外部flash
FlashDB使用求助
发布于 2022-08-11 10:17:28 浏览:1100
最近一个项目需要用到外部flash存储日志,我根据论坛这个帖子实现了flashdb的使用,我项目的需求要使用tsdb来存储日志,我想着把四个例程都跑一下,但是在运行时出问题了,麻烦大佬们帮我看看是不是有啥参数没配置对,,, https://club.rt-thread.org/ask/article/349aa10c2052cd40.html 代码段 `````c /* * Copyright (c) 2006-2021, RT-Thread Development Team * * SPDX-License-Identifier: Apache-2.0 * * Change Logs: * Date Author Notes * 2022-07-13 lenovo the first version */ #include
#define FDB_LOG_TAG "flashdb" static uint32_t boot_count = 0; static time_t boot_time[10] = {0, 1, 2, 3}; /* default KV nodes */ static struct fdb_default_kv_node default_kv_table[] = { {"username", "armink", 0}, /* string KV */ {"password", "123456", 0}, /* string KV */ {"boot_count", &boot_count, sizeof(boot_count)}, /* int type KV */ {"boot_time", &boot_time, sizeof(boot_time)}, /* int array type KV */ }; /* KVDB object */ static struct fdb_kvdb kvdb = { 0 }; /* TSDB object */ struct fdb_tsdb _global_tsdb = { 0 }; /* counts for simulated timestamp */ static int counts = 0; extern void kvdb_basic_sample(fdb_kvdb_t kvdb); extern void kvdb_type_string_sample(fdb_kvdb_t kvdb); extern void kvdb_type_blob_sample(fdb_kvdb_t kvdb); extern void tsdb_sample(fdb_tsdb_t tsdb); static void lock(fdb_db_t db) { __disable_irq(); } static void unlock(fdb_db_t db) { __enable_irq(); } static fdb_time_t get_time(void) { /* Using the counts instead of timestamp. * Please change this function to return RTC time. */ return ++counts; } static int flashdb(void) { fdb_err_t result; #ifdef FDB_USING_KVDB { /* KVDB Sample */ struct fdb_default_kv default_kv; default_kv.kvs = default_kv_table; default_kv.num = sizeof(default_kv_table) / sizeof(default_kv_table[0]); /* set the lock and unlock function if you want */ fdb_kvdb_control(&kvdb, FDB_KVDB_CTRL_SET_LOCK, (void *)lock); fdb_kvdb_control(&kvdb, FDB_KVDB_CTRL_SET_UNLOCK, (void *)unlock); /* Key-Value database initialization * * &kvdb: database object * "env": database name * "fdb_kvdb1": The flash partition name base on FAL. Please make sure it's in FAL partition table. * Please change to YOUR partition name. * &default_kv: The default KV nodes. It will auto add to KVDB when first initialize successfully. * NULL: The user data if you need, now is empty. */ /* init函数的第三个参数,是用于存储数据的fal分区,大家根据自己的情况选择 */ result = fdb_kvdb_init(&kvdb, "env", "fdb_kvdb1", &default_kv, NULL); if (result != FDB_NO_ERR) { return -1; } else { /* 这部分例程在运行时会卡死 */ /* run basic KV samples */ kvdb_basic_sample(&kvdb); /* run string KV samples */ kvdb_type_string_sample(&kvdb); /* run blob KV samples */ kvdb_type_blob_sample(&kvdb); } } #endif /* FDB_USING_KVDB */ #ifdef FDB_USING_TSDB { /* TSDB Sample */ /* set the lock and unlock function if you want */ fdb_tsdb_control(&_global_tsdb, FDB_TSDB_CTRL_SET_LOCK, (void *)lock); fdb_tsdb_control(&_global_tsdb, FDB_TSDB_CTRL_SET_UNLOCK, (void *)unlock); /* Time series database initialization * * &tsdb: database object * "log": database name * "fdb_tsdb1": The flash partition name base on FAL. Please make sure it's in FAL partition table. * Please change to YOUR partition name. * get_time: The get current timestamp function. * 128: maximum length of each log * NULL: The user data if you need, now is empty. */ result = fdb_tsdb_init(&_global_tsdb, "log", "fdb_tsdb1", get_time, 128, NULL); /* read last saved time for simulated timestamp */ fdb_tsdb_control(&_global_tsdb, FDB_TSDB_CTRL_GET_LAST_TIME, &counts); if (result != FDB_NO_ERR) { return -1; } else{ /* run TSDB sample */ tsdb_sample(&_global_tsdb); } } #endif /* FDB_USING_TSDB */ return RT_EOK; } INIT_ENV_EXPORT(flashdb); ````` 原理图  运行截图1  运行截图2  运行截图3  运行截图4  这个是录制的gif图  [cj_csjtarget.rar](https://club.rt-thread.org/file_download/9218486fd79c2de6)
2022-08-11
学以致用
- 可以把 FlashDB 的 断言功能打开,可能断言了,也就是 `FDB_ASSERT` 可以使用 `RT_ASSERT` - 注意下各个线程栈的情况,是否足够
abcde1224
2022-08-15
问题解决了,sfud默认的频率是50Mhz,需要根据使用的flash修改spi最大速率的参数,我自己调整到了500k才正常工作了,注意这个速率在cubeMX配置spi接口时设置的那个分频是不起作用的,只有在这个地方修改才有效  再放一张正常运行的gif图
1.1k
abcde1224
程序分散加载到外部QSPI FLASH 启动问题
stm32f429如何下载程序到外部flash
安卓手机不能识别挂载w25q flash
rtthread stlink加载外部算法问题
flashdb kv value的最大字节
关于F1使用通用BOOT+片外FLASH升级SFUD初始化失败的问题
文件系统挂载到指定内存区域
ART-Pi的APP运行在外部Flash,那还能对内部flash进行读写操作吗?
外部flash是nm25q128挂载不上有大神指点嘛
挂载外部flash出现这个问题有大神解决吗
睿擎工业开发平台--CanOpen示例测试
【深度剖析】RT-Thread 线程调度流程
睿擎工业开发平台--I2C1驱动AMP2301读取温湿度
Ryan_CW
chejia12
纯白酱
530china
rv666
