使用rt_thread无法输出PWM,但使用裸机程序则可以正常输出!
发布于 2024-12-17 13:32:02 浏览:376
[tocm] ## 背景: 实际无法输出PWM波 但是打印报文PWM脉冲 脉宽的变化和线程程序都是正常执行的 使用的RTT 4.03版本; 单片机为STM32F103VET6; 输出引脚:PC9; - PC9:TIM3_CH4; 根据此链接教程配置了cubeMX和rt_thread setting: https://blog.csdn.net/m0_63474185/article/details/134096421 ## 原理图        **下方附完整代码 展开查看全部** ```c /* * Copyright (c) 2006-2024, RT-Thread Development Team * * SPDX-License-Identifier: Apache-2.0 * * Change Logs: * Date Author Notes * 2024-12-17 RT-Thread first version */ #include
#define LED_2 GET_PIN(C, 8) int main(void) { rt_pin_mode(LED_2, PIN_MODE_OUTPUT); rt_pin_write(LED_2, 1); int count = 1; while (count++) { rt_pin_write(LED_2, 1); rt_thread_mdelay(1000); rt_pin_write(LED_2, 0); rt_thread_mdelay(1000); } return RT_EOK; } #define PWM_DEV_NAME "pwm3" /* PWM设备名称 */ #define PWM_DEV_CHANNEL 4 /* PWM通道 */ #define THREAD_PRIORITY 9 /* 线程优先级 */ #define THREAD_STACK_SIZE 512 /* 线程栈大小 */ #define THREAD_TIMESLICE 10 /* 线程时间片大小 */ static rt_thread_t tid1 = RT_NULL; /* 线程句柄 */ struct rt_device_pwm *pwm_dev; /* PWM设备句柄 */ static rt_uint32_t period = 500000; /* 周期为0.5ms,单位为纳秒ns */ static rt_uint32_t pulse = 250000; /* PWM脉冲宽度值的增减方向 */ /* 线程 pwm_entry 的入口函数 */ static void pwm_entry(void *parameter) { int i = 0; while (1) { rt_thread_mdelay(50); if(i == 0) { pulse += 50000; if(pulse >= period){ i = 1; } }else { pulse -= 50000; if(pulse <= 0){ i = 0; } } rt_pwm_set(pwm_dev, PWM_DEV_CHANNEL, period, pulse); rt_kprintf("%d %d \n", period, pulse); } /* step 3、如果不再使用该通道,可以关闭 PWM 通道的输出 */ rt_pwm_disable(pwm_dev, PWM_DEV_CHANNEL); } static int pwm_test(int argc, char *argv[]) { /* step 1.1、查找 PWM 设备 */ pwm_dev = (struct rt_device_pwm *)rt_device_find(PWM_DEV_NAME); if (pwm_dev == RT_NULL) { rt_kprintf("pwm sample run failed! can't find %s device!\n", PWM_DEV_NAME); return RT_ERROR; } /* step 1.2、设置 PWM 周期和脉冲宽度默认值 */ rt_pwm_set(pwm_dev, PWM_DEV_CHANNEL, period, pulse); /* step 1.3、使能 PWM 设备的输出通道 */ rt_pwm_enable(pwm_dev, PWM_DEV_CHANNEL); /* 创建线程,名称是 pwm_thread ,入口是 pwm_entry*/ tid1 = rt_thread_create("pwm_thread", pwm_entry, RT_NULL, THREAD_STACK_SIZE, THREAD_PRIORITY, THREAD_TIMESLICE); /* 如果获得线程控制块,启动这个线程 */ if (tid1 != RT_NULL) rt_thread_startup(tid1); return RT_EOK; } /* 导出到 msh 命令列表中 */ MSH_CMD_EXPORT(pwm_test, pwm sample); ``` 也尝试过使用别的引脚  配置了TM4_CH4也不能实际输出pwm但是用Keil逻辑程序则可以正常输出
每天都很困
2024-12-25
你在线程入口函数的最后失能了pwm输出,74行
376
tangqinyuan001
玩iot camera笔记之3测试试用3路pwm
[已解决]PWM输出异常分析
给RT-Thread添加PWM驱动框架
关于rt-thread-3.1.0 pwm
stm32f103ze 添加pwm 设备失败
基于RT-Thread的STM32开发第一讲——USART
pkgs --upgrade报错SSL未验证问题解决记录
CherryUSB STM32 glue 新增初始化
求助can通讯下怎末运用485
818
