线程调度
多次调用rt_thread_startup出现stack overflow错误
发布于 2022-06-07 10:24:08 浏览:1072
目的:想要实现串口接收不定长数据,思路如下:一个串口接收线程,一个判断数据是否接收完成线程。 串口接收线程中:接收一个字节,令开始接收标志`(rx_start=1)`置1,同时将`(rx_count=0)`,开启计时线程`rt_thread_startup(timeout_thread)`。 是否接收完成线程中:对`rx_count++`,如果`rx_count`到达某个值,说明串口接收完成,对数据进行处理同时将标志清零。 具体代码如下: ```c void serial_thread_entry(void *parameter) { char buffer; while(1) { while(rt_device_read(u1_dev, 0, &buffer, 1) != 1)//从串口读一个字节数据,没有读到则等待接收信号量 { rt_sem_take(&uart1_rx_sem, RT_WAITING_FOREVER);//阻塞等待接收信号量,等待到信号量后再次读取数据 } temp_cmd[temp_len++] = buffer; //接受缓存中的数据 //计数归0,每次接收到一个数据都将该值置0,从而可以重新进行计时 rx_count = 0; if(rx_start == 0) { rt_thread_startup(timeout_thread); } rx_start = 1; } void timeout_thread_entry(void *parameter) { int i; if(rx_start == 1) { while(rx_count < 2) { rx_count ++; rt_thread_delay(1); } if (rx_count >= 2) { rx_count = 0; //处理收到的数据 rt_memset(temp_cmd, 0, temp_len); temp_len = 0; rx_start = 0; } } } rt_err_t rx_callback(rt_device_t dev, rt_size_t size) { rt_sem_release(&uart1_rx_sem);//串口接收到数据后产生中断,调用此回调函数,然后发送接收信号量 return RT_EOK; } int main(void) { rt_kprintf("========================打开串口,并创建串口线程===============================\n"); rt_err_t ret = 0; u1_dev = rt_device_find("uart1"); if(u1_dev == RT_NULL) { rt_kprintf("rt_device_find uart1 failed\n"); return -EINVAL; } ret = rt_device_open(u1_dev, RT_DEVICE_OFLAG_RDWR | RT_DEVICE_FLAG_INT_RX); //以读写及中断接收方式打开串口设备 if(ret < 0) { rt_kprintf("rt_device_open uart failed\n"); return ret; } rt_device_set_rx_indicate(u1_dev, rx_callback); //设置接收回调函数 ret = rt_sem_init(&uart1_rx_sem, "u1_sem", 0, RT_IPC_FLAG_FIFO); //先进先出 if(ret != RT_EOK) { rt_kprintf("rt_sem_init failed...\n"); return ret; } rt_thread_t u1_thread = rt_thread_create("u1_recv", serial_thread_entry, RT_NULL, 1024*8, 17, 5); if(u1_thread == RT_NULL) { return RT_ERROR; } rt_thread_startup(u1_thread); timeout_thread = rt_thread_create("timeout", timeout_thread_entry, RT_NULL, 1024, 18, 5); if(timeout_thread == RT_NULL) { return RT_ERROR; } return 0; } ``` 出现的问题是:用串口助手发送第一包数据时可以正常处理,再发送一包数据(即便是1个字节),出现`thread: stack overflow`,定位到再第二次开启判断接收是否完成线程`rt_thread_startup(timeout_thread)`卡住了,各位大佬看看这个是什么造成的呢?
ching
2022-06-07
>`temp_cmd[temp_len++] = buffer; //接受缓存中的数据` 加个越界保护吧
2022-06-07
用一个定时器线程定时判断数据是否接收完?这个操作。。。 为啥不试试 serialX 呢,可以达到你的需求。
一个小白丫
2022-06-07
已经找到问题了,谢谢各位~
1.1k
一个小白丫
串口DMA发送数据时,数据被覆盖
关于串口DMA模式下rt_device_close问题
finsh 控制台 适配 RS 485请大神指点????
串口无法接受数据,但可以发送
串口如何有效的清除掉接收缓冲,而不必一个一个的去读取
串口接收使用方式问题
雅特力FINSH问题
V5.2.1 魔改以支持多核处理器从任意核启动
【RSOC25】Day5 课程笔记:软件包相关知识
RT-Thread 夏令营 第五天笔记
【RSOC25】Day5 课程笔记:软件包和网络组件
【RSOC25】Day4 课程笔记:I/O设备和驱动框架
Ryan_CW
D1sguIse_
yqiu
