串口DMA
80
SerialX 遇到的问题
发布于 2023-05-26 15:12:13 浏览:675
按照[@出出啊](/u/db779ee1aa856f55) 大佬的serial移植指南,移植到gd32f427。在使用 dma_tx 时,只能发送一次,然后死机。 在执行以下代码时,最后的 ` rt_hw_interrupt_enable(level);` 执行便跑飞 了 ```c rt_inline int _serial_dma_tx(struct rt_serial_device *serial, const rt_uint8_t *data, int length) { rt_size_t len, length_t, size, i; struct rt_serial_fifo *tx_fifo; rt_base_t level; rt_uint8_t ch; static rt_uint8_t last_char = 0; RT_ASSERT(serial != RT_NULL); if (length == 0) return 0; tx_fifo = (struct rt_serial_fifo*) serial->serial_tx; size = 0; do { length_t = length - size; /* disable interrupt */ level = rt_hw_interrupt_disable(); // serial->ops->disable_interrupt(serial); len = tx_fifo->buf_sz - _serial_fifo_calc_data_len(tx_fifo); if ((len == 0) && // non-blocking io mode (serial->parent.open_flag & RT_DEVICE_OFLAG_NONBLOCKING) == RT_DEVICE_OFLAG_NONBLOCKING) { /* enable interrupt */ rt_hw_interrupt_enable(level); // serial->ops->enable_interrupt(serial); break; } if ((len == 0) && // blocking io mode (serial->parent.open_flag & RT_DEVICE_OFLAG_NONBLOCKING) != RT_DEVICE_OFLAG_NONBLOCKING) { rt_err_t ret; /* enable interrupt */ rt_hw_interrupt_enable(level); // serial->ops->enable_interrupt(serial); #ifndef RT_SERIAL_USE_EVENT ret = rt_completion_wait(&(serial->completion_tx), RT_WAITING_FOREVER); #else ret = rt_event_recv(serial->tx_done, RT_SERIAL_EVENT_TXDONE, RT_EVENT_FLAG_OR | RT_EVENT_FLAG_CLEAR, RT_WAITING_FOREVER, RT_NULL); #endif if (ret == RT_EOK || ret == -RT_ETIMEOUT) { continue; } else { return size; } } if (len > length_t) { len = length_t; } /* copy to software FIFO */ while (len > 0) { /* * to be polite with serial console add a line feed * to the carriage return character */ if (*data == '\n' && (serial->parent.open_flag & RT_DEVICE_FLAG_STREAM) == RT_DEVICE_FLAG_STREAM && last_char != '\r') { _serial_fifo_push_data(tx_fifo, '\r'); last_char = '\r'; if (len == 1) { break; } else { len--; } } else if (*data == '\r') { last_char = '\r'; } else { last_char = 0; } _serial_fifo_push_data(tx_fifo, *data); data++; len--; size++; } /* if the next position is read index, discard this 'read char' */ if (tx_fifo->put_index == tx_fifo->get_index) { tx_fifo->is_full = RT_TRUE; } /* enable interrupt */ rt_hw_interrupt_enable(level); // serial->ops->enable_interrupt(serial); // TODO: start tx /* disable interrupt */ level = rt_hw_interrupt_disable(); // serial->ops->disable_interrupt(serial); if (serial->ops->is_dma_txing(serial) == RT_FALSE) { /* calucate fifo data size */ len = _serial_fifo_calc_data_len(tx_fifo); if (len > RT_SERIAL_DMA_BUFSZ) { len = RT_SERIAL_DMA_BUFSZ; } /* read from software FIFO */ for (i = 0; i < len; i++) { /* pop one byte data */ ch = _serial_fifo_pop_data(tx_fifo); serial->serial_dma_tx[i] = ch; } tx_fifo->is_full = RT_FALSE; serial->ops->start_dma_tx(serial, serial->serial_dma_tx, len); } /* enable interrupt */ rt_hw_interrupt_enable(level); // serial->ops->enable_interrupt(serial); } while(size < length); return size; } ```
the_subtly
2023-05-26
 dma_tx 发送前,寄存器状态
675
the_subtly
串口DMA发送数据时,数据被覆盖
关于串口DMA模式下rt_device_close问题
stm32L4 lpuart1DMA下不能打开的问题
UART驱动开启DMA后编译报错,UART DMA配置中加入了没有定义的域
UART DMA 设计问题
UART DMA 拆包问题
串口如何有效的清除掉接收缓冲,而不必一个一个的去读取
串口接收使用方式问题
在studio中打开串口的DMA后,编译出错
官方DMA串口例程,使用时数据打印错误
睿擎工业开发平台---文件系统测试使用
睿擎工业开发平台--SPI使用和测四
睿擎工业开发平台--can总线使用测试
睿擎工业开发平台--如何将i2c1的引脚用于串口4
