rt_hw_spi_rc522_init
发布于 2021-12-29 20:47:23 浏览:875
各位大佬! 小弟在学习RT-THREAD, 遇到初始化失败! 跟踪调试发现是if (device->bus->owner == device) 这个语句 条件不成立,也就是说Owner 不对? 能否赐教 指点迷津, 不胜感激 ```c static int rt_hw_spi_rc522_init() { rt_err_t res = RT_EOK; // Attach Device spi_cs.pin = MFRC522_SS_PIN; rt_pin_mode(spi_cs.pin, PIN_MODE_OUTPUT); res = rt_spi_bus_attach_device(&mfrc522_spi_dev, MFRC522_SPI_DEVICE_NAME, MFRC522_SPI_BUS_NAME, (void*)&spi_cs); if (res != RT_EOK) { rt_kprintf("[RC522] Failed to attach device %s\n", MFRC522_SPI_DEVICE_NAME); return res; } // Set device SPI Mode struct rt_spi_configuration cfg = {0}; cfg.data_width = 8; cfg.mode = RT_SPI_MASTER | RT_SPI_MODE_0 | RT_SPI_MSB | RT_SPI_NO_CS; cfg.max_hz = MFRC522_SPICLOCK; rt_spi_configure(&mfrc522_spi_dev, &cfg); return RT_EOK; } /* 导出到自动初始化 */ INIT_COMPONENT_EXPORT(rt_hw_spi_rc522_init); rt_err_t rt_spi_configure(struct rt_spi_device *device, struct rt_spi_configuration *cfg) { rt_err_t result; RT_ASSERT(device != RT_NULL); /* set configuration */ device->config.data_width = cfg->data_width; device->config.mode = cfg->mode & RT_SPI_MODE_MASK ; device->config.max_hz = cfg->max_hz ; if (device->bus != RT_NULL) { result = rt_mutex_take(&(device->bus->lock), RT_WAITING_FOREVER); if (result == RT_EOK) if (device->bus->owner == device) { device->bus->ops->configure(device, &device->config); } /* release lock */ rt_mutex_release(&(device->bus->lock)); } } return RT_EOK; } ```
2021-12-29
估计是main线程的栈不足了,需要增大一些看看。
2021-12-29
spi总线是否已注册好,rt_spi_bus_attach_device中几个参数的定义是否正确,贴出来看看呢。 另外,对于cs管脚,可以不用再重新定义配置模式。
2021-12-30
没问题的,用的时候再真正配。 参考 - [请教rt_spi_configure函数理解](https://club.rt-thread.org/ask/question/4195.html)
875
GeorgeWang
BBB的SPI驱动
求个SPI上挂两个或多个设备的使用例子
SPI设备有个bug
SPI驱动
SPI FLASH挂载的问题
SPI-FLASH 文件系统 SPIFFS
求助一个完整的 spi flash 驱动
关于同时使用文件系统与SPI FLASH的问题
RT Thread 块设备注册
睿擎工业开发平台--CanOpen示例测试
【深度剖析】RT-Thread 线程调度流程
Ryan_CW
chejia12
纯白酱
530china
rv666
