stm32f407-atk
STM32F407ZGT6 ADC+DMA 多路输出结果有误
发布于 2021-11-28 03:00:25 浏览:1940
在网上借鉴了ADC+DMA的写法改写了rtthread的adc框架,可以正常的获取单个通道的值,但是当读取多通道时发现其他的值只与第一个通道值有关,且有一定的差值。 [借鉴的地址](https://blog.csdn.net/qq_30659437/article/details/107282070) ```c #ifdef BSP_USING_ADC_DMA #define BSP_DMA_BUF_COUNT 1 #define BSP_ADC_TOTAL_CHANNELS 3 #define BSP_ADC_CHN_DEF {5,6,7} #define BSP_ADC_SAMPLE_CYC_DEF ADC_SAMPLETIME_56CYCLES #endif #define ADC1_CONFIG \ { \ .Instance = ADC1, \ .Init.ClockPrescaler = ADC_CLOCKPRESCALER_PCLK_DIV4, \ .Init.Resolution = ADC_RESOLUTION_12B, \ .Init.DataAlign = ADC_DATAALIGN_RIGHT, \ .Init.ScanConvMode = ENABLE, \ .Init.EOCSelection = ADC_EOC_SINGLE_CONV, \ .Init.ContinuousConvMode = ENABLE, \ .Init.NbrOfConversion = BSP_ADC_TOTAL_CHANNELS, \ .Init.DiscontinuousConvMode = DISABLE, \ .Init.NbrOfDiscConversion = 0, \ .Init.ExternalTrigConv = ADC_SOFTWARE_START, \ .Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE, \ .Init.DMAContinuousRequests = ENABLE, \ } #define ADC1_DMA_CONFIG \ { \ .Instance = DMA2_Stream0, \ .Init.Direction = DMA_PERIPH_TO_MEMORY, \ .Init.PeriphInc = DMA_PINC_DISABLE, \ .Init.MemInc = DMA_MINC_ENABLE, \ .Init.PeriphDataAlignment = DMA_PDATAALIGN_HALFWORD, \ .Init.MemDataAlignment = DMA_MDATAALIGN_HALFWORD, \ .Init.Mode = DMA_CIRCULAR, \ .Init.Priority = DMA_PRIORITY_HIGH, \ .Init.FIFOMode = DMA_FIFOMODE_DISABLE, \ .Init.FIFOThreshold = DMA_FIFO_THRESHOLD_HALFFULL, \ .Init.MemBurst = DMA_MBURST_SINGLE, \ .Init.PeriphBurst = DMA_PBURST_SINGLE, \ .Init.Channel = DMA_CHANNEL_0, \ } ``` ADC和DMA的配置 ``` void HAL_ADC_MspInit(ADC_HandleTypeDef *hadc) { GPIO_InitTypeDef GPIO_InitStruct = {0}; if (hadc->Instance == ADC1) { /* Peripheral clock enable */ __HAL_RCC_ADC1_CLK_ENABLE(); __HAL_RCC_GPIOA_CLK_ENABLE(); GPIO_InitStruct.Pin = GPIO_PIN_5 | GPIO_PIN_6 | GPIO_PIN_7; GPIO_InitStruct.Mode = GPIO_MODE_ANALOG; GPIO_InitStruct.Pull = GPIO_NOPULL; HAL_GPIO_Init(GPIOA, &GPIO_InitStruct); #ifdef BSP_USING_ADC_DMA __HAL_RCC_DMA2_CLK_ENABLE(); HAL_NVIC_SetPriority(DMA2_Stream0_IRQn, 0, 0); HAL_NVIC_EnableIRQ(DMA2_Stream0_IRQn); #endif } } ``` GPIO初始化 ```c static int stm32_adc_init(void) { int result = RT_EOK; /* save adc name */ char name_buf[5] = {'a', 'd', 'c', '0', 0}; int i = 0; for (i = 0; i < sizeof(adc_config) / sizeof(adc_config[0]); i++) { /* ADC init */ name_buf[3] = '0'; stm32_adc_obj[i].ADC_Handler = adc_config[i]; #if defined(ADC1) if (stm32_adc_obj[i].ADC_Handler.Instance == ADC1) { name_buf[3] = '1'; } #endif #if defined(ADC2) if (stm32_adc_obj[i].ADC_Handler.Instance == ADC2) { name_buf[3] = '2'; } #endif #if defined(ADC3) if (stm32_adc_obj[i].ADC_Handler.Instance == ADC3) { name_buf[3] = '3'; } #endif if (HAL_ADC_Init(&stm32_adc_obj[i].ADC_Handler) != HAL_OK) { LOG_E("%s init failed", name_buf); result = -RT_ERROR; } else { #ifdef BSP_USING_ADC_DMA int j; ADC_ChannelConfTypeDef sConfig = {0}; rt_uint32_t chn[BSP_ADC_TOTAL_CHANNELS] = BSP_ADC_CHN_DEF; sConfig.SamplingTime = BSP_ADC_SAMPLE_CYC_DEF; for (j = 0; j < BSP_ADC_TOTAL_CHANNELS; j++) { sConfig.Channel = stm32_adc_get_channel(chn[j]); sConfig.Rank = j + 1; if (HAL_ADC_ConfigChannel(&stm32_adc_obj[j].ADC_Handler, &sConfig) != HAL_OK) { rt_kprintf("channel error\n"); return 1; } } #endif /* register ADC device */ if (rt_hw_adc_register(&stm32_adc_obj[i].stm32_adc_device, name_buf, &stm_adc_ops, &stm32_adc_obj[i].ADC_Handler) == RT_EOK) { LOG_D("%s init success", name_buf); } else { LOG_E("%s register failed", name_buf); result = -RT_ERROR; } } } return result; } INIT_BOARD_EXPORT(stm32_adc_init); #endif /* BSP_USING_ADC */ ``` ```c static rt_err_t stm32_adc_enabled(struct rt_adc_device *device, rt_uint32_t channel, rt_bool_t enabled) { ADC_HandleTypeDef *stm32_adc_handler; DMA_HandleTypeDef dma_init_handler = {0}; RT_ASSERT(device != RT_NULL); stm32_adc_handler = device->parent.user_data; if (enabled) { #ifdef BSP_USING_ADC_DMA if (device->dma_buf != RT_NULL) { if (stm32_adc_handler->Instance == ADC1) { dma_init_handler = dma_config[0]; HAL_DMA_Init(&dma_init_handler); __HAL_LINKDMA(stm32_adc_handler, DMA_Handle, dma_init_handler); HAL_DMA_Start(&dma_init_handler, ((rt_uint32_t)ADC1 + 0x4c), (rt_uint32_t)device->dma_buf, BSP_ADC_TOTAL_CHANNELS * BSP_DMA_BUF_COUNT); } HAL_ADC_Start_DMA(stm32_adc_handler, (rt_uint32_t *)device->dma_buf, BSP_ADC_TOTAL_CHANNELS * BSP_DMA_BUF_COUNT); } #else __HAL_ADC_ENABLE(stm32_adc_handler); #endif } else { __HAL_ADC_DISABLE(stm32_adc_handler); } return RT_EOK; } ``` 改写的驱动部分 ```c rt_device_t adc1_dev; rt_uint16_t joystick_value[3][1]; static int rt_adc1_init(void) { adc1_dev = rt_device_find("adc1"); if (adc1_dev == RT_NULL) { rt_kprintf("adc sample run failed! can't find %s device!\n", "adc1"); } rt_device_control(adc1_dev, RT_ADC_CMD_SET_DMA_BUF, joystick_value); rt_device_control(adc1_dev, RT_ADC_CMD_ENABLE, RT_NULL); return RT_EOK; } INIT_APP_EXPORT(rt_adc1_init); ``` 启动的部分    仅仅改变PA5的输入电平,三个输出都会变,且值都不相同,而改变PA6,7则完全没影响
红枫
2023-04-03
通道切换时上一个通道的电平可能会影响下一个通道,如果想消除这种影响,可以采样两次转换取第2次转换结果的方式。原理看ADC采样保持
2021-11-29
学以致用
ADC 的 channel,应该配置到DMA那边吧
fubaojun2006
2021-12-02
哇(挖)~~坑~~~啊!
你的帖子,发布于 2021-11-28 03:00:25 我摸了摸我的头发。 看了你两篇关于ADC DMA的帖子了,也看了你参考的源连接。 我决定 还是按裸机方式 初始化ADC ,然后初始化DMA 。用一个任务去处理DMA搬运过来的数据。 这样感觉还简单点---来自一个没有学设备管理框架的渣渣
safly
2022-03-25
兄弟,你这个驱动没有问题,只有一行代码有个笔误。 将 `if (HAL_ADC_ConfigChannel(&stm32_adc_obj[j].ADC_Handler, &sConfig) != HAL_OK)` 改成 `if (HAL_ADC_ConfigChannel(&stm32_adc_obj[i].ADC_Handler, &sConfig) != HAL_OK)` 即可,通道配置的时候,不能改变stm32_adc_obj的下标。
CrazyH
2023-04-19
rtt的adc架构 学习就行
1.9k
Tourist
请大神帮忙看下风格 还是哪里有问题 照着串口驱动写的ADC驱动
ADC config
rt_thread_delay()和ADC采样之间的冲突
请教在官方BSP中的STM32F40X程序中加入ADC,串口没输出。
给RT-Thread添加ADC驱动框架
求助:ADC采样被干扰
【内核和外设学习营】十里 ADC光敏电阻电压采集实验
<内核学习营>+坦然+探索者stm32f407板子的ADC测试光传感器实验
【内核学习营】+青春+ADC读取光敏传感器实验
《内核学习营》+水一方+项目中应用的ADC实现电压采集
求助can通讯下怎末运用485
STM32F407ZGT适配串口V2驱动
wake_mirco
mushroom
Jack_____
