硬件bug无处不在,M7内核r0p1版本的bug
发布于 2019-05-03 10:51:14 浏览:2227
此文转载与armfly论坛,原帖地址:[http://forum.armfly.com/forum.php?mod=viewthread&tid=93546&page=1&extra=#pid160632](http://forum.armfly.com/forum.php?mod=viewthread&tid=93546&page=1&extra=#pid160632) FreeRTOS: There are two options for running FreeRTOS on ARM Cortex-M7 microcontrollers. The best option depends on the revision of the ARM Cortex-M7 core in use. The revision is specified by an 'r' number, and a 'p' number, so will look something like 'r0p1'. Check the documentation for the microcontroller in use to find the revision of the Cortex-M7 core used in that microcontroller. If in doubt, use the FreeRTOS port provided specifically for r0p1 revisions, as that can be used with all core revisions. The first option is to use the ARM Cortex-M4F port, and the second option is to use the Cortex-M7 r0p1 port - the latter containing a minor errata workaround. If the revision of the ARM Cortex-M7 core is not r0p1 then either option can be used, but it is recommended to use the FreeRTOS ARM Cortex-M4F port located in the /FreeRTOS/Source/portable/RVDS/ARM_CM4F directory. If the revision of the ARM Cortex-M7 core is r0p1 then use the FreeRTOS ARM Cortex-M7 r0p1 port located in the /FreeRTOS/Source/portable/RVDS/ARM_CM7/r0p1 directory. 意思是说对于r0p1版本的bug,有一个专门的移植文件(有一个微小的修正),当然,这个文件可以用于所有M7内核,含已经解决此bug的高版本内核。 对于高版本M7内核,推荐使用M4F里面的移植文件。
2019-05-03
[table] [tr][td]uCOS: ;******************************************************************************************************** ; HANDLE PendSV EXCEPTION ; void OS_CPU_PendSVHandler(void) ; ; Note(s) : 1) PendSV is used to cause a context switch. This is a recommended method for performing ; context switches with Cortex-M. This is because the Cortex-M auto-saves half of the ; processor context on any exception, and restores same on return from exception. So only ; saving of R4-R11 & R14 is required and fixing up the stack pointers. Using the PendSV exception ; this way means that context saving and restoring is identical whether it is initiated from ; a thread or occurs due to an interrupt or exception. ; ; 2) Pseudo-code is: ; a) Get the process SP ; b) Save remaining regs r4-r11 & r14 on process stack; ; c) Save the process SP in its TCB, OSTCBCurPtr->OSTCBStkPtr = SP; ; d) Call OSTaskSwHook(); ; e) Get current high priority, OSPrioCur = OSPrioHighRdy; ; f) Get current ready thread TCB, OSTCBCurPtr = OSTCBHighRdyPtr; ; g) Get new process SP from TCB, SP = OSTCBHighRdyPtr->OSTCBStkPtr; ; h) Restore R4-R11 and R14 from new process stack; ; i) Perform exception return which will restore remaining context. ; ; 3) On entry into PendSV handler: ; a) The following have been saved on the process stack (by processor): ; xPSR, PC, LR, R12, R0-R3 ; b) Processor mode is switched to Handler mode (from Thread mode) ; c) Stack is Main stack (switched from Process stack) ; d) OSTCBCurPtr points to the OS_TCB of the task to suspend ; OSTCBHighRdyPtr points to the OS_TCB of the task to resume ; ; 4) Since PendSV is set to lowest priority in the system (by OSStartHighRdy() above), we ; know that it will only be run when no other exception or interrupt is active, and ; therefore safe to assume that context being switched out was using the process stack (PSP). ; ; 5) Increasing priority using a write to BASEPRI does not take effect immediately. ; (a) IMPLICATION This erratum means that the instruction after an MSR to boost BASEPRI ; might incorrectly be preempted by an insufficient high priority exception. ; ; (b) WORKAROUND The MSR to boost BASEPRI can be replaced by the following code sequence: ; ; CPSID i ; MSR to BASEPRI ; DSB ; ISB ; CPSIE i ;******************************************************************************************************** OS_CPU_PendSVHandler CPSID I ; Cortex-M7 errata notice. See Note #5 MOV32 R2, OS_KA_BASEPRI_Boundary ; Set BASEPRI priority level required for exception preemption LDR R1, [R2] MSR BASEPRI, R1 DSB ISB CPSIE I[/td][/tr] [/table]
2019-05-05
关注
2.2k
29
1218
146
