stm32f407 4.1.0版本串口接收中断不进中断?
发布于 2022-07-19 09:34:23 浏览:1239
采用串口1,连接迪文屏,把调试的console关了,采用rxint方式接收, 调试过程中,发现点击屏幕,串口接收不到数据,我在串口接收中断里打的断点。请大家帮忙看看,谢谢 这是串口接收中断服务函数,我在第一行打断点都不会停 ```c void USART1_IRQHandler(void) { /* enter interrupt */ rt_interrupt_enter(); // uart_isr(&(uart_obj[UART1_INDEX].serial)); uint8_t res; if(USART1->SR&(1<<5))//接收到数据 { res=USART1->DR; //USART6->DR=res; if((USART_RX_STA&0x8000)==0)//接收未完成 { if(USART_RX_STA==0) { //接收数据个数为0时,刚开始接收,此时如果收到帧头0x5A,保存,数字++ if(res==0x5a)USART_RX_BUF[USART_RX_STA++]=res; } else if(USART_RX_STA==1) { //个数1,如果收到0xA5,帧头第二部分,保存,个数++ if(res==0xa5)USART_RX_BUF[USART_RX_STA++]=res; //如果又收到帧头一,则相当于收到1个数据,赋值给buf[0] else if(res==0x5a)USART_RX_BUF[0]=res; //不是帧头1,也不是帧头2,这一帧错误,sta=0,重新接收 else USART_RX_STA=0; } else if(USART_RX_STA==2) { //接收完帧头之后,是数据长度,长度小于5大于30,重新接收,反之接收长度数据 if((res<=5)||(res>30))USART_RX_STA=0; else USART_RX_BUF[USART_RX_STA++]=res; } else { //正常接收数据,接收数据长度大于上面的长度+2,就是等于+3,包括了2个帧头和数据长度,完成接收 USART_RX_BUF[USART_RX_STA++]=res; if(USART_RX_STA>(USART_RX_BUF[2]+2)) USART_RX_STA|=0x8000; //接收完成 } } } /* leave interrupt */ rt_interrupt_leave(); } ``` ```c if (dev == RT_NULL) { dev = rt_device_find(Screen_DEVICE_NAME); RT_ASSERT(dev); if(RT_EOK ==rt_device_open(dev, RT_DEVICE_FLAG_INT_RX)) { rt_kprintf("Screen serial open success.\r\n"); // return RT_EOK; } else { rt_kprintf("Screen serial open failure.\r\n"); return RT_ERROR; } pconfig.baud_rate = BAUD_RATE_115200; pconfig.data_bits = DATA_BITS_8; pconfig.stop_bits = STOP_BITS_1; pconfig.parity = PARITY_NONE; pconfig.bit_order = BIT_ORDER_LSB; pconfig.invert = NRZ_NORMAL; pconfig.bufsz = 256; pconfig.reserved = 0; /* 设置串口参数 */ rt_device_control(dev, RT_DEVICE_CTRL_CONFIG, &pconfig); /*设置串口的回调函数 */ rt_device_set_rx_indicate(dev, RT_NULL); } ``` 还有把控制台关了 ```c #define RT_USING_DEVICE //#define RT_USING_CONSOLE #define RT_CONSOLEBUF_SIZE 128 #define RT_CONSOLE_DEVICE_NAME "uart1" #define RT_VER_NUM 0x40100 #define ARCH_ARM #define RT_USING_CPU_FFS #define ARCH_ARM_CORTEX_M #define ARCH_ARM_CORTEX_M4 ``` 多谢
2022-07-19
嵌入式
参考文档中心的串口驱动小节 [串口中断接收及轮询发送](https://www.rt-thread.org/document/site/#/rt-thread-version/rt-thread-standard/programming-manual/device/uart/uart_v1/uart?id=%e4%b8%b2%e5%8f%a3%e8%ae%be%e5%a4%87%e4%bd%bf%e7%94%a8%e7%a4%ba%e4%be%8b "串口中断接收及轮询发送") ,使用 Rt-Thread 的驱动框架,不用修改串口的中断处理函数,代码示例如下。另外控制台串口无需关闭他俩互不干扰。 ```c /* * 程序清单:这是一个 串口 设备使用例程 * 例程导出了 uart_sample 命令到控制终端 * 命令调用格式:uart_sample uart2 * 命令解释:命令第二个参数是要使用的串口设备名称,为空则使用默认的串口设备 * 程序功能:通过串口输出字符串"hello RT-Thread!",然后错位输出输入的字符 */ #include
#define SAMPLE_UART_NAME "uart2" /* 用于接收消息的信号量 */ static struct rt_semaphore rx_sem; static rt_device_t serial; /* 接收数据回调函数 */ static rt_err_t uart_input(rt_device_t dev, rt_size_t size) { /* 串口接收到数据后产生中断,调用此回调函数,然后发送接收信号量 */ rt_sem_release(&rx_sem); return RT_EOK; } static void serial_thread_entry(void *parameter) { char ch; while (1) { /* 从串口读取一个字节的数据,没有读取到则等待接收信号量 */ while (rt_device_read(serial, -1, &ch, 1) != 1) { /* 阻塞等待接收信号量,等到信号量后再次读取数据 */ rt_sem_take(&rx_sem, RT_WAITING_FOREVER); } /* 读取到的数据通过串口错位输出 */ ch = ch + 1; rt_device_write(serial, 0, &ch, 1); } } static int uart_sample(int argc, char *argv[]) { rt_err_t ret = RT_EOK; char uart_name[RT_NAME_MAX]; char str[] = "hello RT-Thread!\r\n"; if (argc == 2) { rt_strncpy(uart_name, argv[1], RT_NAME_MAX); } else { rt_strncpy(uart_name, SAMPLE_UART_NAME, RT_NAME_MAX); } /* 查找系统中的串口设备 */ serial = rt_device_find(uart_name); if (!serial) { rt_kprintf("find %s failed!\n", uart_name); return RT_ERROR; } /* 初始化信号量 */ rt_sem_init(&rx_sem, "rx_sem", 0, RT_IPC_FLAG_FIFO); /* 以中断接收及轮询发送模式打开串口设备 */ rt_device_open(serial, RT_DEVICE_FLAG_INT_RX); /* 设置接收回调函数 */ rt_device_set_rx_indicate(serial, uart_input); /* 发送字符串 */ rt_device_write(serial, 0, str, (sizeof(str) - 1)); /* 创建 serial 线程 */ rt_thread_t thread = rt_thread_create("serial", serial_thread_entry, RT_NULL, 1024, 25, 10); /* 创建成功则启动线程 */ if (thread != RT_NULL) { rt_thread_startup(thread); } else { ret = RT_ERROR; } return ret; } /* 导出到 msh 命令列表中 */ MSH_CMD_EXPORT(uart_sample, uart device sample); ```
2022-07-19
不进中断,检查开中断配置嘛,看中断函数能看出啥来? 确认自己打开了 uart1 的配置
伊森亨特
2022-07-19
代码如下,夸克网盘,速度比百度网盘快。谢谢 链接:https://pan.quark.cn/s/a340d4402ff2
1.2k
伊森亨特
78
33
串口DMA发送数据时,数据被覆盖
关于串口DMA模式下rt_device_close问题
finsh 控制台 适配 RS 485请大神指点????
串口无法接受数据,但可以发送
串口如何有效的清除掉接收缓冲,而不必一个一个的去读取
串口接收使用方式问题
雅特力FINSH问题
基于RT-Thread的STM32F4开发第三讲——DAC
Wireshark抓包EtherCAT报文
818
