RTT5.2.0串口接收中断死机的问题
发布于 2025-05-08 14:19:48 浏览:334
RTThread: 5.2.0 BSP: STM32F103RC 单片机: GD32F303RCT6 问题代码: ```C int main(void) { // TjcRuntime_reset(&tjc_runtime); while (1) { // rt_kprintf("running...\n"); rt_thread_mdelay(1000); } } static void rx_call(char *buff, u32 size) { TjcRuntime_pushReceiveData(&tjc_runtime, buff, size); } void Ui_startup(void) { serial = rt_device_find("uart4"); struct serial_configure conf = RT_SERIAL_CONFIG_DEFAULT; conf.baud_rate = 921600; rt_device_control(serial, RT_DEVICE_CTRL_CONFIG, &conf); rt_device_open(serial, RT_DEVICE_FLAG_DMA_TX | RT_DEVICE_FLAG_DMA_RX); // rt_device_open(serial, RT_DEVICE_OFLAG_RDWR); // rt_device_open(serial, RT_DEVICE_FLAG_DMA_TX | RT_DEVICE_FLAG_INT_RX); // rt_device_set_rx_indicate(serial, rx_call); // TjcRuntime_init(&tjc_runtime, serial); } INIT_COMPONENT_EXPORT(Ui_startup); ``` 错误输出: ```Shell [D/drv.usart] uart4 dma config start [D/drv.usart] uart4 dma RX instance: 40020430 [D/drv.usart] uart4 dma config done [D/drv.usart] uart4 dma config start [D/drv.usart] uart4 dma TX instance: 40020458 [D/drv.usart] uart4 dma config done [I/FAL] The FAL block device (fs) created successfully [I/tjc_rt] register id=0 msh />thread pri status sp stack size max used left tick error tcb addr -------- --- ------- ---------- ---------- ------ ---------- ------- ---------- tshell 20 suspend 0x000000c8 0x00001000 08% 0x00000009 EINTRPT 0x20004b00 tidle0 31 running 0x00000058 0x00000100 67% 0x0000001d OK 0x20002110 main 10 suspend 0x000000d0 0x00000800 50% 0x0000000f EINTRPT 0x20002ba8 Firmware name: rtthread, hardware version: 1.0, software version: 1.0 Fault on interrupt or bare metal(no OS) environment ===== Thread stack information ===== addr: 20000e78 data: deadbeef addr: 20000e7c data: deadbeef addr: 20000e80 data: 00000000 addr: 20000e84 data: 00000000 addr: 20000e88 data: 00000000 addr: 20000e8c data: 00000000 addr: 20000e90 data: 00000000 addr: 20000e94 data: fffffffd addr: 20000e98 data: b9337822 addr: 20000e9c data: 01000044 addr: 20000ea0 data: 20000ec0 addr: 20000ea4 data: 10000000 addr: 20000ea8 data: f0000000 addr: 20000eac data: 20002bbc addr: 20000eb0 data: 00000008 addr: 20000eb4 data: 0801d687 addr: 20000eb8 data: 080001f8 addr: 20000ebc data: 01000000 ==================================== =================== Registers information ==================== R0 : fffffff1 R1 : fffffff1 R2 : deadbeef R3 : deadbeef R12: deadbeef LR : 20002248 PC : deadbeef PSR: deadbeef ============================================================== Memory management fault is caused by instruction access violation Show more call stack info by run: addr2line -e rtthread.elf -a -f deadbeef 0801d686 Current system tick: 3861 ``` `RT_DEVICE_FLAG_DMA_RX` 和 `RT_DEVICE_FLAG_INT_RX` 问题一样, 如果不使用中断就不会出现这个问题, 开始中断如果没有数据接收不会报错, 有数据就会报错, 而且并没有进入接收回调, 问题出现在很低级的位置 我重新把代码移植到4.1.1, 没有出现这个问题吗, 可以正常运行
2025-05-16
学以致用
串口接收中断中最好只发送个信号量给线程,让线程去处理,不要在中断中处理很多耗时的操作。
334
26
串口DMA发送数据时,数据被覆盖
关于串口DMA模式下rt_device_close问题
finsh 控制台 适配 RS 485请大神指点????
串口无法接受数据,但可以发送
串口如何有效的清除掉接收缓冲,而不必一个一个的去读取
串口接收使用方式问题
雅特力FINSH问题
V5.2.1 魔改以支持多核处理器从任意核启动
【RSOC25】Day5 课程笔记:软件包相关知识
RT-Thread 夏令营 第五天笔记
【RSOC25】Day5 课程笔记:软件包和网络组件
【RSOC25】Day4 课程笔记:I/O设备和驱动框架
Ryan_CW
D1sguIse_
wdfk_prog
