栈溢出_StackOverflow
rt-thread堆栈溢出的问题
发布于 2022-07-24 23:27:18 浏览:1563
定义了5个定时器中断,因为中断周期是500us没有使用rt-thread的硬件定时器驱动框架 ```c void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim) { if( htim == &htim1){ MA_Prog(); // SA_Check(); } else if( htim == &htim2){ // MB_Prog(); // SB_Check(); } else if( htim == &htim3){ // MC_Prog(); // SC_Check(); } else if( htim == &htim4){ // MD_Prog(); // SD_Check(); } else if( htim == &htim5){ // ME_Prog(); // SE_Check(); } } ``` 定时器的中断回调函数调用外部中断处理函数产生PWM ```c void MA_Prog(void) { static uint8_t i=0,j=0; MA_STEP_LEVEL = !MA_STEP_LEVEL; i++; } ``` 产生堆栈溢出错误 ```c .\build\keil\Obj\rt-thread.axf: Error: L6406E: No space in execution regions with .ANY selector matching startup_stm32f103xb.o(STACK). .\build\keil\Obj\rt-thread.axf: Error: L6406E: No space in execution regions with .ANY selector matching startup_stm32f103xb.o(HEAP). .\build\keil\Obj\rt-thread.axf: Error: L6406E: No space in execution regions with .ANY selector matching idle.o(.bss). .\build\keil\Obj\rt-thread.axf: Error: L6406E: No space in execution regions with .ANY selector matching drv_spi.o(.bss). .\build\keil\Obj\rt-thread.axf: Error: L6406E: No space in execution regions with .ANY selector matching motor_tim.o(.bss). .\build\keil\Obj\rt-thread.axf: Error: L6406E: No space in execution regions with .ANY selector matching cm_backtrace.o(.bss). .\build\keil\Obj\rt-thread.axf: Error: L6406E: No space in execution regions with .ANY selector matching drv_usart.o(.bss). .\build\keil\Obj\rt-thread.axf: Error: L6406E: No space in execution regions with .ANY selector matching scheduler.o(.bss). .\build\keil\Obj\rt-thread.axf: Error: L6406E: No space in execution regions with .ANY selector matching drv_tmc2660.o(.bss). .\build\keil\Obj\rt-thread.axf: Error: L6406E: No space in execution regions with .ANY selector matching drv_gpio.o(.data). .\build\keil\Obj\rt-thread.axf: Error: L6406E: No space in execution regions with .ANY selector matching object.o(.data). .\build\keil\Obj\rt-thread.axf: Error: L6406E: No space in execution regions with .ANY selector matching ulog.o(.bss). .\build\keil\Obj\rt-thread.axf: Error: L6406E: No space in execution regions with .ANY selector matching shell.o(.bss). .\build\keil\Obj\rt-thread.axf: Error: L6406E: No space in execution regions with .ANY selector matching kservice.o(.bss). .\build\keil\Obj\rt-thread.axf: Error: L6406E: No space in execution regions with .ANY selector matching libspace.o(.bss). .\build\keil\Obj\rt-thread.axf: Error: L6406E: No space in execution regions with .ANY selector matching drv_wdt.o(.bss). .\build\keil\Obj\rt-thread.axf: Error: L6406E: No space in execution regions with .ANY selector matching pin.o(.bss). .\build\keil\Obj\rt-thread.axf: Error: L6406E: No space in execution regions with .ANY selector matching motor.o(.data). .\build\keil\Obj\rt-thread.axf: Error: L6406E: No space in execution regions with .ANY selector matching mem.o(.bss). .\build\keil\Obj\rt-thread.axf: Error: L6406E: No space in execution regions with .ANY selector matching mem.o(.data). .\build\keil\Obj\rt-thread.axf: Error: L6406E: No space in execution regions with .ANY selector matching console_be.o(.bss). .\build\keil\Obj\rt-thread.axf: Error: L6406E: No space in execution regions with .ANY selector matching scheduler.o(.data). .