stm32f207ve+spi+dma驱动求帮助
发布于 2016-09-08 18:51:15 浏览:3633
这几天在调试spi dma驱动,flash是sst25vf016b,直接while读写都没有问题,但是dma就是不行, 搞了几天没有思路来,希望有高手有空帮忙看看代码指点一下。 ``` #include
/* 定义操作SST25VF016B所需的数据 */ typedef enum ERTYPE{Sec1,Sec8,Sec16,Chip} ErType; typedef enum IDTYPE{Manu_ID,Dev_ID,Jedec_ID} idtype; DMA_InitTypeDef SPIDMA_InitStructure; static int dma_lock = 1; uint8_t rx_buffer[128],tx_buffer[128]={1,2,3,4,5,6,7,8,9,0,0,9,8,7,6,5,4,3,2,1}; /* Private define ------------------------------------------------------------*/ #define MAX_ADDR 0x1FFFFF /* 定义芯片内部最大地址 */ #define SEC_MAX 511 /* 定义最大扇区号 */ #define SEC_SIZE 0x1000 /* 扇区大小 */ #define DMA_FLAG_ALL5 (DMA_FLAG_FEIF5|DMA_FLAG_DMEIF5|DMA_FLAG_TEIF5|DMA_FLAG_TCIF5) #define DMA_FLAG_ALL0 (DMA_FLAG_FEIF0|DMA_FLAG_DMEIF0|DMA_FLAG_TEIF0|DMA_FLAG_TCIF0) #define DMA_IT_ALL (DMA_IT_TC|DMA_IT_TE|DMA_IT_DME|DMA_IT_TE) #define SST_SPI_DMA_Channel DMA_Channel_0 #define SST_SPI_RX_DMA_Stream DMA1_Stream0 #define SST_SPI_RX_DMA_IRQ DMA1_Stream0_IRQn #define SST_SPI_RX_DMA_FLAG DMA_IT_TCIF0 #define SST_SPI_TX_DMA_Stream DMA1_Stream5 #define SST_SPI_TX_DMA_IRQ DMA1_Stream5_IRQn #define SST_SPI_TX_DMA_FLAG DMA_IT_TCIF5 #define SST_SPI_DR_Address (uint32_t)(SPI3_BASE+0x0C) //SPI片选 #define SPI_FLASH_CS_LOW() {GPIO_ResetBits(GPIOC, GPIO_Pin_2);} #define SPI_FLASH_CS_HIGH() {GPIO_SetBits(GPIOC, GPIO_Pin_2);} void dump_spi3(void) { rt_kprintf("SPI register: "); rt_kprintf("CR1: %04x ",SPI3->CR1); rt_kprintf("CR2: %04x ",SPI3->CR2); rt_kprintf("SR: %04x ",SPI3->SR); rt_kprintf("DR: %04x ",SPI3->DR); rt_kprintf("CRCPR: %04x ",SPI3->CRCPR); rt_kprintf("RXCRCR: %04x ",SPI3->RXCRCR); rt_kprintf("TXCRCR: %04x ",SPI3->TXCRCR); rt_kprintf("I2SCFGR:%04x ",SPI3->I2SCFGR); rt_kprintf("I2SPR: %04x ",SPI3->I2SPR); } void dump_dma_rxtx(DMA_Stream_TypeDef* DMAy_Streamx) { rt_kprintf("CR: %08x ",DMAy_Streamx->CR); rt_kprintf("NDTR:%08x ",DMAy_Streamx->NDTR); rt_kprintf("PAR: %08x ",DMAy_Streamx->PAR); rt_kprintf("M0AR:%08x ",DMAy_Streamx->M0AR); rt_kprintf("M1AR:%08x ",DMAy_Streamx->M1AR); rt_kprintf("FCR: %08x ",DMAy_Streamx->FCR); } void dump_dma(void) { rt_kprintf("DMA register: "); rt_kprintf("LISR: %08x ",DMA1->LISR); rt_kprintf("HISR: %08x ",DMA1->HISR); rt_kprintf("LIFCR:%08x ",DMA1->LIFCR); rt_kprintf("HIFCR:%08x ",DMA1->HIFCR); rt_kprintf("TXStream register: "); dump_dma_rxtx(SST_SPI_TX_DMA_Stream); rt_kprintf("RXStream register: "); dump_dma_rxtx(SST_SPI_RX_DMA_Stream); } void dump_reg(void) { dump_spi3(); dump_dma(); } /******************************************************************************* * Function Name : SPI_FLASH_Init * Description : 初始化控制SSI的管脚 * Input : None * Output : None * Return : None * Attention : None *******************************************************************************/ void spi_dma_flash_init(void) { SPI_InitTypeDef SPI_InitStructure; GPIO_InitTypeDef GPIO_InitStructure; NVIC_InitTypeDef NVIC_InitStructure; // Enable SPI and GPIO clocks RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI3, ENABLE); RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC, ENABLE); GPIO_PinAFConfig(GPIOC,GPIO_PinSource10,GPIO_AF_SPI3); GPIO_PinAFConfig(GPIOC,GPIO_PinSource11,GPIO_AF_SPI3); GPIO_PinAFConfig(GPIOC,GPIO_PinSource12,GPIO_AF_SPI3); //SPI口初始化 Set PC10,11,12 as Output push-pull - SCK, MISO and MOSI GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10 | GPIO_Pin_11 | GPIO_Pin_12; GPIO_Init(GPIOC, &GPIO_InitStructure); RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC, ENABLE); //使能GPIO的时钟 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL; GPIO_Init(GPIOC, &GPIO_InitStructure); SPI_FLASH_CS_HIGH(); //拉高片选信号 /* SPI Config -------------------------------------------------------------*/ SPI_DeInit(SPI3); SPI_Cmd(SPI3, DISABLE); SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex; SPI_InitStructure.SPI_Mode = SPI_Mode_Master; SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b; SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low; SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge; SPI_InitStructure.SPI_NSS = SPI_NSS_Soft; SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_64; SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB; SPI_InitStructure.SPI_CRCPolynomial = 7; SPI_Init(SPI3, &SPI_InitStructure); SPI_I2S_DMACmd(SPI3, SPI_I2S_DMAReq_Rx, ENABLE); SPI_I2S_DMACmd(SPI3, SPI_I2S_DMAReq_Tx, ENABLE); /* Enable SPI3 */ SPI_Cmd(SPI3, ENABLE); dump_spi3(); /* Configure and enable I2C1 DMA interrupt -------------------------------*/ NVIC_InitStructure.NVIC_IRQChannel = SST_SPI_RX_DMA_IRQ; NVIC_Init(&NVIC_InitStructure); NVIC_InitStructure.NVIC_IRQChannel = SST_SPI_TX_DMA_IRQ; NVIC_Init(&NVIC_InitStructure); /* Enable the DMA1 clock */ RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA1, ENABLE); /* SPI3 TX DMA Channel configuration */ DMA_Cmd(SST_SPI_RX_DMA_Stream, DISABLE); DMA_DeInit(SST_SPI_RX_DMA_Stream); SPIDMA_InitStructure.DMA_Channel = SST_SPI_DMA_Channel; SPIDMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)SST_SPI_DR_Address; SPIDMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)0; /* This parameter will be configured durig communication */ SPIDMA_InitStructure.DMA_BufferSize = 0; /* This parameter will be configured durig communication */ SPIDMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory; SPIDMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; SPIDMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; SPIDMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte; SPIDMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte; SPIDMA_InitStructure.DMA_Mode = DMA_Mode_Normal; SPIDMA_InitStructure.DMA_Priority = DMA_Priority_VeryHigh; SPIDMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable; SPIDMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull; SPIDMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single; SPIDMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single; DMA_Init(SST_SPI_RX_DMA_Stream, &SPIDMA_InitStructure); DMA_ITConfig( SST_SPI_RX_DMA_Stream, DMA_IT_ALL, ENABLE); rt_kprintf("RXStream register: "); dump_dma_rxtx(SST_SPI_RX_DMA_Stream); /* SPI3 RX DMA Channel configuration */ DMA_Cmd(SST_SPI_TX_DMA_Stream, DISABLE); DMA_DeInit(SST_SPI_TX_DMA_Stream); SPIDMA_InitStructure.DMA_DIR = DMA_DIR_MemoryToPeripheral; SPIDMA_InitStructure.DMA_Mode = DMA_Mode_Normal; DMA_Init(SST_SPI_TX_DMA_Stream, &SPIDMA_InitStructure); DMA_ITConfig( SST_SPI_TX_DMA_Stream, DMA_IT_ALL, ENABLE); rt_kprintf("TXStream register: "); dump_dma_rxtx(SST_SPI_TX_DMA_Stream); rt_kprintf("spi_dma_flash_init "); } void spi_dma_start(DMA_Stream_TypeDef* DMAy_Streamx, uint8_t* pBuffer, uint32_t BufferSize) { SPIDMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)pBuffer; /* This parameter will be configured durig communication */ SPIDMA_InitStructure.DMA_BufferSize = BufferSize; /* This parameter will be configured durig communication */ DMA_Init(DMAy_Streamx, &SPIDMA_InitStructure); DMA_Cmd(DMAy_Streamx, ENABLE); dma_lock = 1; } /******************************************************************************* * Function Name : Flash_ReadWriteByte * Description : 通过硬件SPI发送一个字节到SST25VF016B * Input : - data: 发送的数据 * Output : None * Return : SST25VF016B 返回的数据 * Attention : None *******************************************************************************/ static uint8_t flash_read_write(uint8_t data) { /* Loop while DR register in not emplty */ while (SPI_I2S_GetFlagStatus(SPI3, SPI_I2S_FLAG_TXE) == RESET); /* Send byte through the SPI3 peripheral */ SPI_I2S_SendData(SPI3, data); /* Wait to receive a byte */ while (SPI_I2S_GetFlagStatus(SPI3, SPI_I2S_FLAG_RXNE) == RESET); /* Return the byte read from the SPI bus */ return SPI_I2S_ReceiveData(SPI3); } void DMA1_Stream0_IRQHandler(void) { rt_interrupt_enter(); if (DMA_GetITStatus(SST_SPI_RX_DMA_Stream, DMA_IT_TCIF0)) { rt_kprintf("RXTC "); DMA_Cmd(SST_SPI_RX_DMA_Stream, DISABLE); } else rt_kprintf("Unknow S0 IRQ "); /* clear DMA flag */ DMA_ClearFlag(SST_SPI_RX_DMA_Stream, DMA_FLAG_ALL0); rt_interrupt_leave(); dma_lock = 0; } void DMA1_Stream5_IRQHandler(void) { rt_interrupt_enter(); if (DMA_GetITStatus(SST_SPI_TX_DMA_Stream, DMA_IT_TCIF5)) { rt_kprintf("TXTC "); DMA_Cmd(SST_SPI_TX_DMA_Stream, DISABLE); } else rt_kprintf("Unknow S5 IRQ "); /* clear DMA flag */ DMA_ClearFlag(SST_SPI_TX_DMA_Stream, DMA_FLAG_ALL5); rt_interrupt_leave(); dma_lock = 0; } uint8_t sst_dma_rd(uint32_t Dst, uint8_t* RcvBufPt ,uint32_t NByte) { // uint32_t wait = 10; SPI_InitTypeDef SPI_InitStructure; if ((Dst+NByte > MAX_ADDR)||(NByte == 0)) return (ERROR); /* 检查入口参数 */ SPI_FLASH_CS_LOW(); flash_read_write(0x0B); /* 发送读命令 */ flash_read_write(((Dst & 0xFFFFFF) >> 16)); /* 发送地址信息:该地址由3个字节组成 */ flash_read_write(((Dst & 0xFFFF) >> 8)); flash_read_write(Dst & 0xFF); flash_read_write(0xFF); /* 发送一个哑字节以读取数据 */ dump_reg(); spi_dma_start(SST_SPI_RX_DMA_Stream,RcvBufPt,NByte); spi_dma_start(SST_SPI_TX_DMA_Stream,tx_buffer,NByte); while(dma_lock) rt_thread_delay(1); SPI_FLASH_CS_HIGH(); dump_reg(); return (ENABLE); } uint8_t sst_dma_wr(uint32_t Dst, uint8_t* SndbufPt,uint32_t NByte) { uint8_t temp = 0,StatRgVal = 0; uint32_t i = 0; if (( (Dst+NByte-1 > MAX_ADDR)||(NByte == 0) )) { return (ERROR); /* 检查入口参数 */ } SPI_FLASH_CS_LOW(); flash_read_write(0x05); /* 发送读状态寄存器命令 */ temp = flash_read_write(0xFF); /* 保存读得的状态寄存器值 */ SPI_FLASH_CS_HIGH(); SPI_FLASH_CS_LOW(); flash_read_write(0x50); /* 使状态寄存器可写 */ SPI_FLASH_CS_HIGH(); SPI_FLASH_CS_LOW(); flash_read_write(0x01); /* 发送写状态寄存器指令 */ flash_read_write(0); /* 清0BPx位,使Flash芯片全区可写 */ SPI_FLASH_CS_HIGH(); for(i = 0; i < NByte; i++) { SPI_FLASH_CS_LOW(); flash_read_write(0x06); /* 发送写使能命令 */ SPI_FLASH_CS_HIGH(); SPI_FLASH_CS_LOW(); flash_read_write(0x02); /* 发送字节数据烧写命令 */ flash_read_write((((Dst+i) & 0xFFFFFF) >> 16)); /* 发送3个字节的地址信息 */ flash_read_write((((Dst+i) & 0xFFFF) >> 8)); flash_read_write((Dst+i) & 0xFF); flash_read_write(SndbufPt*); /* 发送被烧写的数据 */ SPI_FLASH_CS_HIGH(); do { SPI_FLASH_CS_LOW(); flash_read_write(0x05); /* 发送读状态寄存器命令 */ StatRgVal = flash_read_write(0xFF); /* 保存读得的状态寄存器值 */ SPI_FLASH_CS_HIGH(); } while (StatRgVal == 0x03 ); /* 一直等待,直到芯片空闲 */ } SPI_FLASH_CS_LOW(); flash_read_write(0x06); /* 发送写使能命令 */ SPI_FLASH_CS_HIGH(); SPI_FLASH_CS_LOW(); flash_read_write(0x50); /* 使状态寄存器可写 */ SPI_FLASH_CS_HIGH(); SPI_FLASH_CS_LOW(); flash_read_write(0x01); /* 发送写状态寄存器指令 */ flash_read_write(temp); /* 恢复状态寄存器设置信息 */ SPI_FLASH_CS_HIGH(); return (ENABLE); } void sst_dma_read(int len) { int i; if(len >= 128){ rt_kprintf("there is no enough buffer. "); } sst_dma_rd(0,rx_buffer,len); rx_buffer[len] = 0; //rt_kprintf("%d bytes:%s ",len,buffer); rt_kprintf("%d bytes:",len); for(i = 0; i < len; i++) rt_kprintf("%x",rx_buffer*); rt_kprintf(" **"); } extern uint8_t SSTF016B_Erase(uint32_t sec1, uint32_t sec2); void sst_dma_write(char *str) { int len; len = strlen(str); SSTF016B_Erase(0, len/SEC_SIZE + 1); sst_dma_wr(0, str, len); rt_kprintf("write finish. "); } #ifdef RT_USING_FINSH #include
