Encoder
spiLCD
潘多拉BSP采用rtt4.04,encoder功能和lcd(spi3)有冲突
发布于 2021-06-01 17:51:58 浏览:1051
main里面的代码如下: ```c #include
/* defined the LED0 pin: PE7 */ #define LED0_PIN GET_PIN(E, 7) #define PULSE_CH1 GET_PIN(C, 7) #define PULSE_CH2 GET_PIN(C, 6) /* * 程序清单:这是一个脉冲编码器设备使用例程 * 例程导出了 pulse_encoder_sample 命令到控制终端 * 命令调用格式:pulse_encoder_sample * 程序功能:每隔 500 ms 读取一次脉冲编码器外设的计数值,然后清空计数值,将读取到的计数值打印出来。 *原文链接:https://blog.csdn.net/qq_41285788/article/details/102729020 */ #define PULSE_ENCODER_DEV_NAME "pulse8" /* 脉冲编码器名称,这里用的是 time8 ,PC6,PC7 */ rt_err_t ret = RT_EOK; rt_device_t pulse_encoder_dev = RT_NULL; /* 脉冲编码器设备句柄 */ rt_int32_t count; rt_int32_t openok=0; //static int pulse_encoder_sample(int argc, char *argv[]) static int pulse_encoder_sample(void) { /* 查找脉冲编码器设备 */ pulse_encoder_dev = rt_device_find(PULSE_ENCODER_DEV_NAME); if (pulse_encoder_dev == RT_NULL) { rt_kprintf("pulse encoder sample run failed! can't find %s device!\n", PULSE_ENCODER_DEV_NAME); return RT_ERROR; openok=0; } /* 以只读方式打开设备 */ ret = rt_device_open(pulse_encoder_dev, RT_DEVICE_OFLAG_RDONLY); if (ret != RT_EOK) { rt_kprintf("open %s device failed!\n", PULSE_ENCODER_DEV_NAME); openok=0; return ret; }else { rt_kprintf("open %s device success!\n", PULSE_ENCODER_DEV_NAME); openok=1; } // for(rt_uint32_t i = 0; i <= 50; i++) // while(1) // { // rt_thread_mdelay(10); // /* 读取脉冲编码器计数值 */ // rt_device_read(pulse_encoder_dev, 0, &count, 1); // /* 清空脉冲编码器计数值 */ //rt_device_control(pulse_encoder_dev, PULSE_ENCODER_CMD_CLEAR_COUNT, RT_NULL); // rt_kprintf("get count %d\n",count); // } // rt_device_close(pulse_encoder_dev); return ret; } /* 导出到 msh 命令列表中 */ MSH_CMD_EXPORT(pulse_encoder_sample, pulse encoder sample); void irq_callback(void *args) { if(openok==1) { rt_device_read(pulse_encoder_dev, 0, &count, 1); /* 清空脉冲编码器计数值 */ //rt_device_control(pulse_encoder_dev, PULSE_ENCODER_CMD_CLEAR_COUNT, RT_NULL); rt_kprintf("get count %d , %d \n", count,count/4); } else { rt_kprintf("please first run cmd of 'pulse_encoder_sample' to open port in MSH\n"); } } int main(void) { /* set LED0 pin mode to output */ rt_pin_mode(LED0_PIN, PIN_MODE_OUTPUT); rt_pin_mode(PULSE_CH1,PIN_MODE_INPUT); rt_pin_mode(PULSE_CH2,PIN_MODE_INPUT); rt_pin_attach_irq(PULSE_CH1, PIN_IRQ_MODE_RISING, irq_callback, (void *)PULSE_CH1); rt_pin_attach_irq(PULSE_CH1, PIN_IRQ_MODE_FALLING, irq_callback, (void *)PULSE_CH1); rt_pin_attach_irq(PULSE_CH2, PIN_IRQ_MODE_RISING, irq_callback, (void *)PULSE_CH2); rt_pin_attach_irq(PULSE_CH2, PIN_IRQ_MODE_FALLING, irq_callback, (void *)PULSE_CH2); rt_pin_irq_enable(PULSE_CH1, PIN_IRQ_ENABLE); rt_pin_irq_enable(PULSE_CH2, PIN_IRQ_ENABLE); pulse_encoder_sample(); while (1) { rt_pin_write(LED0_PIN, PIN_HIGH); rt_thread_mdelay(500); rt_pin_write(LED0_PIN, PIN_LOW); rt_thread_mdelay(500); } } ``` 当把lcd对应的SPI打开时,编码器计数变得非常迟钝,如果在ENV里面关闭LCD和spi以及spi3,则恢复正常。不知道是哪里冲突?请教下该如何解决?非常感谢
2021-06-02
编码器计数是靠中断,应该核对一下该中断的优先级是否需要调整。
1.1k
liuqingsheng
潘多拉开发板AP6181 外设支持报错
潘多拉wifi管理例程中ap模式未启动
潘多拉开发板上I2C设备驱动开发
潘多拉开发板 综合例程 调试报错
潘多拉开发板在VSCODE无法执行micropython
潘多拉添加freemodbus例子出现错误
潘多拉开发板OV2640拍摄JPEG格式的照片
SFUD 提示闪存超过32g
有谁用潘多拉开发过OV2640吗
请问潘多拉开发板怎么烧录micropython固件
pkgs --upgrade报错SSL未验证问题解决记录
CherryUSB STM32 glue 新增初始化
求助can通讯下怎末运用485
STM32F407ZGT适配串口V2驱动
818