\build\keil\Obj\rt-thread.axf: Error: L6406E: No space in execution regions with .ANY selector matching syswatch.o(.bss). .\build\keil\Obj\rt-thread.axf: Error: L6406E: No space in execution regions with .ANY selector matching shell.o(.data). .\build\keil\Obj\rt-thread.axf: Error: L6406E: No space in execution regions with .ANY selector matching timer.o(.data). .\build\keil\Obj\rt-thread.axf: Error: L6406E: No space in execution regions with .ANY selector matching drv_usart.o(.data). .\build\keil\Obj\rt-thread.axf: Error: L6406E: No space in execution regions with .ANY selector matching cm_backtrace.o(.data). .\build\keil\Obj\rt-thread.axf: Error: L6406E: No space in execution regions with .ANY selector matching drv_spi.o(.data). .\build\keil\Obj\rt-thread.axf: Error: L6406E: No space in execution regions with .ANY selector matching cpuport.o(.data). .\build\keil\Obj\rt-thread.axf: Error: L6406E: No space in execution regions with .ANY selector matching ulog.o(.data). .\build\keil\Obj\rt-thread.axf: Error: L6406E: No space in execution regions with .ANY selector matching kservice.o(.data). .\build\keil\Obj\rt-thread.axf: Error: L6406E: No space in execution regions with .ANY selector matching thread.o(.data). .\build\keil\Obj\rt-thread.axf: Error: L6406E: No space in execution regions with .ANY selector matching signal_led.o(.data). .\build\keil\Obj\rt-thread.axf: Error: L6406E: No space in execution regions with .ANY selector matching irq.o(.data). .\build\keil\Obj\rt-thread.axf: Error: L6406E: No space in execution regions with .ANY selector matching stm32f1xx_hal.o(.data). .\build\keil\Obj\rt-thread.axf: Error: L6406E: No space in execution regions with .ANY selector matching main.o(.data). .\build\keil\Obj\rt-thread.axf: Error: L6406E: No space in execution regions with .ANY selector matching drv_wdt.o(.data). .\build\keil\Obj\rt-thread.axf: Error: L6406E: No space in execution regions with .ANY selector matching clock.o(.data). .\build\keil\Obj\rt-thread.axf: Error: L6406E: No space in execution regions with .ANY selector matching tmc2660_sample.o(.data). .\build\keil\Obj\rt-thread.axf: Error: L6406E: No space in execution regions with .ANY selector matching serial.o(.data). .\build\keil\Obj\rt-thread.axf: Error: L6406E: No space in execution regions with .ANY selector matching system_stm32f1xx.o(.data). .\build\keil\Obj\rt-thread.axf: Error: L6407E: Sections of aggregate size 0x13ec bytes could not fit into .ANY selector(s). ``` 只要将MA_Prog的i++注释掉就没有了,是什么原因产生堆栈溢出错误 还有一个,另外定义一个另外测试函数中断回调调用也没这个问题 ```c void time_test(void) { static uint8_t i=0; i++; } ``` 就是说只要在中断回调里调用MA_Prog名称函数并且只要一点简单的运算就会报堆栈错误
nongxiaoming
2022-07-25
rt-thread大师兄
这个是你sram不够用了啊,不是堆栈溢出
红枫
2022-07-25
把中断函数中的变量定义放到函数外面试试
2022-07-25
你这是编译错误啊,内存不足以支撑 rtt 系统了。放弃系统吧。 或者稍微减少线程栈大小一点点验证一下。
Yanye0xFF
2022-07-25
https
中断函数用的系统初始化前的c栈空间,把它改大点试试。
1.6k
kun222
rtt
RT-THREAD在STM32H747平台上移植lwip
正点原子miniSTM32开发板读写sdcard
反馈rtt串口驱动对低功耗串口lpuart1不兼容的问题
Keil MDK 移植 RT-Thread Nano
RT1061/1052 带 RTT + LWIP和LPSPI,有什么坑要注意吗?
RT thread HID 如何收发数据
RT-Thread修改项目名称之后不能下载
rt-studio编译c++
有木有移植rt-thread(nano)到riscv 32位MCU上
【睿擎工业平台试用】EtherCAT主站控制从站IO
【睿擎工业平台试用】硬件平台上手和Modbus功能使用
rt thread 文件系统dfs挂载2个块设备
RT Thread 块设备注册
chejia12
纯白酱
530china
rv666
