Kernel
萌新求助:在 application_init 调用硬件初始化_出现死机
发布于 2018-10-26 10:20:58 浏览:1816
裁剪了 3.1的内核留了一个 Usart1 做finsh shell 的输入输出硬件,small heap 的动态内存管理,其他组件都关了,由此想 模仿类似 UCOS一样 初始化 硬件,不管在 board_init 还是在 application_init 里初始化GPIO 都初始化失败,单步调试 连第一步 R0=systeminit;启动文件都进不去,但是如果只定义一个每500ms usart1 打印一段字符的线程 就没有问题 (定义初始化IO 翻转 LED灯 就出现上述状况) 平台:STM32407VE+MDK5+CMSIS DAP 上图: 卡死在175行, 代码先关代码段: ```/* * File : application.c * This file is part of RT-Thread RTOS * COPYRIGHT (C) 2006, RT-Thread Development Team * * The license and distribution terms for this file may be * found in the file LICENSE in this distribution or at * [http://www.rt-thread.org/license/LICENSE](http://www.rt-thread.org/license/LICENSE) * * Change Logs: * Date Author Notes * 2009-01-05 Bernard the first version * 2014-04-27 Bernard make code cleanup. */ #include
#ifdef RT_USING_LWIP #include
#include "stm32f4xx_eth.h" #endif #ifdef RT_USING_FINSH #include
#endif #ifdef RT_USING_GDB #include
#endif //-------------------------// #include "AllHeadFile.h" //-------------------------// //-----------------------------------------// void rt_thread_LED_entry(void* arg) { Kim_GPIO_init_out(GPIOA,GPIO_Pin_6,1);//PA6 初始化 输出 默认为 高 while(1) { LED1 = ~LED1; rt_thread_delay(70); } } void rt_thread_KEY_entry(void* arg) { u8 keyvalue =0 ; Key_init(); while(1) { keyvalue = Key_Scan(KEY_SCAN_ONCE); switch(keyvalue) { case (KEY1) : rt_kprintf("key 1 pressed
"); break; case (KEY2) : rt_kprintf("key 2 pressed
"); break; case (KEY0) : rt_kprintf("keyUP pressed
"); break; default: break; } rt_thread_delay(2); } } //-----------------------------------// void rt_init_thread_entry(void* parameter) { /* initialization RT-Thread Components */ rt_components_init(); rt_kprintf("init thread entry
"); /* GDB STUB */ #ifdef RT_USING_GDB gdb_set_device("uart6"); gdb_start(); #endif } void task_test(void* arg) { while(1) { rt_kprintf("task runing
"); rt_thread_delay(55); } } int rt_application_init() { rt_thread_t tid; rt_thread_t led; rt_thread_t test; tid = rt_thread_create("init", rt_init_thread_entry, RT_NULL, 2048, RT_THREAD_PRIORITY_MAX/3, 20); if (tid != RT_NULL) { rt_kprintf("startup rt init thread
"); rt_thread_startup(tid); } led = rt_thread_create("led",rt_thread_LED_entry,RT_NULL,256,RT_THREAD_PRIORITY_MAX/3+2,10); if (led != RT_NULL) { rt_kprintf("led thread up
"); rt_thread_startup(led); } test = rt_thread_create("led",task_test,RT_NULL,256,RT_THREAD_PRIORITY_MAX/3+1,10); if (test != RT_NULL) { rt_kprintf("led thread up
"); rt_thread_startup(test); } return 0; }``` 我最近在自己做一个小玩意,想搞成自己的毕设,由于一开始没有接触到RTT ,就模仿 正点原子 的风格 写了一些裸机驱动代码,(初始化,数据处理等),接触到RTT 感觉到他的强大,像现在就先适应RTT ,以后找工作了可以快速对接,但是又不是很想用RTT 的提供的组件, 所以想裁剪RTT 做到类似于UCOS 一样。我也具体的不是很清楚为么会卡死在连启动函数的systeminit都进不去,感觉上像是RTT 自己有定义启动文件?但是我没看见啊,就看见了一个 NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0); (board.c line 45),但是这个是 systeminit结束之后才会执行的,而我对比 自己的裸机程序,代码里好像没有看到(依稀记得之前有见过(IAP 里头一定有)),但是实在没有搞懂,后面的代码怎么能影响前面的 systeminit 都进不去,恳请大神大牛指教!!!!
kimalittlestar
2018-10-26
BUG已解决 ,函数中有调用 printf 但是 并未实现 printf 中的 fout 的实现,所以出错 解决办法: 在 #include “stdio.h” 处修改 如果支持 RTTreated #include “rtthread.h” #define printf(ftm,...) rt_kprintf((ftm),##__VA_ARGS__) 解决问题。 总结:平常能进去DEBUG ,改了一句语句,立马 启动文件都不跑了大概率 里面你调用了 一些错误的 库函数 典型:malloc() ; printf();
来一颗糖
2018-10-27
rtt 的优势 不仅仅在稳定的内核,还在于驱动框架和组件。对接得好的话,代码就是一次编写多处使用。
armink
2018-10-27
开启 libc 功能后,malloc,printf 这类 libc 函数就都支持了
kimalittlestar
2018-10-28
>rtt 的优势 不仅仅在稳定的内核,还在于驱动框架和组件。对接得好的话,代码就是一次编写多处使用。 ... --- 恩恩,谢谢指点。
kimalittlestar
2018-10-28
>开启 libc 功能后,malloc,printf 这类 libc 函数就都支持了 --- 是这样的,因为 我自定义写的那些文件里头并没有include rtthread.h 文件进去,不过 开启libc功能支持 malloc 这些 我还真不知道。不过还是谢谢啦,我现在去试试看。那我就不用宏定义转换了。。:lol
1.8k
kimalittlestar
请教cpu使用率分析
选择FreeRTOS, 还是RT-Thread。
thread heap stack overflow ?
rtt消息队列delay问题
释放被删除线程的内存地方在哪里啊
请教:各线程结束后,释放其中的内存的连续性问题
STM32F103中断关于信号量、邮箱问题
RTT中的线程栈大小如何控制
关于线程由执行态变为挂起态的代码实现,,,
RT Thread 块设备注册
睿擎工业开发平台--CanOpen示例测试
【深度剖析】RT-Thread 线程调度流程
Ryan_CW
chejia12
纯白酱
530china
rv666
