rt_hw_context_switch_to之后进入硬件错误中断 该怎么办?
发布于 2024-10-14 09:35:32 浏览:821
通过STM32CUBEMX生成的基于STM32CUBEIDE的RT-THREAD程序,在完成rt_hw_context_switch_to之后进入如下程序 ```c HardFault_Handler: /* get current context */ MRS r0, msp /* get fault context from handler. */ TST lr, #0x04 /* if(!EXC_RETURN[2]) */ BEQ _get_sp_done MRS r0, psp /* get fault context from thread. */ _get_sp_done: STMFD r0!, {r4 - r11} /* push r4 - r11 register */ STMFD r0!, {lr} /* push exec_return register */ TST lr, #0x04 /* if(!EXC_RETURN[2]) */ BEQ _update_msp MSR psp, r0 /* update stack pointer to PSP. */ B _update_done _update_msp: MSR msp, r0 /* update stack pointer to MSP. */ _update_done: PUSH {LR} BL rt_hw_hard_fault_exception POP {LR} ORR LR, LR, #0x04 BX LR ``` 当进入到rt_hw_hard_fault_exception里 ```c void rt_hw_hard_fault_exception(struct exception_info * exception_info) { extern long list_thread(void); struct stack_frame* context = &exception_info->stack_frame; if (rt_exception_hook != RT_NULL) { rt_err_t result; result = rt_exception_hook(exception_info); if (result == RT_EOK) return; } rt_kprintf("psr: 0x%08x\n", context->exception_stack_frame.psr); rt_kprintf("r00: 0x%08x\n", context->exception_stack_frame.r0); rt_kprintf("r01: 0x%08x\n", context->exception_stack_frame.r1); rt_kprintf("r02: 0x%08x\n", context->exception_stack_frame.r2); rt_kprintf("r03: 0x%08x\n", context->exception_stack_frame.r3); rt_kprintf("r04: 0x%08x\n", context->r4); rt_kprintf("r05: 0x%08x\n", context->r5); rt_kprintf("r06: 0x%08x\n", context->r6); rt_kprintf("r07: 0x%08x\n", context->r7); rt_kprintf("r08: 0x%08x\n", context->r8); rt_kprintf("r09: 0x%08x\n", context->r9); rt_kprintf("r10: 0x%08x\n", context->r10); rt_kprintf("r11: 0x%08x\n", context->r11); rt_kprintf("r12: 0x%08x\n", context->exception_stack_frame.r12); rt_kprintf(" lr: 0x%08x\n", context->exception_stack_frame.lr); rt_kprintf(" pc: 0x%08x\n", context->exception_stack_frame.pc); if(exception_info->exc_return & (1 << 2) ) { rt_kprintf("hard fault on thread: %s\r\n\r\n", rt_thread_self()->name); #ifdef RT_USING_FINSH list_thread(); #endif /* RT_USING_FINSH */ } else { rt_kprintf("hard fault on handler\r\n\r\n"); } #ifdef RT_USING_FINSH hard_fault_track(); #endif /* RT_USING_FINSH */ while (1); } ``` 因为 `rt_exception_hook ==RT_NULL` 导致进入死循环 请问大家该怎么解决呢 谢谢 在线等!
rv666
2024-10-14
用GDB调试人生
都异常了,首先应该是找异常的原因,这里异常没有退出机制,进去是出不来的,结合输出的异常信息分析一下异常的原因,也可以在上述提到的函数打断点,单步调试
动于九天之上
2024-10-14
这是程序刚开始运行,第一次上下文切换的时候,遇到这个问题。也就是要控制程序切换到用户main时出现的。程序从entry开始启动系统,在 rt_system_scheduler_start();中调用了rt_hw_context_switch_to,rt_hw_context_switch_to结束后,进入了HardFault_Handler
2024-10-15
代码总在「分分钟搞定」的狂喜与「必有暗坑」的隐忧间往复
- 你用的是什么芯片?看一下BSP有没有现成的工程,先拿来试一下
不见子都
2024-10-15
1.首先根据芯片用户手册,查看芯片的异常类型。 2.在异常处理中打断点断住程序 3.分析psr或者evc中,指向的异常向量位置,找到具体异常类型,根据类型排查 4.芯片着重查看psr各状态位是否合理,如程序用户权限等级 5.查看Reset函数汇编内容是否符合要求,sp、vbr等关键寄存器是否配置
2024-10-16
cubemx生成的nano工程,然后导出工程为stm32cubeide?如果是这样的话,需要修改启动文件中的main入口为entry(也就是rtthread的入口函数),你这个异常可能是直接进入的main函数,并且在里面调用了rtt相关的API,但是由于没有rtthread_startup这个系统一系列初始化过程,所以直接抛出异常了 默认nano是只支持mdk工具链的,stm32cubeide由于启动文件不好做修改所以不建议在cubemx中的nano组件中导出工程为cubeide 如果是自己移植的rtt,cubeide默认使用的也是gcc工具链,需要改启动文件的入口,然后参考主仓bsp移植一份
都家二公子
2025-03-27
你的问题解决了吗?我现在遇到了和你一模一样的问题,想请教下
动于九天之上
新手请教关于hardfault怎么查
STM32F1+RTT串口接收中断进入hardfault
STM32F746NG随机进入hardfault(已解决)
【RSOC25】Day5 课程笔记:软件包相关知识
RT-Thread 夏令营 第五天笔记
【RSOC25】Day5 课程笔记:软件包和网络组件
【RSOC25】Day4 课程笔记:I/O设备和驱动框架
【RSOC25】Day3 课程笔记:线程间同步和通信
1527
344
822
