调度器
龙芯
龙芯BSP调度器和中断控制器存在设计缺陷
发布于 2021-10-22 12:09:09 浏览:1291
[tocm] ## 问题1 调度器问题,调度器调度时在rt_hw_context_switch中完成了上下文切换,然后直接切换到了to_thread线程,导致下面的rt_hw_interrupt_enable在切换线程前得不到执行(ARM架构中是执行rt_hw_interrupt_enable打开中断后在PENSV中完成了上下文切换)  ## 问题2 中断环境不是全局管理的,每个线程都有一个中断环境,通过测试日志可以看出来main线程中关闭了中断,系统依然还能正常调度(与问题1有关),在test_thread线程中读取中断发现中断为打开状态,而main线程中断为关闭状态 在mips架构的stack.c中发现每个线程栈都初始化了cp0_status,这个寄存器正是跟中断有关的寄存器   ```c rt_uint8_t *rt_hw_stack_init(void *tentry, void *parameter, rt_uint8_t *stack_addr, void *texit) { static rt_ubase_t wSR=0; static rt_ubase_t wGP; rt_uint8_t *stk; struct pt_regs *pt; rt_uint32_t i; /* Get stack aligned */ stk = (rt_uint8_t *)RT_ALIGN_DOWN((rt_ubase_t)stack_addr, 8); stk -= sizeof(struct pt_regs); pt = (struct pt_regs*)stk; #ifndef ARCH_MIPS64 for (i = 0; i < 8; ++i) { pt->pad0[i] = 0xdeadbeef; } #endif /* Fill Stack register numbers */ for (i = 0; i < 32; ++i) { pt->regs[i] = 0xdeadbeef; } pt->regs[REG_SP] = (rt_ubase_t)stk; pt->regs[REG_A0] = (rt_ubase_t)parameter; pt->regs[REG_GP] = (rt_ubase_t)$GP; pt->regs[REG_FP] = (rt_ubase_t)0x0; pt->regs[REG_RA] = (rt_ubase_t)texit; pt->hi = 0x0; pt->lo = 0x0; pt->cp0_status = (ST0_IE | ST0_CU0 | ST0_IM); #ifdef RT_USING_FPU pt->cp0_status |= (ST0_CU1 | ST0_FR); #endif pt->cp0_cause = read_c0_cause(); pt->cp0_epc = (rt_ubase_t)tentry; pt->cp0_badvaddr = 0x0; return stk; } ``` 测试代码: ``` #include
void test_thread(void* par) { while (1) { rt_kprintf("[%d] (%X) test_thread\n", rt_tick_get(), read_c0_status() & ST0_IE); rt_thread_mdelay(500); } } int main(int argc, char **argv) { rt_thread_t tid = RT_NULL; tid = rt_thread_create("test", test_thread, RT_NULL, 20480, 21, 20); if(tid) rt_thread_startup(tid); rt_kprintf("[%d] (%X) Hi, this is RT-Thread!!\n", rt_tick_get(), read_c0_status() & ST0_IE); rt_kprintf("rt_hw_interrupt_disable \n"); rt_hw_interrupt_disable(); while(1) { rt_kprintf("[%d] (%X) Hi, this is RT-Thread!!\n", rt_tick_get(), read_c0_status() & ST0_IE); rt_thread_mdelay(1000); } return 0; } ``` 测试日志截图:
2021-10-22
其它MIPS的分支也有这问题吗?
2021-10-23
好像没有问题
1.3k
不知名二五仔
使用CmBacktrace定位错误异常,请教分析原因
ARM9、raspberry-pi中断问题
内联函数不压栈,会因为中断导致栈内现场被破坏吗
rt_hw_context_switch_interrupt的逻辑
中断的入口程序在哪个文件里?
我想实现一个定时器中断,发现rt_hw_interrupt_install未定义
临界区和关中断,是否需要同时使用?
gpio 引脚一直进中断,请问怎么办呢?
RT-Thread那些API可以在中断程序中调用?
spi dma 中断接收的问题
【RSOC25】Day5 课程笔记:软件包相关知识
RT-Thread 夏令营 第五天笔记
【RSOC25】Day5 课程笔记:软件包和网络组件
【RSOC25】Day4 课程笔记:I/O设备和驱动框架
【RSOC25】Day3 课程笔记:线程间同步和通信
D1sguIse_
Ryan_CW
