我和楼主的代码中 先对src直接赋了一个内容为字串的列表,形成这样的列表: ['string', SCons.Node.FS.File, ……]这样列表中成员的类型有混杂,src[0] 是字串,所以跑到[i]if type(src[0]) == type('str'):[/i]的这段,然后因为后续的类型不匹配,出错踢掉了。 如果要避免这种情况的出现,不改SrcRemove源码的话, 可以先对 src=Glob(*.c) 赋值 然后删掉不需要的文件 再把指定的文件附加到src变量中。
3.2k
chmh8981
usb host读取u盘偶尔才能加载成功,读写失败的问题
10年开发后,我后悔坚持的8个技术信仰,不知你踩中几个
MCAX-156 ADC测评
【FRDM-MCXA156测评】- CherryUSB与hid鼠标设备模仿
【FRDM-MCXA156测评】- 硬件SPI模块
1520
813
178
554
