硬件定时器
硬件定时器超时影响串口接收回调的原因?
发布于 2022-08-10 10:01:03 浏览:579
串口DMA方式接收,在接收回调里打开硬件定时器 ```c int hwtimer_sample(void) { rt_err_t ret = RT_EOK; rt_hwtimerval_t timeout_s; /* 定时器超时值 */ rt_hwtimer_mode_t mode; /* 定时器模式 */ rt_uint32_t freq = 10000; /* 计数频率 */ /* 查找定时器设备 */ hw_dev = rt_device_find(HWTIMER_DEV_NAME); if (hw_dev == RT_NULL) { rt_kprintf("hwtimer sample run failed! can't find %s device!\n", HWTIMER_DEV_NAME); return RT_ERROR; } /* 以读写方式打开设备 */ ret = rt_device_open(hw_dev, RT_DEVICE_OFLAG_RDWR); if (ret != RT_EOK) { rt_kprintf("open %s device failed!\n", HWTIMER_DEV_NAME); return ret; } /* 设置超时回调函数 */ rt_device_set_rx_indicate(hw_dev, timeout_cb); /* 设置计数频率(若未设置该项,默认为1Mhz 或 支持的最小计数频率) */ rt_device_control(hw_dev, HWTIMER_CTRL_FREQ_SET, &freq); /* 设置模式为周期性定时器(若未设置,默认是HWTIMER_MODE_ONESHOT)*/ mode = HWTIMER_MODE_ONESHOT; ret = rt_device_control(hw_dev, HWTIMER_CTRL_MODE_SET, &mode); if (ret != RT_EOK) { rt_kprintf("set mode failed! ret is :%d\n", ret); return ret; } return ret;} ``` 定时器超时回调 ```c /* 定时器超时回调函数 */ static rt_err_t timeout_cb(rt_device_t dev, rt_size_t size) { // rt_kprintf("this is hwtimer timeout callback fucntion!\n"); rt_kprintf("tick is :%d !\n", rt_tick_get()); rt_uint32_t len = 0; timeout = 1; len = rt_device_read(dev, 0, USART3_RX_BUF, USART3_RX_LEN); dump_hex(USART3_RX_BUF, len); rt_sem_release(&recv_comp); // if (rx9_length > 0) // { // rt_kprintf("rx9_length = %d \n", rx9_length); // } return 0; } ``` 串口接收回调 ```c rt_err_t env_recv_ind(rt_device_t dev, rt_size_t size) { rt_hwtimerval_t timeout_s; /* 定时器超时值 */ timeout_s.sec = 0; /* 秒 */ timeout_s.usec = 999000; /* 微秒 100ms的时候是正常的,但是DTU数据间隔大,改成这个试试 DTU用延时做了*/ USART3_RX_LEN += size; rt_kprintf("receive time is %d size == %d\n", rt_tick_get(), size); // rt_device_write(hw_dev, 0, &timeout_s, sizeof(timeout_s)) ; /* release semaphore to let finsh thread rx data */ // if (size > 0) // rt_sem_release(&env_rx); return RT_EOK; } ``` 现象:加上开启定时器的时候,如下,相当于卡了1s,没接收新的数据  去掉开启定时器的时候,如下,一直能接收到  这个开启定时器还影响串口接收吗? 我之前也用到了这两个,可以正常,现在是想优化一下,谢谢
2022-08-11
嵌入式
如果不使用 DMA 还有类似的问题吗?
红枫
2022-08-10
999000us不就是一秒了吗?
579
伊森亨特
78
33
串口DMA发送数据时,数据被覆盖
关于串口DMA模式下rt_device_close问题
finsh 控制台 适配 RS 485请大神指点????
串口无法接受数据,但可以发送
串口如何有效的清除掉接收缓冲,而不必一个一个的去读取
串口接收使用方式问题
雅特力FINSH问题
RTT串口查找函数使用过程中遇到的问题。
RT-Thread CI编译产物artifacts自动上传功能介绍
STM32G030移植RT-Thread
CubeMX & RT-Thread Studio 联合开发说明
RT-Thread项目助手v0.3 | Ubuntu与MacOS平台的RT-Thread Env
1522
815
