GPIO
GPIO设置电平无效
发布于 2020-09-28 11:32:22 浏览:1481
硬件:stm32ret6 软件:CubeMX Keil 问题:就是一个很简单的GPIO控制电平翻转,但是就是起不了作用,希望大佬能帮忙看下,我是被搞懵了。里面还有芯片的数据手册,硬件这边是没有问题的,因为用标准库是可以的,用HAL库就不行了。 ```c int main(void) { HAL_Init(); SystemClock_Config(); MX_GPIO_Init(); while (1) { HAL_GPIO_WritePin(GPIOB, GPIO_PIN_8, GPIO_PIN_SET); HAL_Delay(100); HAL_GPIO_WritePin(GPIOB, GPIO_PIN_8, GPIO_PIN_RESET); } } HAL_StatusTypeDef HAL_Init(void) { /* Configure Flash prefetch */ #if (PREFETCH_ENABLE != 0) #if defined(STM32F101x6) || defined(STM32F101xB) || defined(STM32F101xE) || defined(STM32F101xG) || \ defined(STM32F102x6) || defined(STM32F102xB) || \ defined(STM32F103x6) || defined(STM32F103xB) || defined(STM32F103xE) || defined(STM32F103xG) || \ defined(STM32F105xC) || defined(STM32F107xC) /* Prefetch buffer is not available on value line devices */ __HAL_FLASH_PREFETCH_BUFFER_ENABLE(); #endif #endif /* PREFETCH_ENABLE */ /* Set Interrupt Group Priority */ HAL_NVIC_SetPriorityGrouping(NVIC_PRIORITYGROUP_4); /* Use systick as time base source and configure 1ms tick (default clock after Reset is HSI) */ HAL_InitTick(TICK_INT_PRIORITY); /* Init the low level hardware */ HAL_MspInit(); /* Return function status */ return HAL_OK; } void HAL_MspInit(void) { /* USER CODE BEGIN MspInit 0 */ /* USER CODE END MspInit 0 */ __HAL_RCC_AFIO_CLK_ENABLE(); __HAL_RCC_PWR_CLK_ENABLE(); HAL_NVIC_SetPriorityGrouping(NVIC_PRIORITYGROUP_2); /* System interrupt init*/ /** DISABLE: JTAG-DP Disabled and SW-DP Disabled */ //__HAL_AFIO_REMAP_SWJ_DISABLE(); __HAL_AFIO_REMAP_SWJ_NOJTAG(); /* USER CODE BEGIN MspInit 1 */ /* USER CODE END MspInit 1 */ } void MX_GPIO_Init(void) { GPIO_InitTypeDef GPIO_InitStruct = {0}; /* GPIO Ports Clock Enable */ __HAL_RCC_GPIOD_CLK_ENABLE(); __HAL_RCC_GPIOB_CLK_ENABLE(); /*Configure GPIO pin Output Level */ HAL_GPIO_WritePin(GPIOB, GPIO_PIN_8, GPIO_PIN_SET); /*Configure GPIO pin : PB8 */ GPIO_InitStruct.Pin = GPIO_PIN_8; GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP; GPIO_InitStruct.Pull = GPIO_NOPULL; GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW; HAL_GPIO_Init(GPIOB, &GPIO_InitStruct); } ```
Tianqf
2020-09-28
你是如何确定电平未翻转的,从代码来看,while(1)里面,GPIO_PIN_SET持续100ms,然后GPIO_PIN_RESET后立即又GPIO_PIN_SET了,如果你通过点灯来看,那估计是看不出来的,不好的示波器也够呛能抓到,要不你GPIO_PIN_RESET后再延时100ms试试?
2020-09-28
同类问题不要重复发,直接追加到原问题后面。 https://club.rt-thread.org/ask/question/427431.html
1.5k
thrive
drivers- pin
bsp 里面的drivers/gpio.c 少了一个功能
stm32f407移植RTT中gpio设备驱动问题
config PB4(NJTRST) to GPIO
RT-Thread的GPIO设备驱动问题
关于pin.c文件中语句可能出现的bug
RT-Thread学习笔记--线程创建与官方Pin设备驱动调用
【应用笔记】小白也能玩转RT-Thread之通用GPIO设备【官方出品
串口引脚定义中的GPIO_Pin_sources是社么意思?
RTT -GPIO 使用例程
rt-thread 挂载romfs与ramfs
smart启动流程详解
小内存管理(1)--- 内存初始化
spi自动初始化程序
zhuzhuzhu
YDPB_5935
aeniac
