Network
请教LWIP1.4.1和2.0.2对应用层表现的差异问题
发布于 2018-05-29 14:44:54 浏览:8737
我最近使用STM32F207跑一个LWIP,由于不懂LWIP,所以发现如下几个问题: 全部基于想同LWIP配置项的情况下对比。极个别项在不同版本可能需要关闭。 ```c #define RT_USING_LWIP // #define RT_USING_LWIP132 // #define RT_USING_LWIP141 #define RT_USING_LWIP202 #define RT_LWIP_ICMP // #define RT_LWIP_IGMP #define RT_LWIP_UDP #define RT_LWIP_TCP // #define RT_LWIP_DNS // #define RT_LWIP_SNMP // #define RT_LWIP_DHCP #ifdef RT_LWIP_DHCP #define IP_SOF_BROADCAST 1 #define IP_SOF_BROADCAST_RECV 1 #endif #define RT_MEMP_NUM_NETCONN 2 #define RT_LWIP_PBUF_NUM 6 #define RT_LWIP_RAW_PCB_NUM 2 #define RT_LWIP_UDP_PCB_NUM 2 #define RT_LWIP_TCP_PCB_NUM 2 #define RT_LWIP_TCP_SND_BUF 8192 #define RT_LWIP_TCP_WND 8192 #define RT_LWIP_TCPTHREAD_PRIORITY 3 #define RT_LWIP_TCPTHREAD_MBOX_SIZE 4 #define RT_LWIP_TCPTHREAD_STACKSIZE 1024 #define RT_LWIP_ETHTHREAD_PRIORITY 5 #define RT_LWIP_ETHTHREAD_MBOX_SIZE 4 #define RT_LWIP_ETHTHREAD_STACKSIZE 512 // #define SO_REUSE 1 #define LWIP_SO_RCVTIMEO 1 #define LWIP_SO_SNDTIMEO 1 #define LWIP_NETIF_LOOPBACK 0 ``` 1.LWIP2.0.2版本静态RAM占用差异很大 ``` 1.3.2:Program Size: Code=61200 RO-data=3228 RW-data=616 ZI-data=31672 1.4.1:Program Size: Code=77908 RO-data=4928 RW-data=592 ZI-data=30424 2.0.2:Program Size: Code=83972 RO-data=5764 RW-data=632 ZI-data=37288 ``` 2.基于同一份代码,仅仅开关LWIP的版本不一样,导致TCP client连接在1.4.1上连接不了。2.0.2版本上正常,并且压力测试两天了没有任何异常。 一下是LOG: 2.0.2log: ``` \ | / - RT - Thread Operating System / | \ 3.0.4 build May 29 2018 2006 - 2018 Copyright by rt-thread team eth_device_init success create phy thread successed eth hardware init sucess... eth hardware start success... lwIP-2.0.2 initialized! 192.168.1.30 network interface: e0 (Default) MTU: 1500 MAC: 00 80 e1 18 2a 25 FLAGS: UP LINK_DOWN ETHARP ip address: 192.168.1.30 gw address: 192.168.1.1 net mask : 255.255.255.0 link up 100Mbps full-duplex eth hardware init sucess... eth hardware start success... send total:1024 bytes, read total:1024 bytes send total:2048 bytes, read total:2048 bytes send total:3072 bytes, read total:3072 bytes send total:4096 bytes, read total:4096 bytes send total:5120 bytes, read total:5120 bytes send total:6144 bytes, read total:6144 bytes send total:7168 bytes, read total:7168 bytes ``` 1.4.1log: ``` \ | / - RT - Thread Operating System / | \ 3.0.4 build May 29 2018 2006 - 2018 Copyright by rt-thread team eth_device_init success create phy thread successed eth hardware init sucess... eth hardware start success... lwIP-1.4.1 initialized! 192.168.1.30 network interface: e0 (Default) MTU: 1500 MAC: 00 80 e1 18 2a 25 FLAGS: UP LINK_UP ETHARP ip address: 192.168.1.30 gw address: 192.168.1.1 net mask : 255.255.255.0 RX err =-3 link up 100Mbps full-duplex eth hardware init sucess... eth hardware start success... RX err =-3 RX err =-3 RX err =-3 RX err =-3 **************************************** Connect fail! **************************************** **************************************** Connect fail! **************************************** ```
geniusgogo
2018-05-29
[i=s] 本帖最后由 geniusgogo 于 2018-5-29 15:45 编辑 [/i] 1.4.1版本连接失败的原因原来是eth_system_device_init没有调用,因为我没有启用componentinit,所以遗漏了eth_system_device_init接口初始化。这个接口在2.0.2上是由lwip_system_init自动调用的,但是在之前的老版本需要手动调用。
2018-05-29
建议以后都用 2.x 的版本
geniusgogo
2018-05-29
>建议以后都用 2.x 的版本 --- 2.x的版本RAM占用多啊!
geniusgogo
2018-05-31
为什么没人对LWIP2.0.2的RAM占用变多的问题提出见解?包括ROM也一样多了很多。
kerrhu
2018-07-05
>为什么没人对LWIP2.0.2的RAM占用变多的问题提出见解?包括ROM也一样多了很多。 ... --- 麻烦帮忙看看这个帖子,[https://www.rt-thread.org/qa/thread-7358-1-1.html](https://www.rt-thread.org/qa/thread-7358-1-1.html) 是不是只用UDP的话,LWIP_SO_SNDTIMEO 就要不启用?
8.7k
geniusgogo
42
157
lwip1.4.1连接经常会断开无法连接上,可以ping通
求一些LWIP开发的经验,目前ping一直不稳定。
stm32f207+dp83848无法ping通
RTT下的LWIP传递机制
rtt内lwip的socket是否是线程安全?
Lwip+enc28j60无法ping通
坑爹的rtconfig.h lwip关掉了checksum
嵌入式ARM RISCV toolchain工具 梳理arm-none-eabi-gcc
可以使用MQTT连接AI大模型吗
wake_mirco
mushroom
Jack_____
