30
下列放出的 消息队列接收消息函数中,后面有备注 步骤几 的链表是怎么连接的?
发布于 2024-12-17 16:35:23 浏览:263
```c rt_err_t rt_mq_recv(rt_mq_t mq, void *buffer, rt_size_t size, rt_int32_t timeout) { struct rt_thread *thread; register rt_ubase_t temp; struct rt_mq_message *msg; rt_uint32_t tick_delta; RT_ASSERT(mq != RT_NULL); RT_ASSERT(buffer != RT_NULL); RT_ASSERT(size != 0); /* initialize delta tick */ tick_delta = 0; /* get current thread */ thread = rt_thread_self(); RT_OBJECT_HOOK_CALL(rt_object_trytake_hook, (&(mq->parent.parent))); /* disable interrupt */ temp = rt_hw_interrupt_disable(); /* for non-blocking call */ if (mq->entry == 0 && timeout == 0) { rt_hw_interrupt_enable(temp); return -RT_ETIMEOUT; } /* message queue is empty */ while (mq->entry == 0) { RT_DEBUG_IN_THREAD_CONTEXT; /* reset error number in thread */ thread->error = RT_EOK; /* no waiting, return timeout */ if (timeout == 0) { /* enable interrupt */ rt_hw_interrupt_enable(temp); thread->error = -RT_ETIMEOUT; return -RT_ETIMEOUT; } /* suspend current thread */ rt_ipc_list_suspend(&(mq->parent.suspend_thread), thread, mq->parent.parent.flag); /* has waiting time, start thread timer */ if (timeout > 0) { /* get the start tick of timer */ tick_delta = rt_tick_get(); RT_DEBUG_LOG(RT_DEBUG_IPC, ("set thread:%s to timer list\n", thread->name)); /* reset the timeout of thread timer and start it */ rt_timer_control(&(thread->thread_timer), RT_TIMER_CTRL_SET_TIME, &timeout); rt_timer_start(&(thread->thread_timer)); } /* enable interrupt */ rt_hw_interrupt_enable(temp); /* re-schedule */ rt_schedule(); /* recv message */ if (thread->error != RT_EOK) { /* return error */ return thread->error; } /* disable interrupt */ temp = rt_hw_interrupt_disable(); /* if it's not waiting forever and then re-calculate timeout tick */ if (timeout > 0) { tick_delta = rt_tick_get() - tick_delta; timeout -= tick_delta; if (timeout < 0) timeout = 0; } } /* get message from queue */ msg = (struct rt_mq_message *)mq->msg_queue_head; // 步骤 1 /* move message queue head */ mq->msg_queue_head = msg->next; // 步骤 2 /* reach queue tail, set to NULL */ if (mq->msg_queue_tail == msg) mq->msg_queue_tail = RT_NULL; /* decrease message entry */ mq->entry --; /* enable interrupt */ rt_hw_interrupt_enable(temp); /* copy message */ rt_memcpy(buffer, msg + 1, size > mq->msg_size ? mq->msg_size : size); /* disable interrupt */ temp = rt_hw_interrupt_disable(); /* put message to free list */ msg->next = (struct rt_mq_message *)mq->msg_queue_free; // 步骤 3 mq->msg_queue_free = msg; // 步骤 4 /* enable interrupt */ rt_hw_interrupt_enable(temp); RT_OBJECT_HOOK_CALL(rt_object_take_hook, (&(mq->parent.parent))); return RT_EOK; } ``` - 我的理解是: 消息队列中有两个链表,一个一个空闲链表,一个消息链表 - mq->msg_queue_head 代表消息链表的表头 - mq->msg_queue_tail 代表消息链表的表尾 - 步骤1的时候:msg得到消息链表的表头 - 步骤2的时候:刷新消息链表的表头,因为原本的表头中的消息被取走了。 - 步骤3的时候:`msg->next`指向当前空闲链表的头部。 这步是为什么? `msg->next`不是应该还存在消息吗,不是应该这样吗 `msg=(struct rt_mq_message *)mq->msg_queue_free;` 因为msg的消息给搬走了 - 步骤4的时候: 请问这步 做了什么?
az1010
2024-12-17
开始学习消息列表,还有很多不懂的地方,请万能的老哥们指教
2024-12-18
注释里还是比较全的了,请仔细阅读注释。 另外,注意每一行注释描述的可能不仅仅是其后面一行代码的功能,而是好几行代码的功能。
263
az1010
rt_object_init中报assertion failed错误?
在 MDK中的NANO 里创建消息队列失败,内存堆已开启
如何用消息队列传递结构体数据
消息队列满了以后接收乱码
消息队列传输不定长数据
使用消息队列在线程中发送总失败
初始化第二个消息队列时发生硬件错误
rtthread消息队列一对多的情况
消息队列为什么会出现获取到的内容有旧的数据?
通过消息队列名称,获取消息队列句柄
新版OneNet的星火1号开发板例程适配(下)
重磅预售!RT-Trace调试工具
yans
tjrong
miandian_7
Pai同学
Rick98
河南理工大学恁带劲儿
