串口DMA接收
bsp中stm32串口dma接收
发布于 2021-07-13 09:47:08 浏览:1094
rtt关于stm32的bsp,不支持dma接收吗? 分析过程如下: ```c rt_inline int _serial_dma_rx(struct rt_serial_device *serial, rt_uint8_t *data, int length) { rt_base_t level; RT_ASSERT((serial != RT_NULL) && (data != RT_NULL)); level = rt_hw_interrupt_disable(); if (serial->config.bufsz == 0) { int result = RT_EOK; struct rt_serial_rx_dma *rx_dma; rx_dma = (struct rt_serial_rx_dma*)serial->serial_rx; RT_ASSERT(rx_dma != RT_NULL); if (rx_dma->activated != RT_TRUE) { rx_dma->activated = RT_TRUE; RT_ASSERT(serial->ops->dma_transmit != RT_NULL); serial->ops->dma_transmit(serial, data, length, RT_SERIAL_DMA_RX); } else result = -RT_EBUSY; rt_hw_interrupt_enable(level); if (result == RT_EOK) return length; rt_set_errno(result); return 0; } else { struct rt_serial_rx_fifo *rx_fifo = (struct rt_serial_rx_fifo *) serial->serial_rx; rt_size_t recv_len = 0, fifo_recved_len = rt_dma_calc_recved_len(serial); RT_ASSERT(rx_fifo != RT_NULL); if (length < (int)fifo_recved_len) recv_len = length; else recv_len = fifo_recved_len; if (rx_fifo->get_index + recv_len < serial->config.bufsz) rt_memcpy(data, rx_fifo->buffer + rx_fifo->get_index, recv_len); else { rt_memcpy(data, rx_fifo->buffer + rx_fifo->get_index, serial->config.bufsz - rx_fifo->get_index); rt_memcpy(data + serial->config.bufsz - rx_fifo->get_index, rx_fifo->buffer, recv_len + rx_fifo->get_index - serial->config.bufsz); } rt_dma_recv_update_get_index(serial, recv_len); rt_hw_interrupt_enable(level); return recv_len; } } ``` 上述代码,当bufsz==0,则dma直接将数据拷贝到用户buf,如果bufsz != 0,则从接收fifo拷贝数据。但是: 问题1:bufsz!=0时候,第一次dma传输的发起是从哪里发起的呢? 另外,当bufsz==0时候,调用了 `serial->ops->dma_transmit(serial, data, length, RT_SERIAL_DMA_RX);` 提供的驱动如下: ```c static rt_size_t stm32_dma_transmit(struct rt_serial_device *serial, rt_uint8_t *buf, rt_size_t size, int direction) { struct stm32_uart *uart; RT_ASSERT(serial != RT_NULL); RT_ASSERT(buf != RT_NULL); uart = rt_container_of(serial, struct stm32_uart, serial); if (size == 0) { return 0; } if (RT_SERIAL_DMA_TX == direction) { if (HAL_UART_Transmit_DMA(&uart->handle, buf, size) == HAL_OK) { return size; } else { return 0; } } return 0; } ``` 并没有关于RT_SERIAL_DMA_RX这种情况的处理,所以 问题2:这个stm32 bsp的串口驱动程序是不是还没有完全支持dma接收呢?
123
2021-07-13
先说结论,是支持的。 _serial_dma_rx 里面调用了serial->ops->dma_transmit(serial, data, length, RT_SERIAL_DMA_RX); 其实这个只是一个标志,真正对接到底层驱动时候,由于DMA接收是在中断中完成的,不是主动接收的,所以这个接口`stm32_dma_transmit` 并没有用到`RT_SERIAL_DMA_RX`这个标志。真正接收的地方是这三个中断里: ```c 1. IDLE中断 uart_isr() { #ifdef RT_SERIAL_USING_DMA else if ((uart->uart_dma_flag) && (__HAL_UART_GET_FLAG(&(uart->handle), UART_FLAG_IDLE) != RESET) && (__HAL_UART_GET_IT_SOURCE(&(uart->handle), UART_IT_IDLE) != RESET)) { level = rt_hw_interrupt_disable(); recv_total_index = serial->config.bufsz - __HAL_DMA_GET_COUNTER(&(uart->dma_rx.handle)); recv_len = recv_total_index - uart->dma_rx.last_index; uart->dma_rx.last_index = recv_total_index; rt_hw_interrupt_enable(level); if (recv_len) { rt_hw_serial_isr(serial, RT_SERIAL_EVENT_RX_DMADONE | (recv_len << 8)); } __HAL_UART_CLEAR_IDLEFLAG(&uart->handle); } } 2. 接收完成回调 void HAL_UART_RxCpltCallback(UART_HandleTypeDef *huart); 3. 接收半完成回调 void HAL_UART_RxHalfCpltCallback(UART_HandleTypeDef *huart); ``` 最后的数据处理是在 `rt_hw_serial_isr` 的 `RT_SERIAL_EVENT_RX_DMADONE` 里面进行的。
1.1k
arminker
串口DMA发送数据时,数据被覆盖
关于串口DMA模式下rt_device_close问题
finsh 控制台 适配 RS 485请大神指点????
串口无法接受数据,但可以发送
串口如何有效的清除掉接收缓冲,而不必一个一个的去读取
串口接收使用方式问题
雅特力FINSH问题
