drv_eth_以太网驱动
使用rtt 2.0版本 stm32f107 mac用KSZ8041NL,需要改驱动吗?
发布于 2014-12-07 00:26:09 浏览:6099
用的stm32f107,rtt用2.0版本,mac用KSZ8041NL,MII模式,CPU晶振8M,KSZ8041NL用有源晶振25M。 ```c /* STM32F107 ETH dirver options */ #define CHECKSUM_BY_HARDWARE 1 /* 0: disable. 1: use hardware checksum. */ #define RMII_MODE 0 /* 0: MII MODE, 1: RMII MODE. */ #define STM32_ETH_IO_REMAP 1 /* 0: default, 1: remap RXD to PDx. */ #define USE_MCO 0 /* 0: disable, 1: PA8(MCO) out 25Mhz(MII) or 50Mhz(RMII). */ ``` 这里的配置已经如上改好。 编译后下载,ping 不通目标板。 是不是还有哪里要改?
2014-12-07
把checksum hardware定义成0试试
kerrhu
2014-12-07
>把checksum hardware定义成0试试 改了还是不行。 我改动的地方有: ```c #if !defined HSE_VALUE #ifdef STM32F10X_CL #define HSE_VALUE ((uint32_t)8000000) /*!< Value of the External oscillator in Hz */ //这里把mcu晶振由25000000改为 8000000 #else #define HSE_VALUE ((uint32_t)8000000) /*!< Value of the External oscillator in Hz */ #endif /* STM32F10X_CL */ #endif /* HSE_VALUE */ ``` -------------------------------- ```c /* STM32F107 ETH dirver options */ #define CHECKSUM_BY_HARDWARE 0 /* 0: disable. 1: use hardware checksum. */ #define RMII_MODE 0 /* 0: MII MODE, 1: RMII MODE. */ #define STM32_ETH_IO_REMAP 1 /* 0: default, 1: remap RXD to PDx. */ #define USE_MCO 0 /* 0: disable, 1: PA8(MCO) out 25Mhz(MII) or 50Mhz(RMII). */ //@k 1 ``` ------------------------------------- 就改动了这两个地方。 还有其他地方需要改吗? phy初始化部分需要改吗?
kerrhu
2014-12-10
```c /* Configure PLLs ------------------------------------------------------*/ /* PLL2 configuration: PLL2CLK = (HSE / 5) * 8 = 40 MHz */ /* PREDIV1 configuration: PREDIV1CLK = PLL2 / 5 = 8 MHz */ RCC->CFGR2 &= (uint32_t)~(RCC_CFGR2_PREDIV2 | RCC_CFGR2_PLL2MUL | RCC_CFGR2_PREDIV1 | RCC_CFGR2_PREDIV1SRC); //RCC->CFGR2 |= (uint32_t)(RCC_CFGR2_PREDIV2_DIV5 | RCC_CFGR2_PLL2MUL8 | // RCC_CFGR2_PREDIV1SRC_PLL2 | RCC_CFGR2_PREDIV1_DIV5); //@k /* PLL2 configuration: PLL2CLK = (HSE / 2) * 10 = 40 MHz */ /* PREDIV1 configuration: PREDIV1CLK = PLL2 / 5 = 8 MHz */ //@k RCC->CFGR2 |= (uint32_t)(RCC_CFGR2_PREDIV2_DIV2 | RCC_CFGR2_PLL2MUL10 | RCC_CFGR2_PREDIV1SRC_PLL2 | RCC_CFGR2_PREDIV1_DIV5); ``` 系统时钟这里也改了,还是不行。 是不是硬件问题?软件应该不需要改了吧?
