idle空闲线程
栈溢出_StackOverflow
idle堆栈溢出,导致系统反复重启
发布于 2024-03-20 10:46:36 浏览:562
idle线程线程溢出  如上图,堆栈溢出后,系统反复重启。 具体溢出代码如下 ``` thread:tidle stack overflowthread pri status sp stack size max used left tick error-------- --- ------- ---------- ---------- ------ ---------- --- tidle 31 ready 0x00000220 0x00000200 100% 0x0000001c 000 main 10 suspend 0x000000d0 0x00000200 93% 0x0000000d 000 ``` 目前不清楚啥原因 先有rt_config如下: ```c /* RT-Thread config file */ #ifndef __RTTHREAD_CFG_H__ #define __RTTHREAD_CFG_H__ #include
#if defined(__CC_ARM) || defined(__CLANG_ARM) #include "RTE_Components.h" #if defined(RTE_USING_FINSH) #define RT_USING_FINSH #endif //RTE_USING_FINSH #endif //(__CC_ARM) || (__CLANG_ARM) // <<< Use Configuration Wizard in Context Menu >>> //
Basic Configuration //
Maximal level of thread priority <8-256> //
Default: 32 #define RT_THREAD_PRIORITY_MAX 32 //
OS tick per second //
Default: 1000 (1ms) #define RT_TICK_PER_SECOND 1000 //
Alignment size for CPU architecture data access //
Default: 4 #define RT_ALIGN_SIZE 4 //
the max length of object name<2-16> //
Default: 8 #define RT_NAME_MAX 8 //
Using RT-Thread components initialization //
Using RT-Thread components initialization #define RT_USING_COMPONENTS_INIT 1 // #define RT_USING_USER_MAIN 1 //
the stack size of main thread<1-4086> //
Default: 512 #define RT_MAIN_THREAD_STACK_SIZE 512 //
Debug Configuration //
enable kernel debug configuration //
Default: enable kernel debug configuration #define RT_DEBUG 1 // //
enable components initialization debug configuration<0-1> //
Default: 0 #define RT_DEBUG_INIT 1 //
thread stack over flow detect //
Diable Thread stack over flow detect #define RT_USING_OVERFLOW_CHECK 1 // //
Hook Configuration //
using hook //
using hook //#define RT_USING_HOOK 1 // //
using idle hook //
using idle hook //#define RT_USING_IDLE_HOOK 1 // //
Software timers Configuration //
Enables user timers #define RT_USING_TIMER_SOFT 0 #if RT_USING_TIMER_SOFT == 0 #undef RT_USING_TIMER_SOFT #endif //
The priority level of timer thread <0-31> //
Default: 4 #define RT_TIMER_THREAD_PRIO 10 //
The stack size of timer thread <0-8192> //
Default: 512 #define RT_TIMER_THREAD_STACK_SIZE 512 //
IPC(Inter-process communication) Configuration //
Using Semaphore //
Using Semaphore #define RT_USING_SEMAPHORE 1 // //
Using Mutex //
Using Mutex #define RT_USING_MUTEX 1 // //
Using Event //
Using Event #define RT_USING_EVENT 1 // //
Using MailBox //
Using MailBox #define RT_USING_MAILBOX 1 // //
Using Message Queue //
Using Message Queue #define RT_USING_MESSAGEQUEUE 1 // //
Memory Management Configuration //
Dynamic Heap Management //
Dynamic Heap Management #define RT_USING_HEAP 1 // //
using small memory //
using small memory #define RT_USING_SMALL_MEM 1 // //
using tiny size of memory //
using tiny size of memory #define RT_USING_TINY_SIZE 256 // //
Console Configuration //
Using console //
Using console #define RT_USING_CONSOLE 1 // //
the buffer size of console <1-1024> //
the buffer size of console //
Default: 128 (128Byte) #define RT_CONSOLEBUF_SIZE 128 //
#define RT_USING_FINSH #if defined(RT_USING_FINSH) #define FINSH_USING_MSH #define FINSH_USING_MSH_ONLY //
Finsh Configuration //
the priority of finsh thread <1-7> //
the priority of finsh thread //
Default: 6 #define __FINSH_THREAD_PRIORITY 5 #define FINSH_THREAD_PRIORITY (RT_THREAD_PRIORITY_MAX / 8 * __FINSH_THREAD_PRIORITY + 1) //
the stack of finsh thread <1-4096> //
the stack of finsh thread //
Default: 4096 (4096Byte) #define FINSH_THREAD_STACK_SIZE 512 //
the history lines of finsh thread <1-32> //
the history lines of finsh thread //
Default: 5 #define FINSH_HISTORY_LINES 1 #define FINSH_USING_SYMTAB //
#endif // <<< end of configuration section >>> #define RT_USING_DEVICE 1 #endif ``` 相关idle堆栈配置如下: ```c #ifndef IDLE_THREAD_STACK_SIZE #if defined (RT_USING_IDLE_HOOK) || defined(RT_USING_HEAP) #define IDLE_THREAD_STACK_SIZE 512 #else #define IDLE_THREAD_STACK_SIZE 512 #endif #endif ``` main函数很干净,仅有一个打印函数和延时: ```c int main() { while(1) { rt_kprintf("main\r\n"); rt_thread_mdelay(1); } } ```
天下起了沙
2024-03-20
idle的入口函数呢
2024-03-20
空闲函数都做了啥
zhkag
2024-03-20
加大 IDLE_THREAD_STACK_SIZE
hhart
2025-03-14
可以看一下ide栈空间中的内容,在初始化的时候,是否被成功设置成了`'#'`,如果没有被设置的话,栈检测肯定一直都是溢出的
562
第十一代人造人无纯
空闲线程调用LED闪烁钩子函数
程序跑飞了,msh发命令进不了shell 大循环,一直在idle里
RT-Thread Nano 支持CPU使用率计算吗?
SCB_CFSR_UFSR:0x02_INVSTATE
IDLE 线程总是显示超时状态,是什么原因?
idle线程资源回收
MSH运行hwtimer_test后把idle线程kill了?
idle线程中的rt_free
为什么RTT中空闲线程永远不能被挂起?
NANO3.15 无法进入空闲线程钩子函数【已解决】
【RSOC25】Day5 课程笔记:软件包相关知识
RT-Thread 夏令营 第五天笔记
【RSOC25】Day5 课程笔记:软件包和网络组件
【RSOC25】Day4 课程笔记:I/O设备和驱动框架
【RSOC25】Day3 课程笔记:线程间同步和通信
1527
344
822
