ulog输出异常-中断与线程打印冲突
发布于 2024-04-10 09:35:16 浏览:1155
[tocm] 逻辑:can收到数据后,can中断打印test,并把数据放到消息队列,main函数的消息队列打印消息内容 问题:只要can中断中有test打印的代码,整个串口就会卡死; 中断中无test打印的代码,main函数的打印正常; main函数的打印代码注释掉的话,中断中的test打印正常; .config相关的配置 ```c # # Utilities # # CONFIG_RT_USING_RYM is not set CONFIG_RT_USING_ULOG=y # CONFIG_ULOG_OUTPUT_LVL_A is not set # CONFIG_ULOG_OUTPUT_LVL_E is not set # CONFIG_ULOG_OUTPUT_LVL_W is not set # CONFIG_ULOG_OUTPUT_LVL_I is not set CONFIG_ULOG_OUTPUT_LVL_D=y CONFIG_ULOG_OUTPUT_LVL=7 CONFIG_ULOG_USING_ISR_LOG=y CONFIG_ULOG_ASSERT_ENABLE=y CONFIG_ULOG_LINE_BUF_SIZE=128 CONFIG_ULOG_USING_ASYNC_OUTPUT=y CONFIG_ULOG_ASYNC_OUTPUT_BUF_SIZE=2048 CONFIG_ULOG_ASYNC_OUTPUT_BY_THREAD=y CONFIG_ULOG_ASYNC_OUTPUT_THREAD_STACK=2048 CONFIG_ULOG_ASYNC_OUTPUT_THREAD_PRIORITY=30 # # log format # CONFIG_ULOG_OUTPUT_FLOAT=y CONFIG_ULOG_USING_COLOR=y CONFIG_ULOG_OUTPUT_TIME=y # CONFIG_ULOG_TIME_USING_TIMESTAMP is not set CONFIG_ULOG_OUTPUT_LEVEL=y CONFIG_ULOG_OUTPUT_TAG=y # CONFIG_ULOG_OUTPUT_THREAD_NAME is not set CONFIG_ULOG_BACKEND_USING_CONSOLE=y # CONFIG_ULOG_BACKEND_USING_FILE is not set # CONFIG_ULOG_USING_FILTER is not set # CONFIG_ULOG_USING_SYSLOG is not set # CONFIG_RT_USING_UTEST is not set # CONFIG_RT_USING_VAR_EXPORT is not set # CONFIG_RT_USING_RESOURCE_ID is not set # CONFIG_RT_USING_ADT is not set # CONFIG_RT_USING_RT_LINK is not set # CONFIG_RT_USING_VBUS is not set ``` can中断中打印的代码 ```c void HAL_CAN_RxFifo0MsgPendingCallback(CAN_HandleTypeDef *hcan) { struct can_rx_msg msg; if (HAL_CAN_GetRxMessage(hcan, CAN_RX_FIFO0, &msg.RxHeader, msg.data) != HAL_OK) { LOG_E("get can rx error\n"); } if(msg.RxHeader.StdId != 0x601){ // A板TSDO 0x601 return; } LOG_E("test"); if(RT_EOK != rt_mq_send(&can1_obj.rx_msg_mq, &msg, sizeof(msg))){ LOG_E("send my_canopen_sdo_mq failed"); } } ``` main线程打印消息队列的数据 ```c int main(void) { while (1) { struct can_rx_msg rx_msg; if(1 == can_receive_data(&can1_obj, &rx_msg, RT_WAITING_FOREVER)) { LOG_D("stdid:%x dlc:%d data:%x %x %x %x %x %x %x %x", rx_msg.RxHeader.StdId, rx_msg.RxHeader.DLC, rx_msg.data[0], rx_msg.data[1], rx_msg.data[2], rx_msg.data[3], rx_msg.data[4], rx_msg.data[5], rx_msg.data[6], rx_msg.data[7]); } } } ```
Jam
2024-04-10
与此问题有点类似,可能也是互斥量的问题 https://club.rt-thread.org/ask/question/af4cfb5cf6c82462.html
2024-04-10
代码总在「分分钟搞定」的狂喜与「必有暗坑」的隐忧间往复
- 怀疑你串口驱动有互斥操作以保证日志的完整显示;可以进一步排查看看
aeniac
2024-04-30
把LOG_E("test");去掉试试,可能是因为中断中不可以使用可能会造成阻塞的代码。
歴肄业
2025-03-24
https://club.rt-thread.org/ask/question/474913da388e590c.html [@Jam](/u/fdc9c103b16a0209)
1.2k
Jam
串口DMA发送数据时,数据被覆盖
关于串口DMA模式下rt_device_close问题
finsh 控制台 适配 RS 485请大神指点????
串口无法接受数据,但可以发送
串口如何有效的清除掉接收缓冲,而不必一个一个的去读取
串口接收使用方式问题
雅特力FINSH问题
【RSOC25】Day5 课程笔记:软件包相关知识
RT-Thread 夏令营 第五天笔记
【RSOC25】Day5 课程笔记:软件包和网络组件
【RSOC25】Day4 课程笔记:I/O设备和驱动框架
【RSOC25】Day3 课程笔记:线程间同步和通信
1527
344
822