zchong
2014-12-10
PHY地址可能要修改
kerrhu
2014-12-11
>PHY地址可能要修改 --- 我的phy硬件地址是默认的0x01,在FINSH模式下,用串口软件调用void phy_dump(int addr)这个函数,可以读出phy寄存器的值,用这个void phy_search(void)函数查了下,phy地址确实是1,广播地址 0x00,也可以的。 另外,我奇怪的是rtt网络初始化代码里面怎么没有写MACMIIDR寄存器的代码??? 也没有选择phy寄存器地址然后写入MACMIIAR寄存器的代码,只有ETH_Init(ETH_InitTypeDef* ETH_InitStruct)函数里读出MACMIIAR的值然后回写的操作,也就是说用的是MAC默认初始化的phy地址? 请大神们多指导啊
2014-12-11
PHY的工作状态基本通过手册上要求的上下拉电阻就可以配置好,一般是自动协商。 现在99.9%都是100M全双工,所以程序默认当100M全双工处理。 如果你设计硬件时没注意这个,可以dump出PHY的寄存器跟PHY的数据手册对比一下。 MAC不用跟PHY打交道 如果要使用PHY的特殊功能,或是要支持10M,半双工,或是网线插拔通知等,是需要跟PHY打交道的。 1. 使用phy_dump检查PHY是否连接上,速率和双工模式是多少?并检查 2. 检查MII/RMII设置,以及IO配置 3. PC上面使用抓包,EMAC的驱动里面打开dump 4. list_if()看看IP地址是否跟电脑同个网段
kerrhu
2014-12-11
>PHY的工作状态基本通过手册上要求的上下拉电阻就可以配置好,一般是自动协商。 >现在99.9%都是100M全双工,所以程序默认当100M全双工处理。 >如果你设计硬件时没注意这个,可以dump出PHY的寄存器跟PHY的数据手册对比一下。 > >MAC不用跟PHY打交道 >如果要使用PHY的特殊功能,或是要支持10M,半双工,或是网线插拔通知等,是需要跟PHY打交道的。 > >1. 使用phy_dump检查PHY是否连接上,速率和双工模式是多少?并检查 >2. 检查MII/RMII设置,以及IO配置 >3. PC上面使用抓包,EMAC的驱动里面打开dump >4. list_if()看看IP地址是否跟电脑同个网段 --- ========== 1,使用phy_dump可以读出PHY寄存器值,速率100M,全双工 2,MII以及IO配置需要哪里改?按道理我帖子上面配置了啊,使能了STM32_ETH_IO_REMAP 1 3,这个什么意思?需要哪里打开? 4,我的电脑和板用网线直连的,电脑IP和板IP网段一致
kerrhu
2014-12-22
打开 ETHARP_DEBUG 调试信息,PC发PING的时候,串口打印出如下调试信息。但PC端ping不通目标板。是什么 问题? 看这个日志,好像没有进入这个函数: `etharp_send_ip(netif, p, (struct eth_addr*)(netif->hwaddr), ethaddr);` 还有,`type:86dd` ,怎么会有这个类型?好像是乱码。 ------------------------------打印日志如下-------------------------- ``` etharp_timer ethernet_input: dest:ff:ff:ff:ff:ff:ff, src:b8:88:e3:3b:65:61, type:806 etharp_update_arp_entry: 192.168.1.123 - b8:88:e3:3b:65:61 etharp_find_entry: found matching entry 0 etharp_update_arp_entry: updating stable entry 0 etharp_arp_input: incoming ARP request etharp_arp_input: replying to ARP request for our IP address ethernet_input: dest:33:33:00:01:00:02, src:b8:88:e3:3b:65:61, type:86dd ethernet_input: dest:33:33:00:00:00:0c, src:b8:88:e3:3b:65:61, type:86dd ethernet_input: dest:ff:ff:ff:ff:ff:ff, src:b8:88:e3:3b:65:61, type:806 etharp_update_arp_entry: 192.168.1.123 - b8:88:e3:3b:65:61 etharp_find_entry: found matching entry 0 etharp_update_arp_entry: updating stable entry 0 etharp_arp_input: incoming ARP request etharp_arp_input: replying to ARP request for our IP address ethernet_input: dest:ff:ff:ff:ff:ff:ff, src:b8:88:e3:3b:65:61, type:806 etharp_update_arp_entry: 192.168.1.123 - b8:88:e3:3b:65:61 etharp_find_entry: found matching entry 0 etharp_update_arp_entry: updating stable entry 0 etharp_arp_input: incoming ARP request etharp_arp_input: replying to ARP request for our IP address etharp_timer ethernet_input: dest:33:33:00:00:00:0c, src:b8:88:e3:3b:65:61, type:86dd etharp_timer ethernet_input: dest:33:33:00:00:00:0c, src:b8:88:e3:3b:65:61, type:86dd ```
6.1k
kerrhu
21
SPI总线挂接2个W5500以太网芯片
用studio开发ETH设备时drv_eth.c不参与编译
STM32H743 以太网驱动 问题
关于在drv_eth.c中如何强制PHY工作
如何在rt-thread工作过程中切换IP地址获取模式(静态IP或者动态IP)
w5500_socket错误
STM32H743 LAN8720A
rt bthread studio不支持stm32H7系列的cpu 以太网驱动
studio生成stm32h7工程,drv_eth.c编译不过,如何解?
LWIP配置一直ping不同
RT-Thread BSP支持玄铁全系列RISC-V内核啦
ubuntu20搭建rtthead5.2.0开发环境
BitsButton嵌入式按键处理框架
art-pi2 上手记录(二)
