uart_sample.c 中 ,uart_input()函数没有执行
发布于 2022-01-21 15:37:18 浏览:746
uart_sample.c 中 ,uart_input()函数没有执行,信号量发送不出,是什么原因
Sen
2022-01-21
#include "test_config.h" #include
#define UART_DEMO_TEST #ifdef UART_DEMO_TEST #define SAMPLE_UART_NAME "uart1" /* 用于接收消息的信号量*/ static struct rt_semaphore rx_sem; static rt_device_t serial; /* 接收数据回调函数*/ static rt_err_t uart_input(rt_device_t dev, rt_size_t size) { /* 串口接收到数据后产生中断, 调用此回调函数, 然后发送接收信号量*/ rt_kprintf("======= sem_release ! ======= \n"); rt_sem_release(&rx_sem); return RT_EOK; } static void serial_thread_entry(void *parameter) { char ch; /* 从串口读取一个字节的数据, 没有读取到则等待接收信号量*/ while (rt_device_read(serial, 0, &ch, 1) != 1) { /* 阻塞等待接收信号量, 等到信号量后再次读取数据*/ rt_kprintf("======= sem_take !! ======= \n"); rt_sem_take(&rx_sem, RT_WAITING_FOREVER); } rt_kprintf("======= ch++ ======= \n"); ch = ch + 1; rt_device_write(serial, 0, &ch, 1); } static int uart_sample(int argc, char *argv[]) { rt_err_t ret = RT_EOK; char uart_name[RT_NAME_MAX]; char str[] = "hello BK72xx!\r\n"; struct serial_configure config = RT_SERIAL_CONFIG_DEFAULT; if (argc == 2) { rt_strncpy(uart_name, argv[1], RT_NAME_MAX); } else { rt_strncpy(uart_name, SAMPLE_UART_NAME , RT_NAME_MAX); } /* 查找系统中的串口设备*/ serial = rt_device_find(uart_name); if (!serial) { rt_kprintf("find %s failed!\n", uart_name); return RT_ERROR; } rt_kprintf("========== test =========== \n"); rt_sem_init(&rx_sem, "rx_sem", 0, RT_IPC_FLAG_FIFO); /* 以中断接收及轮询发送模式打开串口设备*/ rt_device_open(serial, RT_DEVICE_FLAG_INT_RX); // rt_device_open(serial, RT_DEVICE_FLAG_INT_TX); /* 设置接收回调函数*/ ret = rt_device_set_rx_indicate(serial, uart_input); if(ret != RT_EOK){ rt_kprintf("rx_indicate failed !!"); } /* 设置配置参数 */ config.baud_rate = BAUD_RATE_115200; config.data_bits = DATA_BITS_8; config.stop_bits = STOP_BITS_1; config.parity = PARITY_NONE; config.bufsz = 2048; /*can not change buffer size, must be 2048*/ /* 打开设备后才可修改串口配置参数 */ rt_device_control(serial, RT_DEVICE_CTRL_CONFIG, &config); rt_device_write(serial, 0, str, (sizeof(str) - 1)); rt_thread_t thread = rt_thread_create("serial", serial_thread_entry , RT_NULL,1024, 25, 10); if (thread != RT_NULL) { rt_thread_startup(thread); } else { ret = RT_ERROR; } return ret; } /* 导出到msh 命令列表中*/ MSH_CMD_EXPORT(uart_sample, uart device sample); #endif
sync
2022-01-21
检查下串口引脚配置,是不是引脚没有使能串口接收?
746
Sen
rt thread 2.0.2 usart 接收缓存问题
关于STM32串口通信的问题
STM32F1+RTT串口接收终端数据丢失问题
UART TX丢数据?
RTT打开串口的时候如何自定义波特率呢?
STM32F4的USART数据接收问题
串口1234使用问题
串口接收回调函数
LPC18xx UART问题讨论
x1000串口配置的失败问题
睿擎工业开发平台---文件系统测试使用
睿擎工业开发平台--SPI使用和测四
睿擎工业开发平台--can总线使用测试
睿擎工业开发平台--如何将i2c1的引脚用于串口4
