ota_downloader软件包
qboot
qboot 修改fal_cfg,h中的FAL_FLASH_DEV_TABLE 后 跳转失败
发布于 2023-04-11 11:18:21 浏览:1323
1. 因为MCU FLASH有限,在移植了qboot后,发现没有足够的ROM空间放置download factory区 ,因板子上有TF卡,所以想在把两个partition放置TF中 ,按照@红枫大佬的文档移植 测试qboot功能正常后 我做了如下修改: - fal_cfg. 文件 ```c extern const struct fal_flash_dev tf_download_file; /* flash device table */ #define FAL_FLASH_DEV_TABLE \ { \ &stm32_onchip_flash_16k, \ &stm32_onchip_flash_64k, \ &stm32_onchip_flash_128k, \ &tf_download_file, \ } ``` - 仿照drv_flash_f4.c写了download partition部分的驱动代码 ```c #define DOWNLOARD_BIN_SIZE_MAX (7 * 128 * 1024) #define DOWNLOARD_BIN_START_ADRESS (0) static int fal_flash_read_download_bin(long offset, rt_uint8_t *buf, size_t size); static int fal_flash_write_download_bin(long offset, const rt_uint8_t *buf, size_t size); static int fal_flash_erase_download_bin(long offset, size_t size); static int fatfs_Init(void); const struct fal_flash_dev tf_download_file = { "tf_download_file", DOWNLOARD_BIN_START_ADRESS, DOWNLOARD_BIN_SIZE_MAX, (128 * 1024), {fatfs_Init, fal_flash_read_download_bin, fal_flash_write_download_bin, fal_flash_erase_download_bin} }; static int g_file_fd = -1; int file_download_read(rt_uint32_t addr, rt_uint8_t *buf, size_t size) { // size_t i; if ((addr + size) > DOWNLOARD_BIN_SIZE_MAX) { LOG_E("read outrange flash size! addr is (0x%p)", (void*)(addr + size)); return -1; } g_file_fd = open("/download.bin", O_RDONLY| O_CREAT); lseek(g_file_fd,(addr),SEEK_SET); if (g_file_fd > 0) { read(g_file_fd, buf, size); } close(g_file_fd); return size; } static int fal_flash_read_download_bin(long offset, rt_uint8_t *buf, size_t size) { return file_download_read(tf_download_file.addr + offset, buf, size); } int file_download_write(rt_uint32_t addr, const rt_uint8_t *buf, size_t size) { //size_t i; if ((addr + size) > DOWNLOARD_BIN_SIZE_MAX) { LOG_E("read outrange flash size! addr is (0x%p)", (void*)(addr + size)); return -1; } g_file_fd = open("/download.bin", O_WRONLY| O_CREAT); lseek(g_file_fd,(addr),SEEK_SET); if (g_file_fd > 0) { write(g_file_fd, buf, size); } close(g_file_fd); return size; } static int fal_flash_write_download_bin(long offset, const rt_uint8_t *buf, size_t size) { return file_download_write(tf_download_file.addr + offset, buf, size); } int file_download_erase(rt_uint32_t addr, size_t size) { size_t i; uint8_t erase_buf[512] ; i=(addr + size); if ((addr + size) > DOWNLOARD_BIN_SIZE_MAX) { LOG_E("read outrange flash size! addr is (0x%p)", (void*)(addr + size)); return -1; } g_file_fd = open("/download.bin", O_WRONLY| O_CREAT); lseek(g_file_fd,i,SEEK_SET); memset(erase_buf,0xff,512); if (g_file_fd > 0) { for (int var = 0; var < size/512; ++var) { write(g_file_fd, erase_buf, 512); i+=512; lseek(g_file_fd,i,SEEK_SET); } write(g_file_fd, erase_buf, size%512); } close(g_file_fd); return size; } static int fal_flash_erase_download_bin(long offset, size_t size) { return file_download_erase(tf_download_file.addr + offset, size); } static int fatfs_Init(void) { rt_thread_mdelay(1000); if (dfs_mount("sd0", "/", "elm", 0, 0) == 0) { rt_kprintf(" dfs mount ok \r\n"); } else { rt_kprintf(" dfs mount err \r\n"); } return 0; } ``` ```c - 然后运行发现 跳转失败 后测试发现 我只要 屏蔽FAL_FLASH_DEV_TABLE中我增加的 tf_download_file ,就能正常跳转,否则即便我全部使用片上FALSH也会跳转失败 ,我搜寻了 FAL_FLASH_DEV_TABLE,发现只在 fal_flash.c中文件使用了,并没有发现导致跳转失败的地方。请大佬帮忙分析一下原因
lchnu
2023-04-11
Witness, Understand, Skill
思路很秀,代码风格和功能看起来都ok。 1. 你指的跳转失败具体表现是什么?能否提供更多的信息? 2. 你在qboot bootloader中测试过文件的写入和读取功能吗? 3. 你提到全部使用片上Flash,是指download和factory都放在片上吗?这种情况下,即使没有使用tf,但只要它在FAL_FLASH_DEV_TABLE中也会出错?我的这个理解可对? 根据已有信息,我初步想到这几个小问题: 1. 在app中下载程序,一般在tshell线程下,或者根据你的逻辑在某个线程下。我看`file_download_erase`函数中有个临时数组为512字节,有没有可能你的线程栈崩了? 2. 在download和erase函数中,都用了O_CREAT,是否在download中添加O_APPEND会比较合理? 根据目前的信息只能推测出上述两个不成熟观点。 我的板子上也有板载TF卡,我对这个思路很感兴趣,欢迎进一步探讨。
红枫
2023-04-12
使用文件模拟成flash分区,实现了qboot到文件系统接口,做得很棒!👍 👍
iron_cdw
2023-04-11
各位 问题已解决 我用的是RT-Studio,编译优化等级 要选择 None(-O0)。 整个工程编译下来太大了 133K,所以选择 Optimize more(-O2)来缩小尺寸,没想到踩了一个大坑。目前的问题变成该如何优化固件尺寸。。。
Lrain
2024-05-20
 跳转过去,app区的程序不会运行了是为什么?
1.3k
iron_cdw
关于FAL移植
添加fal软件包之后编译出现错误,求助!
FAL驱动移植&构建脚本问题
帮我看一下这样分区会不会冲突??
EasyFlash 4.0疑似出BUG
疑似FAL日志输出与DFS冲突??
fal软件包偏移量大于等于当前分区的大小会报错
为什么片内Flash总是写失败?
片上flash的文件系统的建立
RT-Thread BSP支持玄铁全系列RISC-V内核啦
ubuntu20搭建rtthead5.2.0开发环境
BitsButton嵌入式按键处理框架
art-pi2 上手记录(二)