FINSH_FUNCTION_EXPORT(dump_reg, read spi register); FINSH_FUNCTION_EXPORT(sst_dma_read, read SST25 data); FINSH_FUNCTION_EXPORT(sst_dma_write, write SST25 data); #endif ```
sitence
2016-09-08
这分别是初始化,dma前,dma后三个时段寄存器的值 ``` SPI register: ------初始化 CR1: 036c CR2: 0003 SR: 0002 DR: 0000 CRCPR: 0007 RXCRCR: 0000 TXCRCR: 0000 I2SCFGR:0000 I2SPR: 0002 RXStream register: CR: 00030416 NDTR:00000000 PAR: 40003c0c M0AR:00000000 M1AR:00000000 FCR: 00000021 TXStream register: CR: 00030456 NDTR:00000000 PAR: 40003c0c M0AR:00000000 M1AR:00000000 FCR: 00000021 spi_dma_flash_init finsh>>sst_dma_read(9) SPI register: -----------启动DMA前 CR1: 036c CR2: 0003 SR: 0002 DR: 00ff CRCPR: 0007 RXCRCR: 0000 TXCRCR: 0000 I2SCFGR:0000 I2SPR: 0002 DMA register: LISR: 00000000 HISR: 00000000 LIFCR:00000000 HIFCR:00000000 TXStream register: CR: 00030456 NDTR:00000000 PAR: 40003c0c M0AR:00000000 M1AR:00000000 FCR: 00000021 RXStream register: CR: 00030416 NDTR:00000000 PAR: 40003c0c M0AR:00000000 M1AR:00000000 FCR: 00000021 RXTC ----------产生了tx rx完成的中断 TXTC SPI register: ----dma完成后 CR1: 036c CR2: 0003 SR: 0043 DR: 0061 CRCPR: 0007 RXCRCR: 0000 TXCRCR: 0000 I2SCFGR:0000 I2SPR: 0002 DMA register: LISR: 00000010 HISR: 00000400 LIFCR:00000000 HIFCR:00000000 TXStream register: CR: 00030456 NDTR:00000000 PAR: 40003c0c M0AR:20000070 M1AR:00000000 FCR: 00000021 RXStream register: CR: 00030456 NDTR:00000000 PAR: 40003c0c M0AR:20002990 M1AR:00000000 FCR: 00000021 9 bytes:000000000 ---------- ``` -结果不对,正确值是“abcdef……”26个字母
sitence
2016-09-08
系统刚启动后,用while循环的代码去读,可以读到正确值,这说明spi的初始化应该没有问题,就是不知道和dma关联的问题出自哪里
2016-09-08
/rt-thread_git_fork/bsp/stm32f40x/drivers/stm32f20x_40x_spi.c /rt-thread_git_fork/components/drivers/spi/spi_flash_sst25vfxx.c
sitence
2016-09-08
aozima君,github上的master和stable分支上都没有看到stm32f20x_40x_spi.c这个文件呢, spi_flash_sst25vfxx.c只是上层的封装,没有底层的实现。 [https://github.com/RT-Thread/rt-thread/tree/stable-v2.1.x/bsp/stm32f40x/drivers](https://github.com/RT-Thread/rt-thread/ ... 0x/drivers)
2016-09-08
这里有:[https://github.com/RT-Thread/ART/tree/master/software/platform/drivers](https://github.com/RT-Thread/ART/tree/master/software/platform/drivers) 具体到板子,请参考: platform.c
sitence
2016-09-08
>这里有:[https://github.com/RT-Thread/ART/tree/master/software/platform/drivers](https://github.com/RT-Thread/ART/tree/master/software/platform/drivers) > >具体到板子,请参考: platform.c --- 多谢,我也在realtouch的源码里面找到了 [s:175]
fxf509
2016-12-09
SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_64?分频搞大点,试试
3.6k
sitence
BBB的SPI驱动
求个SPI上挂两个或多个设备的使用例子
SPI设备有个bug
SPI驱动
请教rt_spi_configure函数理解
SPI FLASH挂载的问题
SPI-FLASH 文件系统 SPIFFS
求助一个完整的 spi flash 驱动
关于同时使用文件系统与SPI FLASH的问题
STM32内存扩展,SRAM-RMC
