IMX.RT1052
tinyusb
RT1052利用keil编译器移植tinyusb出现的问题
发布于 2021-09-24 20:45:00 浏览:1959
最近需要利用RT1052实现U盘功能,打算直接使用tinyusb,按照教程导入src后,出现了以下报错: ``` “error "Compiler attribute porting is required"”, ``` 报错文件为:`tinyusb\src\common\tusb_compiler.h`, 报错部分代码为: ```c // TODO refactor since __attribute__ is supported across many compiler #if defined(__GNUC__) #define TU_ATTR_ALIGNED(Bytes) __attribute__ ((aligned(Bytes))) #define TU_ATTR_SECTION(sec_name) __attribute__ ((section(#sec_name))) #define TU_ATTR_PACKED __attribute__ ((packed)) #define TU_ATTR_WEAK __attribute__ ((weak)) #define TU_ATTR_ALWAYS_INLINE __attribute__ ((always_inline)) #define TU_ATTR_DEPRECATED(mess) __attribute__ ((deprecated(mess))) // warn if function with this attribute is used #define TU_ATTR_UNUSED __attribute__ ((unused)) // Function/Variable is meant to be possibly unused #define TU_ATTR_USED __attribute__ ((used)) // Function/Variable is meant to be used #define TU_ATTR_PACKED_BEGIN #define TU_ATTR_PACKED_END #define TU_ATTR_BIT_FIELD_ORDER_BEGIN #define TU_ATTR_BIT_FIELD_ORDER_END // Endian conversion use well-known host to network (big endian) naming #if __BYTE_ORDER__ == __ORDER_LITTLE_ENDIAN__ #define TU_BYTE_ORDER TU_LITTLE_ENDIAN #else #define TU_BYTE_ORDER TU_BIG_ENDIAN #endif #define TU_BSWAP16(u16) (__builtin_bswap16(u16)) #define TU_BSWAP32(u32) (__builtin_bswap32(u32)) // List of obsolete callback function that is renamed and should not be defined. // Put it here since only gcc support this pragma #pragma GCC poison tud_vendor_control_request_cb #elif defined(__TI_COMPILER_VERSION__) #define TU_ATTR_ALIGNED(Bytes) __attribute__ ((aligned(Bytes))) #define TU_ATTR_SECTION(sec_name) __attribute__ ((section(#sec_name))) #define TU_ATTR_PACKED __attribute__ ((packed)) #define TU_ATTR_WEAK __attribute__ ((weak)) #define TU_ATTR_ALWAYS_INLINE __attribute__ ((always_inline)) #define TU_ATTR_DEPRECATED(mess) __attribute__ ((deprecated(mess))) // warn if function with this attribute is used #define TU_ATTR_UNUSED __attribute__ ((unused)) // Function/Variable is meant to be possibly unused #define TU_ATTR_USED __attribute__ ((used)) #define TU_ATTR_PACKED_BEGIN #define TU_ATTR_PACKED_END #define TU_ATTR_BIT_FIELD_ORDER_BEGIN #define TU_ATTR_BIT_FIELD_ORDER_END // __BYTE_ORDER is defined in the TI ARM compiler, but not MSP430 (which is little endian) #if ((__BYTE_ORDER__) == (__ORDER_LITTLE_ENDIAN__)) || defined(__MSP430__) #define TU_BYTE_ORDER TU_LITTLE_ENDIAN #else #define TU_BYTE_ORDER TU_BIG_ENDIAN #endif #define TU_BSWAP16(u16) (__builtin_bswap16(u16)) #define TU_BSWAP32(u32) (__builtin_bswap32(u32)) #elif defined(__ICCARM__) #include
