bootloader 跳转APP 出现 bus fault
发布于 2025-02-19 11:04:53 浏览:147
板子: AT32F403ARGT7 ram 96k rt-thread: 4.1.0 bootloader: 跳转前 以下重置操作 ```c nvic_system_reset(); rt_hw_cpu_reset(); /*Close Peripherals Clock*/ CRM->apb2rst = 0xFFFF; CRM->apb2rst = 0; CRM->apb1rst = 0xFFFF; CRM->apb1rst = 0; CRM->apb1en = 0; CRM->apb2en = 0; CRM->cfg_bit.sclksel = 0; CRM->cfg_bit.ahbdiv = 0; CRM->cfg_bit.apb1div = 0; CRM->cfg_bit.apb2div = 0; CRM->cfg_bit.adcdiv_l = 0; CRM->cfg_bit.adcdiv_h = 0; CRM->cfg_bit.clkout_sel = 0; CRM->ctrl_bit.hexten = 0; CRM->ctrl_bit.cfden = 0; CRM->ctrl_bit.pllen = 0; CRM->cfg_bit.pllrcs = 0; CRM->cfg_bit.pllhextdiv = 0; CRM->cfg_bit.pllmult_l = 0; CRM->cfg_bit.pllmult_h = 0; CRM->cfg_bit.usbdiv_l = 0; CRM->cfg_bit.usbdiv_h = 0; CRM->cfg_bit.pllrange = 0; CRM->clkint_bit.lickstblfc = 0; CRM->clkint_bit.lextstblfc = 0; CRM->clkint_bit.hickstblfc = 0; CRM->clkint_bit.hextstblfc = 0; CRM->clkint_bit.pllstblfc = 0; CRM->clkint_bit.cfdfc = 0; SysTick->CTRL = 0; for (IRQn_Type irq = Reset_IRQn; irq <= UART8_IRQn; irq++) { nvic_irq_disable(irq); __NVIC_ClearPendingIRQ(irq); } jump_to_app = (iapfun)*(uint32_t*)(app_addr + 4); /* code second word is reset address */ __set_MSP(*(uint32_t*)app_addr); /* init app stack pointer(code first word is stack address) */ jump_to_app(); nvic_system_reset(); ``` app start: 0x8020000 ```c // main.go 如下无其他逻辑 int ota_app_vector_reconfig(void) { nvic_vector_table_set(NVIC_VECTTAB_FLASH, 0x20000); return 0; } INIT_BOARD_EXPORT(ota_app_vector_reconfig); static char buffer[4096]; int main (){ ......buffer赋值 rt_kprint("xxxxxx"); } ``` 运行结果, 能正常跳转到app, main函数未输出就直接fault ``` psr: 0x81090000 r00: 0x20003890 r01: 0x00000023 r02: 0x00000000 r03: 0x23232323 r04: 0x23232323 r05: 0x23232323 r06: 0x0000000a r07: 0x00000000 r08: 0x0000000a r09: 0xdeadbeef r10: 0xdeadbeef r11: 0xdeadbeef r12: 0x00000000 lr: 0x080230a7 pc: 0x23232322 hard fault on thread: (NULL) thread pri status sp stack size max used left tick error -------- --- ------- ---------- ---------- ------ ---------- --- main 0 init 0x20004890 0x00001000 59% 0x00000000 000 bus fault: SCB_CFSR_BFSR:0x01 IBUSERR ``` 如下修改可以正常运行 ``` static char buffer[4096]; 改成 static char buffer[1024]; ``` app程序进行单独运行没有问题的
147
小白
进入bootloader的方式探讨
求助:IAP里的APP使用的RTT,跳转后出错。[已解决]
想做网口的IAP远程升级,不知可不可行
IAP问题
基于RT-Thread的STM32F4开发第三讲——DAC
Wireshark抓包EtherCAT报文
818
