PM电源管理
PM组件
休眠
休眠后串口还在打印数据
发布于 2024-06-09 16:27:06 浏览:846
在使用RTthread的PM模块时,想控制stm32f103进入最浅的睡眠模式,于是使用PM的IDLE状态,增加了以下代码,然后发现程序不停的在串口打印第21行的内容,debug后发现没有进入其他的轮询任务,这是否意味着休眠?还是说一直在尝试唤醒然后又进入了睡眠?有什么解决方法吗?(休眠不应该是什么都不执行了吗?串口理论上应该没法打印才对) ```c void PM_DisableSystick(void) { /* Disable SysTick */ HAL_SuspendTick(); // SysTick->CTRL &= ~SysTick_CTRL_ENABLE_Msk; } void PM_EnableSystick(void) { /* Enable SysTick */ // SysTick->CTRL |= SysTick_CTRL_ENABLE_Msk; HAL_ResumeTick(); } #endif void pm_sleep_idle(struct rt_pm *pm) { LOG_D("sleep light mode start"); control_40v_status(GPIO_CLOSE); control_3_3v_status(GPIO_CLOSE); control_led_status(GPIO_CLOSE); set_40v_gpio_mode(GPIO_INPUT_MODE); set_3_3v_gpio_mode(GPIO_INPUT_MODE); set_led_gpio_mode(GPIO_INPUT_MODE); set_co1_gpio_mode(GPIO_INPUT_MODE); set_co2_gpio_mode(GPIO_INPUT_MODE); set_co3_gpio_mode(GPIO_INPUT_MODE); set_co4_gpio_mode(GPIO_INPUT_MODE); set_co5_gpio_mode(GPIO_INPUT_MODE); set_co6_gpio_mode(GPIO_INPUT_MODE); HAL_CAN_RequestSleep(&hcan); //set can bus into leep mode PM_DisableSystick(); HAL_PWR_EnterSLEEPMode(PWR_MAINREGULATOR_ON, PWR_SLEEPENTRY_WFI); } static void sleep(struct rt_pm *pm, uint8_t mode) { switch (mode) { case PM_SLEEP_MODE_NONE: break; case PM_SLEEP_MODE_IDLE: pm_sleep_idle(pm); break; case PM_SLEEP_MODE_LIGHT: break; case PM_SLEEP_MODE_DEEP: break; case PM_SLEEP_MODE_STANDBY: break; case PM_SLEEP_MODE_SHUTDOWN: break; default: RT_ASSERT(0); break; } } #ifdef PM_IIC_CALLBACK /* iic module rt_device_pm_ops callback */ int pm_i2c_suspend(const struct rt_device *device, rt_uint8_t mode) { LOG_W("pm_i2c_suspend works"); return RT_EOK; } void pm_i2c_resume(const struct rt_device *device, rt_uint8_t mode) { LOG_W("pm_i2c_resume works"); return ; } static const struct rt_device_pm_ops _i2c_pm_ops = { pm_i2c_suspend, pm_i2c_resume, RT_NULL }; #endif static const struct rt_pm_ops _ops = { sleep, #ifdef PM_USING_RUN_AND_TICKLESS run, pm_timer_start, pm_timer_stop, pm_timer_get_tick #else RT_NULL, RT_NULL, RT_NULL, RT_NULL #endif }; int drv_pm_hw_init(void) { rt_uint8_t timer_mask = 0; #ifdef PM_USING_RUN_AND_TICKLESS /* initialize timer mask */ timer_mask = 1UL << PM_SLEEP_MODE_NONE; #endif #ifdef PM_IIC_CALLBACK /* regisiter device pm module */ rt_pm_device_register("i2c1", &_i2c_pm_ops); #endif /* initialize system pm module */ rt_system_pm_init(&_ops, timer_mask, RT_NULL); LOG_I("PM init successful"); return 0; } INIT_BOARD_EXPORT(drv_pm_hw_init); ```
_CXF_
2025-05-29
PM_SLEEP_MODE_IDLE可以被任何中断唤醒,这里频繁退出又进入应该是系统滴答定时器中断唤醒了,但实际没有更高优先级任务需要运行,继而调度到idle线程继续进入PM_SLEEP_MODE_IDLE
2025-05-30
代码总在「分分钟搞定」的狂喜与「必有暗坑」的隐忧间往复
- 合理的方案是使用RTC之类的可以从深度睡眠唤醒的定时器做唤醒调度. - 进入睡眠时,关闭除开可以唤醒的中断源以外的所有中断,等到唤醒后在恢复中断或者有需要在开启中断. - 是否进入睡眠,一个是观察日志是否打印.另一个使用功耗仪抓功耗数据(需要硬件有做低功耗处理+软件配合实现)
846
小航同学
STM32F103的低功耗
最近用rtthread系统下AD采样并低功耗,中断响应不及时
rt-thread低功耗休眠应用问题请教
关于RTT对低功耗的支持
RT-Thread怎么休眠实现低功耗。
RT-Thread V3.0支持的低功耗,OS会自行进入吗?
关于RTThread3.0低功耗休眠模式
RTT3.0的bsp包中哪些MCU自带低功耗定时器?
关于低功耗上次说针对L4出个BSP的,怎么迟迟不见呀
低功耗问题。
睿擎工业开发平台--如何将i2c1的引脚用于串口4
睿擎工业开发平台--如何更新设备数dts(设置IO复用配置)
睿擎派RK3506开发板开箱记录&amp;初步调试
睿擎工业开发平台rk3506常用外设功能评测
