PIN_GPIO通用驱动
touch_屏幕触摸
系统中断
touch驱动使能引脚中断无法触发
发布于 2025-04-21 11:13:20 浏览:85
```C static void touch(void *param) { struct rt_touch_data data[GT911_MAX_TOUCH]; rt_size_t point_num; static rt_uint32_t touch_count = 0; /* 查找触摸设备 */ touch_dev = rt_device_find("gt911"); rt_kprintf("flag1\n"); if (touch_dev == RT_NULL) { rt_kprintf("[GT911] Error: Touch device not found!\n"); return -1; } rt_kprintf("flag2\n"); /* 打开触摸设备 */ if (rt_touch_open(touch_dev, RT_DEVICE_FLAG_INT_RX) != RT_EOK) { rt_kprintf("[GT911] Error: Open device failed!\n"); return -1; } rt_kprintf("flag3\n"); rt_uint16_t x = 240; if (rt_touch_control(touch_dev, RT_TOUCH_CTRL_SET_X_RANGE, &x) != RT_EOK) { rt_kprintf("[GT911] Error: Set x failed!\n"); return -1; } rt_uint16_t y = 320; if (rt_touch_control(touch_dev, RT_TOUCH_CTRL_SET_Y_RANGE, &y) != RT_EOK) { rt_kprintf("[GT911] Error: Set y failed!\n"); return -1; } rt_kprintf("flag4\n"); // 信号量 touch_sem = rt_sem_create("tsem", 0, RT_IPC_FLAG_PRIO); if (touch_sem == RT_NULL) { LOG_E("create dynamic semaphore failed.\n"); } if (rt_device_set_rx_indicate(touch_dev, touch_handler) != RT_EOK) { rt_kprintf("[GT911] Error: Set int handler failed!\n"); } if (rt_touch_control(touch_dev, RT_TOUCH_CTRL_ENABLE_INT, RT_NULL) != RT_EOK) { rt_kprintf("[GT911] Error: Enable int failed!\n"); } /* 获取触摸屏信息 */ struct rt_touch_info info; if (rt_touch_control(touch_dev, RT_TOUCH_CTRL_GET_INFO, &info) != RT_EOK) { rt_kprintf("[GT911] Error: Get touch info failed!\n"); return -1; } rt_kprintf("\n[GT911] Touch screen test start\n"); rt_kprintf("type :%d\n", info.type); /* 类型:电容型/电阻型*/ rt_kprintf("vendor :%s\n", info.vendor); /* 厂商 */ rt_kprintf("point_num :%d\n", info.point_num); /* 支持的触点个数 */ rt_kprintf("range_x :%d\n", info.range_x); /* X 轴分辨率 */ rt_kprintf("range_y :%d\n", info.range_y); /* Y 轴分辨率*/ rt_kprintf("[GT911] Press any point to test, press ESC to exit\n\n"); gt911_thread = rt_thread_create("gt911", touch_callback, RT_NULL, 1024, 15, 10); if (gt911_thread != RT_NULL) { rt_thread_startup(gt911_thread); } //rt_touch_t touch_dev_1 = rt rt_touch_irq_init((rt_touch_t)touch_dev); rt_touch_irq_enable((rt_touch_t)touch_dev); return 0; } ``` 以上为我创建的测试触摸的线程入口函数,使用open和control都使能了引脚中断,甚至在结尾又使用rt_touch_irq_init再次初始化了引脚中断,但是这个中断仍无法触发,给中断引脚手动输入高低电平也无法触发。 跪求大佬指点迷津
85
DXJF_5992
在RTT下使用普通IO口模拟串口时序,如何才能做到不被系统干扰?
系统在什么时候开启中断
在系统初始化之前一定要关中断吗,如果中断开启,系统会紊乱吗?
rt-thread 定时器 HARD_TIMER 模式 中断
Rt-thread的系统中断在哪里开启
bug反馈:中断号有问题
在中断环境下进行线程的切换,from线程的R4-R11为何不保存
在操作系统的下,进入中断后,使用rt_interrupt_enter还是 关闭中断呢?
完成量的使用,rt_completion_done()函数可以在中断里调用吗?
RTThread-nano在C66xDSP上的移植问题
睿擎派RK3506开发板开箱记录&初步调试
睿擎工业开发平台rk3506常用外设功能评测
RT-Thread BSP支持玄铁全系列RISC-V内核啦
ubuntu20搭建rtthead5.2.0开发环境
BitsButton嵌入式按键处理框架
