关于SPI flash的elm文件系统
发布于 2013-07-26 17:50:28 浏览:8944
最近在调试spi flash的elm文件系统,发现一些问题; 1、rtthread系统用的是1.2.0beta版本;spiflash型号如打印信息, ``` | / - RT - Thread Operating System / | 1.2.0 build Jul 26 2013 2006 - 2013 Copyright by rt-thread team lwIP-1.4.1 initialized! AT45DB041D detection rtc is not configured please configure with set_date and set_time RTC Reconfig RCC BDCR = 0x8103 RTC TAFCR = 0x0 BKP SRAM write OK Fri Mar 18 08:00:00 2011 finsh />File System initialzation failed!``` 此时提示elm文件系统加载失败,输入格式化命令mkfs("elm","flash0")可以格式化成功 ```finsh />mkfs("elm","flash0") 0, 0x00000000``` 按realtouch的说明,此时reset系统后应该可以mount成功,但是还是提示mount失败,可重新格式化,但是无法加载,这是问题1 ``` | / - RT - Thread Operating System / | 1.2.0 build Jul 26 2013 2006 - 2013 Copyright by rt-thread team lwIP-1.4.1 initialized! AT45DB041D detection Fri Mar 18 08:00:15 2011 finsh />File System initialzation failed! ``` 2、rt-thread文件从github下载最新代码,替换后 ``` | / - RT - Thread Operating System / | 1.2.0 build Jul 26 2013 2006 - 2013 Copyright by rt-thread team lwIP-1.4.1 initialized! AT45DB041D detection rtc is not configured please configure with set_date and set_time RTC Reconfig RCC BDCR = 0x8103 RTC TAFCR = 0x0 BKP SRAM write OK Fri Mar 18 08:00:00 2011 finsh />File System initialzation failed!``` 此时输入格式化命令,无法格式化;提示错误,这是问题2 ```format error -5, 0xfffffffb``` 3、spi驱动程序spi_flash_at45dbxx是aozima写的,应该没有问题,于是下载了RealTouch_20121210_release工程包进行验证; ``` | / - RT - Thread Operating System / | 1.1.0 build Jul 26 2013 2006 - 2012 Copyright by rt-thread team TCP/IP initialized! AT45DB041D detection finsh />File System initialzation failed!``` 输入格式化命令提示格式化OK ```finsh />mkfs("elm","flash0") 0, 0x00000000``` reset后提示加载正常,文件测试什么的都OK; ``` | / - RT - Thread Operating System / | 1.1.0 build Jul 26 2013 2006 - 2012 Copyright by rt-thread team TCP/IP initialized! AT45DB041D detection finsh />flash0 mount to / ``` 此时发现另外一个问题,ST407 reset软复位和硬件复位都提示加载正常,但是掉电重新上电后却提示加载失败,需要重新格式化才能加载成功,请问有遇到类似的问题吗? 下个星期准备仔细看一下这些问题,有消息了再来汇报。
chenytscut
2013-07-29
挂载不成功,但使用device_test("flash0")测试驱动,信息如下,貌似驱动是OK的; 另外device_test("flash0")必须是在没有mount的情况下才能测试; ``` | / - RT - Thread Operating System / | 1.2.0 build Jul 29 2013 2006 - 2013 Copyright by rt-thread team lwIP-1.4.1 initialized! AT45DB041D detection Fri Mar 18 08:39:13 2011 finsh>>File System initialzation failed! device_test("flash0") block device! device info: sector size : 256 byte sector count : 2048 block size : 2048 byte device R/W test pass! RT_TICK_PER_SECOND:100 continuous single sector speed test: write: <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< write 200 sector from 499 to 718, 22.83Kbyte/s read : >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> read 200 sector from 719 to 726, 714.28Kbyte/s random single sector speed test: write: <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< write 200 sector from 727 to 942, 23.25Kbyte/s read : >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> read 200 sector from 942 to 949, 714.28Kbyte/s multiple sector speed test write: <<<<<<<<<< multiple write 2 sector speed : 20.83Kbyte/s read : >>>>>>>>>> multiple read 2 sector speed : 500.0Kbyte/s write: <<<<<<<<<< multiple write 4 