CPU
线程上下文调度切换_context
中断里进行线程上下文切换如何做到的?
发布于 2023-05-23 09:47:50 浏览:1245
``` rt_hw_context_switch_interrupt EXPORT rt_hw_context_switch_interrupt rt_hw_context_switch PROC EXPORT rt_hw_context_switch ; set rt_thread_switch_interrupt_flag to 1 LDR r2, =rt_thread_switch_interrupt_flag LDR r3, [r2] CMP r3, #1 BEQ _reswitch MOV r3, #1 STR r3, [r2] LDR r2, =rt_interrupt_from_thread ; set rt_interrupt_from_thread STR r0, [r2] _reswitch LDR r2, =rt_interrupt_to_thread ; set rt_interrupt_to_thread STR r1, [r2] LDR r0, =NVIC_INT_CTRL ; trigger the PendSV exception (causes context switch) LDR r1, =NVIC_PENDSVSET STR r1, [r0] BX LR ENDP ``` ------------ 上面是context-m 这个中断时线程上下文切换也是通过触发PendSV进行的,但是一些其他的CPU架构在中断环境下不触发类似PendSV,那么是如何进行真正切换呢?例如下面 ``` rt_hw_context_switch: /* compare rt_thread_switch_interrupt_flag and set it */ lis r5,rt_thread_switch_interrput_flag@h ori r5,r5,rt_thread_switch_interrput_flag@l lwz r6,0(r5) cmpi cr0,0,r6,0x1 /* whether is 1 */ beq _reswitch /* set already, goto _reswitch */ li r6,0x1 /* set rt_thread_switch_interrput_flag to 1*/ stw r6,0(r5) /* set rt_interrupt_from_thread to 'from' */ lis r5,rt_interrupt_from_thread@h ori r5,r5,rt_interrupt_from_thread@l stw r3,0(r5) _reswitch: /* set rt_interrupt_to_thread to 'to' */ lis r6,rt_interrupt_to_thread@h ori r6,r6,rt_interrupt_to_thread@l stw r4,0(r6) /* trigger a system call */ sc blr rt_hw_context_switch_interrupt: /* compare rt_thread_switch_interrupt_flag and set it */ lis r5,rt_thread_switch_interrput_flag@h ori r5,r5,rt_thread_switch_interrput_flag@l lwz r6,0(r5) cmpi cr0,0,r6,0x1 /* whether is 1 */ beq _int_reswitch /* set already, goto _int_reswitch */ li r6,0x1 /* set rt_thread_switch_interrput_flag to 1*/ stw r6,0(r5) /* set rt_interrupt_from_thread to 'from' */ lis r5,rt_interrupt_from_thread@h ori r5,r5,rt_interrupt_from_thread@l stw r3,0(r5) _int_reswitch: /* set rt_interrupt_to_thread to 'to' */ lis r6,rt_interrupt_to_thread@h ori r6,r6,rt_interrupt_to_thread@l stw r4,0(r6) blr ``` 目前的情况就是当我两个优先级相同的线程以时间片轮转时会在定时器中断tick增加时产生线程切换,并且调试模式打印是进了 `rt_hw_context_switch_interrupt`,现象就是没有进行切换。从这个汇编来看确实只是获取了from和to线程,真正的切换寄存器压栈进栈并没有进行。 所以我想问问不和context-m一样在里面触发,那么是怎么做到在中断下上下文切换呢?
靖哥哥我滴神
2023-05-24
看这代码我猜应该和m核的类似吧,应该靠陷阱中断或者软中断的方式,`rt_hw_context_switch_interrupt`完成后在scheduler那开中断然后才进中断切?我猜的
323LJH12
2023-05-24
```c void thread1_entry(void* parameter) { int i = 0; while(i < 20){ rt_kprintf("THREAD TICK:0X%x \r\n",rt_tick_get()); i++; } } void thread2_entry(void* parameter) { int j = 0; while(j < 20){ rt_kprintf("thread tick:0x%x \r\n",rt_tick_get()); j++; } } int main() { rt_thread_t tid1; rt_thread_t tid2; rt_err_t result; rt_kprintf("00tick:0x%x \n",rt_tick_get()); tid1 = &LED_Thread; result = rt_thread_init(tid1,"THREAD1",thread1_entry, RT_NULL,rt_led_thread_stack, sizeof(rt_led_thread_stack), 12,10); rt_thread_startup(tid1); rt_kprintf("11tick:0x%x \n",rt_tick_get()); tid2 = rt_thread_create("thread2", thread2_entry, (void*)1, THREAD_STACK_SIZE, 12, 10); if (tid2 != RT_NULL) rt_thread_startup(tid2); rt_kprintf("main_thread is ending \n"); return 0; } ```
1.2k
323LJH12
使用CmBacktrace定位错误异常,请教分析原因
ARM9、raspberry-pi中断问题
内联函数不压栈,会因为中断导致栈内现场被破坏吗
rt_hw_context_switch_interrupt的逻辑
中断的入口程序在哪个文件里?
我想实现一个定时器中断,发现rt_hw_interrupt_install未定义
临界区和关中断,是否需要同时使用?
gpio 引脚一直进中断,请问怎么办呢?
RT-Thread那些API可以在中断程序中调用?
spi dma 中断接收的问题
【最新活动】RT-Thread论坛活动正在进行(2026年5月活动已更新)
【RSOC26】Day2:RT-Thread 启动流程、线程调度与 SCons 构建实践
【RSOC26】RT-Thread 线程内核入门:启动流程、线程机制与 SCons 实操
【RSOC26】RT-Thread 内核机制与 STM32F407 平台启动、调度及构建解析
【RSOC26】Day1-从Git协作到RT-Thread启动链路
【RSOC26】第一天学习(环境的搭建以及git and gitee)
QEMU
CYFS
王棒棒
wdfk_prog
Ewan11111
金阳阳
longtsing
RTT_Studio
枫雪天
