rt-thread中使用usart3引脚
发布于 2024-03-26 11:19:01 浏览:698
rt-thread中使用usart3后,他的端口定义实在什么地方,我找不到,下面是我通过GET_PIN查找的,也没有,那么下面代码是自己生成的嘛,为什么我用了usart3,他却没有自动生成呢???? ```c #include
#include "pins_arduino.h" /* * {Arduino Pin, RT-Thread Pin [, Device Name, Channel]} * [] means optional * Digital pins must NOT give the device name and channel. * Analog pins MUST give the device name and channel(ADC, PWM or DAC). * Arduino Pin must keep in sequence. */ const pin_map_t pin_map_table[]= { {D0, GET_PIN(A,3), "uart2"}, /* Serial-RX */ {D1, GET_PIN(A,2), "uart2"}, /* Serial-TX */ {D2, GET_PIN(A,10)}, {D3, GET_PIN(B,3), "pwm2", 2}, /* PWM */ {D4, GET_PIN(B,5)}, {D5, GET_PIN(B,4), "pwm3", 1}, /* PWM */ {D6, GET_PIN(B,10), "pwm2", 3}, /* PWM */ {D7, GET_PIN(A,8)}, {D8, GET_PIN(A,9)}, {D9, GET_PIN(C,7), "pwm3", 0}, /* PWM */ {D10, GET_PIN(B,6), "pwm4", 1}, /* PWM */ {D11, GET_PIN(A,7), "pwm17", 1}, /* PWM */ {D12, GET_PIN(A,6)}, {D13, GET_PIN(A,5)}, {D14, GET_PIN(B,9), "i2c1"}, /* I2C-SDA (Wire) */ {D15, GET_PIN(B,8), "i2c1"}, /* I2C-SCL (Wire) */ {D16, GET_PIN(A,5)}, {A0, GET_PIN(A,0), "adc1", 5}, /* ADC */ {A1, GET_PIN(A,1), "adc1", 6}, /* ADC */ {A2, GET_PIN(A,4), "adc1", 9}, /* ADC */ {A3, GET_PIN(B,0), "adc1", 15}, /* ADC */ {A4, GET_PIN(C,1), "adc1", 2}, /* ADC */ {A5, GET_PIN(C,0), "adc1", 1}, /* ADC */ {A6, RT_NULL, "adc1", 17}, /* ADC, On-Chip: internal reference voltage, ADC_CHANNEL_VREFINT */ {A7, RT_NULL, "adc1", 16}, /* ADC, On-Chip: internal temperature sensor, ADC_CHANNEL_TEMPSENSOR */ }; ```
CrazyH
2024-03-26
自己添加
编程菜鸟
2024-03-27
代码改变世界
在cubmx配置好串口引脚生成xx_hal_msp.c就相当于引脚和对应串口绑定了,会自动初始化引脚IO,其他地方不用处理引脚了
698
dsfghjkl
串口DMA发送数据时,数据被覆盖
关于串口DMA模式下rt_device_close问题
finsh 控制台 适配 RS 485请大神指点????
串口无法接受数据,但可以发送
串口如何有效的清除掉接收缓冲,而不必一个一个的去读取
串口接收使用方式问题
雅特力FINSH问题
基于RT-Thread的STM32F4开发第三讲——DAC
Wireshark抓包EtherCAT报文
818