sector speed : 21.27Kbyte/s read : >>>>>>>>>> multiple read 4 sector speed : 500.0Kbyte/s write: <<<<<<<<<< multiple write 8 sector speed : 20.83Kbyte/s read : >>>>>>>>>> multiple read 8 sector speed : 666.66Kbyte/s write: <<<<<<<<<< multiple write 16 sector speed : 21.5Kbyte/s read : >>>>>>>>>> multiple read 16 sector speed : 666.66Kbyte/s write: <<<<<<<<<< multiple write 32 sector speed : 20.77Kbyte/s read : >>>>>>>>>> multiple read 32 sector speed : 666.66Kbyte/s write: <<<<<<<<<< multiple write 64 sector speed : 20.96Kbyte/s read : >>>>>>>>>> multiple read 64 sector speed : 695.65Kbyte/s write: <<<<<<<<<< multiple write 128 sector speed : 20.94Kbyte/s read : >>>>>>>>>> multiple read 128 sector speed : 711.11Kbyte/s 0, 0x00000000 finsh>> ``` 验证驱动OK,排除了驱动问题; 对系统做mkfs,显示可以格式化,但是reset后还是显示无法挂载,如下所示 ``` finsh>>mkfs("elm","flash0") 0, 0x00000000 finsh>>reset()? | / - RT - Thread Operating System / | 1.2.0 build Jul 29 2013 2006 - 2013 Copyright by rt-thread team lwIP-1.4.1 initialized! AT45DB041D detection Fri Mar 18 09:38:21 2011 finsh>>File System initialzation failed! ```
2013-07-29
github的版本有些问题,上午刚修复了,你可以重新测试下。
chenytscut
2013-07-29
>github的版本有些问题,上午刚修复了,你可以重新测试下。 --- 已在github下载最新rtthread程序测试: 问题依旧,可以MKFS,reset后无法mount; 单步调试发现,在Ff.c line1989中该条件成立 ``` if (LD_WORD(&fs->win[BS_55AA]) != 0xAA55) /* Check record signature (always placed at offset 510 even if the sector size is >512) */ return 2; ``` 于是在Ff.c line2080 返回FR_NO_FILESYSTEM ``` if (fmt) return FR_NO_FILESYSTEM; /* No FAT volume is found */ ``` 跳转至以下条件成立,mount不成功, ``` /* call mount of this filesystem */ else if (ops->mount(fs, rwflag, data) < 0) { /* close device */ if (dev_id != RT_NULL) rt_device_close(fs->dev_id); /* mount failed */ dfs_lock(); /* clear filesystem table entry */ rt_memset(fs, 0, sizeof(struct dfs_filesystem)); dfs_unlock(); rt_free(fullpath); return -1; } ```
chenytscut
2013-09-08
已测AT45DB161是ok的,AT45DB041不行,问题待查。
apingrtt
2015-03-31
我今天在做SPI Flash时,楼主遇到的问题一样,return 2的条件成立,导致挂载不成功。我用的Flash 是SST25VF016B,不知楼主的问题解决否?
apingrtt
2015-03-31
在我刚刚把SST25VF016B芯片更换成25Q64FV后,更改了IC厂商代码后 ``` / * JEDEC Manufacturer??s ID */ #define MF_ID (0xEF) ``` 并注销了下面代码后,编译下载后第一挂载失败,mkfs("elm","flash0")后,挂载成功 ``` /*else if(memory_type_capacity == MTC_SST25VF016B) { FLASH_TRACE("SST25VF016B detection "); spi_flash_device.geometry.sector_count = 512; }*/ else { FLASH_TRACE("Memory Capacity error! "); return -RT_ENOSYS; } } ``` 终端输出: ``` | / - RT - Thread Operating System / | 1.2.2 build Mar 31 2015 2006 - 2013 Copyright by rt-thread team W25Q64BV or W25Q64CV detection finsh />flash0 mount to /. ```
armink
2016-10-16
>我今天在做SPI Flash时,楼主遇到的问题一样,return 2的条件成立,导致挂载不成功。我用的Flash 是SST25VF016B,不知楼主的问题解决否? --- 很明显,楼主那个是 SPI Flash 驱动的问题,写入和读取的不一致,所以文件系统检查写入的关键词 55AA 没有通过。 你这个估计也是一样的问题。SST 的 SPI Flash 使用是 AAI 写模式,要注意地址与写入大小 2 字节对齐的问题。可以试试我新提交的采用 SFUD 库 SPI Flash 驱动,这方面都做了严格的测试。 最后还要注意硬件问题,前些日子我也遇到过,写入偶尔会不正常,修改硬件后才稳定。所以出现这个问题,优先进行 Flash 读写正确性测试。新增的 SFUD 库,可以通过 SF 命令来测试。
weiyuliang
2017-12-17
SFUD 库 赞一个
Learn
2020-09-16
请问楼主RealTouch_20121210_release这个工程包在哪下载的?
8.9k
chenytscut
搞懂rt-thread对STM32的GPIO操作
rt-thread 挂载romfs与ramfs
smart启动流程详解
小内存管理(1)--- 内存初始化
aeniac
zhuzhuzhu