#define TU_ATTR_ALIGNED(Bytes) __attribute__ ((aligned(Bytes))) #define TU_ATTR_SECTION(sec_name) __attribute__ ((section(#sec_name))) #define TU_ATTR_PACKED __attribute__ ((packed)) #define TU_ATTR_WEAK __attribute__ ((weak)) #define TU_ATTR_ALWAYS_INLINE __attribute__ ((always_inline)) #define TU_ATTR_DEPRECATED(mess) __attribute__ ((deprecated(mess))) // warn if function with this attribute is used #define TU_ATTR_UNUSED __attribute__ ((unused)) // Function/Variable is meant to be possibly unused #define TU_ATTR_USED __attribute__ ((used)) // Function/Variable is meant to be used #define TU_ATTR_PACKED_BEGIN #define TU_ATTR_PACKED_END #define TU_ATTR_BIT_FIELD_ORDER_BEGIN #define TU_ATTR_BIT_FIELD_ORDER_END // Endian conversion use well-known host to network (big endian) naming #if __BYTE_ORDER__ == __ORDER_LITTLE_ENDIAN__ #define TU_BYTE_ORDER TU_LITTLE_ENDIAN #else #define TU_BYTE_ORDER TU_BIG_ENDIAN #endif #define TU_BSWAP16(u16) (__iar_builtin_REV16(u16)) #define TU_BSWAP32(u32) (__iar_builtin_REV(u32)) #elif defined(__CCRX__) #define TU_ATTR_ALIGNED(Bytes) #define TU_ATTR_SECTION(sec_name) #define TU_ATTR_PACKED #define TU_ATTR_WEAK #define TU_ATTR_ALWAYS_INLINE #define TU_ATTR_DEPRECATED(mess) #define TU_ATTR_UNUSED #define TU_ATTR_USED #define TU_ATTR_PACKED_BEGIN _Pragma("pack") #define TU_ATTR_PACKED_END _Pragma("packoption") #define TU_ATTR_BIT_FIELD_ORDER_BEGIN _Pragma("bit_order right") #define TU_ATTR_BIT_FIELD_ORDER_END _Pragma("bit_order") // Endian conversion use well-known host to network (big endian) naming #if defined(__LIT) #define TU_BYTE_ORDER TU_LITTLE_ENDIAN #else #define TU_BYTE_ORDER TU_BIG_ENDIAN #endif #define TU_BSWAP16(u16) ((unsigned short)_builtin_revw((unsigned long)u16)) #define TU_BSWAP32(u32) (_builtin_revl(u32)) #else #error "Compiler attribute porting is required" #endif ``` 显示问题为:需要编译器属性移植。所以想问一下各位大佬有没有什么解决方法。
李肯陪你玩赚嵌入式
2021-10-09
精简下报错的头文件`tinyusb\src\common\tusb_compiler.h` ```c // TODO refactor since __attribute__ is supported across many compiler #if defined(__GNUC__) //GCC编译器 #elif defined(__TI_COMPILER_VERSION__) //TI编译器 #elif defined(__ICCARM__) //IAR EWARM编译器 #elif defined(__CCRX__) //这个__CCRX__不知道啥编译 #else //其他编译器都不支持 #error "Compiler attribute porting is required" #endif ``` 也就是你使用的交叉编译器不支持,需要自己对照着上面支持的交叉编译器的写法,重新实现下那几个宏定义。
2021-09-25
你用的啥交叉编译工具链?竟然不支持你的编译器。 如果有能力,自己修改一下,定义上面的那几个宏。
2021-09-25
rtdef.h里面有类似的宏,可以照着抄下。
所长
2021-09-29
巧了 我 也 在 移植 这个 USB 库, 使用 KEIL 编译器 , V5 编译 。楼主解决了吗?
2k
小啊小林宝
RT1061/1052 带 RTT + LWIP和LPSPI,有什么坑要注意吗?
SFUD无法探测到flash
rt1052 bootloader跳转需要注意啥
RTthread在RT1052上的文件系统挂载与卸载
野火imxrt1052的bsp中缺少drv_sdio.c文件
microPython移植到正点原子RT1052开发板出现问题
rt1052能支持ap6181的驱动吗
用野火的imx RT1052 EVK PRO 注册SPI Flash的问题
rt1052+rt_thread移植lwip一直ping不通
请问一下前辈野火rt1052在RT-Thread下的spi驱动应该怎样编写?
rt-thread 挂载romfs与ramfs
smart启动流程详解
小内存管理(1)--- 内存初始化
spi自动初始化程序
aeniac
zhuzhuzhu
YDPB_5935
